    2.3k Posts 517 Posters 3.0m Views 522 Watching
      skuser259
      Thanks Rich, followed your advice but they have not responded, I am desperate to user this plugin and my project is being held up by this. I may need to ask PayPal for a refund.
        @skuser you should be sorted now. Check your inbox when you get a chance
          @clinexgrim said:
          I purchased license, but can't Validate it because of Error A04
          I've already installed Sketchucation store v4.1.0.
          how can I solve it???? 😒
          Can you let me know the what plugin you need help with?
          • C
            clinexgrim
            oh, I'm trying to validate Fredocorner.
              13thRebel
              Hello.
              Are there other payment methods besides PayPal?
                Not at the moment. Stripe support planned.
                • G
                  gazzato70
                  Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
                  • I
                    irachica
                    licence problem with fredo corner
                      Got more info?
                        rwilliamson
                        Thank you very much. This solved my error also. 😎
                        • kimgaK
                          kimga
                          I just downloaded Fredo Spline - to try out for 15 day, but it already said that the license has expired in February 2021...
                          • fredo6F
                            I don't think it says 'the license has expired', but most probably 'the trial period has expired'.
                            It is likely because you already installed FredSpline sometimes in Februrary.
                            • H
                              helenbzilka
                              I bought a license Fredo Corner and I can’t load it. I have already reinstall my program for a few times.
                                @helenbzilka said:
                                Install latest version of SketchUcation Tools...
                                Plugin Store Download | SketchUcation
                                Extending SketchUp has never been easier with a suite of tools that make installing and disabling plugins and extensions a one click operation.
                                (sketchucation.com)
                                If that won't fix issue, erase your signature file and reactivate your license.
                                C;\Users\[SomeName]\AppData\Local\SCF Licenses
                                • L
                                  langis
                                  Just like some others here I get the following error message when trying to validate my FredoCorner license.
                                  "msg_validation_error
                                  Request to Sketchucation = ERROR_A04"
                                  I tried to find the soultion in this thread but couldn't find an answer adressing this specific error code
                                  I have Sketchucation extension store v4.1.3 installed and I have tried to delete the SFCLicenseSignature file and reactivate the license. Still get the error message. Can you help me with a solution for ERROR_A04?
                                  • C
                                    Chisaina mamont
                                    Hi, for some reason, a license has ceased to work on
                                    Fredocorner. I hope to help.
                                    • fredo6F
                                      Could you do the following
                                      1. In the Message History panel, click on the button "License File Location". This opens the directory where license files are stored.
                                      2. Erase the files
                                      • SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt
                                      • SCFLicense_FredoCorner_this_computer.txt
                                      1. Redo the Validation procedure.
                                      Sorry for the inconvenience. This may be due to a change of your computer environment.
                                      • C
                                        Chisaina mamont
                                        Thanks, all worked well. Health to you and prosperity.
                                        • H
                                          helmanfrow
                                          Is there no one-time fee for just Fredo Spline? I don't want to pay a subscription!
                                            Yes, you buy and its yours. It has no subscription.
                                            • 115
                                            • 116
                                            • 5 / 116
