    New version quirks
    19 Posts 9 Posters 8.2k Views 9 Watching
    • pmolsonP Offline
      pmolson
      I have to report that my color picking tool is now working like it always has.
      I do not know why it would have changed after the update and then changed back a day later, but it did. Maybe a few re boots helped.
      Sorry for the ultimately baseless complaint.
      p
      • pmolsonP Offline
        pmolson
        Is there a way to roll back to the previous update? The one prior to version 21.1.299 64 bit.
        My color picker/paint bucket tool is now inconsistent. One time it works as it always has, the next time it hangs up with the eye dropper, sometimes it will not pick a color without clicking several times...
        I also do not like the way the move/copy tool works now.
        If any body can point me to how to roll back my version, I would appreciate it.
        • sfto1S Offline
          sfto1
          After reading this thread, I tried to see if I would have the same issues.
          Currently, the program is behaving as expected.
          SU 21.1.299 64 bit
          Windows 10 latest updates
            rv1974
            SU 21.1.299 64 bit
            Start Paint command, single Alt press to sample some material; Now, change your mind and try to sample another material (pressing single Alt without orbiting)- you won't be able to do that (to chose another mat).
            • pmolsonP Offline
              pmolson
              SU 21.1.299 64 bit
              I tried that and it worked fine for me.
              I have been having intermittent odd behavior. Today however, it seems to be working just like the old days. Makes me think the issue is with my setup and not with the update as I thought.
              p
              • sfto1S Offline
                sfto1
                SU 21.1.299 64 bit
                I tried this and it did glitch once, but all other times (half a dozen)in 2021 the tool seems to be working normal
                • gullfoG Offline
                  gullfo
                  besides the need to learn a new set of button presses combinations to turn "features" on and off (a real PITA if your used to holding the modification key while operating and then reverting), the constant "graying out" of the context menu and then later, even the edit->group or edit->component menus requiring a restart of the app. this latest version is very counter-productive (esp the latter menu graying nonsense).
                  Glenn
                  http://www.runnel.com
                  • pmolsonP Offline
                    pmolson
                    If the move tool and paint tool being spasmatic and graying out of contextual menus is operating as expected than I think expectations need to be adjusted.
                    This latest update is counterproductive.
                    Is there a way to roll back the version on my setup?
                    p
                    • troyhomeT Offline
                      troyhome
                      I've rolled back to the previous version. I cannot work with the new version. i'm not interested in pressing more keys to do the same stuff i used to. I would love the option to use SU as "legacy". Until then I'm not upgrading.
                      IOviz.com
                      SU Pro 2024 PC
                      • jujuJ Offline
                        juju
                        Which version are you actually using? Your post implies SU2020, your signature says SU2017 and your bio says SU2016?
                        • andybotA Offline
                          andybot
                          I just installed the latest SU update they rolled out today. The crtl+move stickiness is gone and it's back to the traditional behavior where you have to hold ctrl to copy. Yay! It's been bugging me ever since I installed 2021 a month or so ago.
                          • BoxB Offline
                            That behavior changed in a release about a month ago, the one today addressed some other issues.
                            Note that the toggle still works, they added back in the ability to hold it down. And a double tap of ctrl before you start turns on the repeat paste option.
                            • andybotA Offline
                              andybot
                              I may have missed an update, thanks for that clarification.
                              • jujuJ Offline
                                juju
                                Hmmm, new minor version released today?
                                Doing a version check on my SketchUp 2021 (version 21.1.332) says I have the latest version, also no newer version on the SketchUp Download URL either?
                                Am I missing something? Was something released and subsequently retracted again?
                                • pmolsonP Offline
                                  pmolson
                                  Whatever and whenever, it is better now.
                                  move and move copy behaves like the old days:)
