    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
      ak-sam
      Hello are there any updates on when this could be compatible with SU2020 & 2021?
        See: http://sketchucation.com/forums/viewtopic.php?f=323&t=56852&start=840#p656107
          pinyol
          Hi Anton,
          Any news on when you'll be able to release an updated version of this wonderful Plugin?
          Best,
          Juan
            kaoru_komine
            Hello.
            I have a question for the participants of this forum.
            I would like to use the videos I made with "mspysics" and "sketchup make" for commercial purposes, what do you guys do in such cases?
            If I have a "sketchup" license, am I not in violation?
            Or do I have to buy "sketchup pro 2017" somehow?
            I posted a question here because the terms and conditions of sketchup.com don't make sense to me.
            Please let me know what you think.
              maddiebeck
              Hi Anton,
              I am also awaiting the release of an SKU2021 compatible version of MS Physics..Can we expect to see this soon?
                The terms of use for SketchUp 2017 Make are clear that it may not be used for commercial purposes. Having a license for an older version of SketchUp does not change the EULA for Make. If you need more clarification on that you should seek legitimate legal counsel.
                At this stage it's not likely that Trimble would sell you a license for SU2017 Pro. It's long out of support and they don't sell licenses for unsupported versions. The current version for which they are providing licenses is 2021.
                • F Offline
                  faust07
                  Hello Anton,
                  I hope you are fine and as a programming and physics genius you have a lot to do ... 😉
                  My questions:
                  Is it feasible to make the existing (ingenious) MSPhysics compatible with SketchUp 2021 and what effort would that require?
                  SketchUp and Ruby API have changed a few times in the meantime.
                  Could outsiders with more or less programming knowledge help you? Possibly also financially.
                  You're working on a new version. Can someone help you with testing?
                  Otherwise, porting the last version v1.0.3 to SUp2021 would be very helpful, as you already have to keep 3 SketchUp versions:
                  SUp2016 32bit for Sketchy Physics, SUp2017Make for MSPhysics and the current SUp version for daily work.
                  I hope the users' interest in exercises and simulations on a physical basis for SketchUp does not wane.
                  Since SketchUp is only available in paid versions anyway and since more and more professional plugins are chargeable, this would also be conceivable for MSPhysics.
                  Well, moaned enough.
                  Best regards, Andreas
                  • 9 Offline
                    971jmd
                    hello
                    hi, i can't move the cart forward, do you have the skechup file to understand. thank you
                    [url]]https://youtu.be/s2XaEboPQ7g?t=731[/url]
                      What version of SketchUp are you actually using? Your profile says Pre-6.
                      • MaloXM Offline
                        MaloX
                        @utsav1110 said:
                        Can anyone help me with this simulation of multiple plastic bottles over a conveyor?
                        I need to know the flow of bottles over the conveyor. Whenever i run the simulation, it crashes.
                        Don't know the reason.
                        Also, if possible how can i model a simple flat belt that runs instead of this chain type belt. I have attached the file which i modelled in sketchup pro 2017.
                        Hello
                        ... traduction google ...
                        I have been on this forum for some time but I do not participate much ...
                        First of all, I wanted to thank "Anton_S" for the development of this plugin! Very good work !!
                        To answer utsav1110, I think it is not possible to make a rolling strip (soft belt) in MSPhysics. It is necessary to go through the production of a chain, with pivot type connections.
                        Your file crashed, I don't know why, it happened myself, solution: copy all the elements into a new Sketchup file and reset the simulation parameters (speed, pass, etc.). Closing and reopening the file from time to time avoids some slowness and crashes.
                        I have modified your file (attached), a little on the modeling but especially on the configuration of the elements and the connections. It works, I think plastic bottles can be improved. MSPhysics parameters are very precise (and that's fine) so handle with care.
                        Thank you again to you "Anton_S"
                        Good luck to all
                        plastic bottle conveyor
                        • SwissmountainS Offline
                          Swissmountain
                          Hi Anton,
                          thank you for your useful plugin!
                          I often use it for destruction sets, to skatter piles of debris here and there or fracture objects and drop the shards organically.
                          I just realized it doesn't work in SKP2020, I am so bummed!!!
                          It looks like there was a hope for MSphysics2 to be released in July 2020 and I would love to know if we can still hope for it to be released in the foreseeable future.
                          I'd be absolutely willing to pay for this plugin by the way or financially support its development.
                          Thank you!
                          Cogito ergo dum-di-dum
                          • O Offline
                            oheimala
                            Hi Anton,
                            For me, as a professional designer of pontoon docks, a reliable physic simulator for such floating items would be extremely useful. Our company is also ready to pay for it;just like we pay for other professional software too.
                            Cheers,
                            Olli
                              Anton_S
                              @oheimala said:
                              Hi Anton,
                              Cheers,
                              Olli
                              @swissmountain said:
                              Hi Anton,
                              Thank you!
                              I hear you guys. I will put the effort this rainy November to revamp the plugin. MSPhysics will be free since I am using an external physics engine, but some of the features that I come up with will require a license. That way I could make some profit from the time I invest in the product. Have a great weekend!
                              • MaloXM Offline
                                MaloX
                                @cristyan said:
                                Hello ! How can i connect these sliders ( or can be a piston joint )in a way that if I move one the other will move in the opposite direction or to affect its position (without connecting them directly). Thank you!
                                Hi Cristyan
                                There is very little info in your request ... and I don't see an answer to your problem on this post ... so I interpreted your problem ...
                                You didn't want a "physical" connection between the two elements, but an opposite movement interaction.
                                I think I did the job (Anton, tell me if it's okay), tell us Cristyan if that's what you wanted.
                                The keys to operate the cursors are left / right arrow. (The script is in the "PR" block)
                                When the left and right arrow keys are pressed at the same time, the cursor returns to the middle.
                                The central objects (in pink) have a different and automatic script, that could help you ...
                                File edit as link, tell me if that's what you were looking for.
                                A + the team
                                A + Anton
                                PS: google translation
                                Malox
                                (In french, parce qu'il y a des francais)
                                Salut Cristyan
                                Il y a très peu d'info dans ta demande ... et je ne vois pas de réponse à ton problème sur ce post ... donc j'ai interprété ton problème ...
                                Tu ne voulais pas de connexion "physique" entre les deux éléments, mais une interaction de mouvement opposée.
                                Je pense que j'ai fait le taf (Anton, dis-moi si c'est correct), dis-nous Cristyan si c'est ce que tu voulais.
                                Les touches pour actionner les curseurs sont flèches gauche/droite. (Le script est dans le bloc "PR")
                                Quand les touches "flèche" gauche et droite sont actionnées en même temps, le curseur revient au milieu.
                                Les objet centraux (en rose) ont un script différent et automatique, cela pourrai t'aider ...
                                Fichier modifier en lien, dis-moi si c'est ça que tu recherchais.
                                A+ l'équipe
                                A+ Anton
                                Malox
                                connected slider_Malox
                                • F Offline
                                  faust07
                                  That sounds great!
                                    keamoge
                                    Hi Anton.
                                    MSPHYSICS is a very terrific tool. Perfect and perfect tool for us teachers. However, we are in trouble because it cannot work with current 2021 Sketchup Pro.
                                    Do you have any plans of updating this tool so that it works in the current sketchup even if it means turning it into a paid version. We will pay to have this plugin. It is super useful
                                      AISmebel
                                      @anton_s said:
                                      @oheimala said:
                                      Hi Anton,
                                      Cheers,
                                      Olli
                                      Hi Anton,
                                      Thank you!
                                      Hello. We are looking forward to it)))
                                      Thank you for your plugins, they are very cool 👍
                                      • N Offline
                                        N Lindenthal
                                        Klappe 90 Grad
                                        Klappe 90 Grad
                                        Hallo Anton und hallo an alle hier:
                                        Mein Modell Klappe4hinges.skp ist zugegebenermaßen jetzt in Unordnung. Es war schon besser eingestellt. Aber ich habe noch nicht den Überblick, welche wenigen Einstellungen unbedingt richtig sein müssen, damit eine einfache mechanische Betätigung meiner Klappe abläuft.
                                        Zwei größere Teile sollen durch zwei kleinere Knochen und 4 MSPhysics-Gelenke zueinander 90 Grad gestellt werden. Ich frage mich aber, ob 4 Gelenke an 4 Teilen überhaupt berechnet werden können. Jedenfalls schaffe ich es nicht, die Einstellungen richtigzustellen.
                                        Wer kann mir helfen?
                                        Hello Anton and hello to everyone here:
                                        Admittedly, my model Klappe4hinges.skp is now in disarray. It was adjusted better. But I still don't have an overview of which few settings absolutely have to be right for a simple mechanical operation of my flap to take place.
                                        Two larger parts should be placed at 90 degrees to each other by two smaller bones and 4 MSPhysics joints. But I wonder if 4 joints on 4 parts can be calculated at all. Anyway, I can't get the settings right.
                                        Who can help me?
                                        • ecatiE Offline
                                          ecati
                                          Is that what you want?
                                          Click on picture for animation.
                                          Klappe4hinges_ecati.skp
                                          • N Offline
                                            N Lindenthal
                                            Oh, thank you, yes, this is, what I want.
                                            In my tests the moving parts allways were restless unsteady.
                                            What did you set in the MSPhysics settings??
                                            Sorry, now I see your model.
                                            … and I opened it with SketchUp Make 2017 and MSPhysics 1.0.3
                                            When I toggle start, the shorter bone falls down and also more parts beginn to be restless.
                                            How did you get the restfull moving in your little film?
                                            How can I look for the differences between yours and my model?
                                            Thank you, that you gave me back my trust, that MSPhysics will move my model!!
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 45 / 47
