    Some tips and tricks from out of the Box
    203 Posts 20 Posters 242.3k Views 20 Watching
    • BoxB
      Here's a pretty simple twilight render of a basic scene animation. Two components, 17 scenes, odd number because it loops.
      • HornOxxH
        HornOxx
        @gd3design said:
        ...Every time I check this thread, I either learn something new or realize a different way to approach a problem. Thanks for sharing, Box!
        So do I πŸ‘ πŸ‘
        never trust a skinny cook
        • BoxB
          Here's a dose of Fredo.
          Curved wall framing for windows.
          https://i.imgur.com/tRG8zEU.gif
          • HornOxxH
            HornOxx
            πŸ‘ πŸ‘ Thanks! an extremely instructive Dose of Fredo video! Everything 3D is generated from this "curved sheet of paper" πŸ˜„
            • BoxB
              I did miss one pane of glass though, so it will be a bit drafty.
              • BoxB
                Some things in Sketchup aren't immediately obvious, one is that when you use the 'Hide Rest of Model' option, you can still intersect faces with things that aren't visible.
                https://i.imgur.com/EsOhh7U.gif
                • BoxB
                  Here's a little tip for making all those fancy railing fences.
                  Note: I'm using keyboard shortcuts for copy and paste in place.
                  https://i.imgur.com/TxSrwOA.gif
                  • tuna1957T
                    tuna1957
                    Bravo ! The Box goodness never ends πŸ‘
                    • BoxB
                      Here's a Sunday doodle
                      and the method used to make it.
                      https://i.imgur.com/DQwkN8l.gif
                      • HornOxxH
                        HornOxx
                        ...toll toll toll! πŸ‘ πŸ‘
                          Simple is beautiful! β˜€
                          • BoxB
                            Some pipes and the basic method used to make them.
                            https://i.imgur.com/2UOLV8d.gif
                            • BoxB
                              Tig's excellent Grow plugin makes creating tapering dots very simple.
                              • G
                                Glenn at home
                                LOL, nice exhaust header tutorial, great stuff! I just had some installed on my car last week. I should have took a shot at designing my own πŸ˜‰
                                Thanks for sharing.
                                • BoxB
                                  A little something for people using the web version or deliberately avoiding extensions.
                                  There are various extensions that can be used to draw spirals but it is useful to know how to draw them manually. By using offset on a square I can layout the number and size of the rotations I want. Then join the midpoints with 'half circles'. Watch for the inference either Tangent if the arc is the right way around or Half Circle if you need to make it go the other way.
                                  • BoxB
                                    A tip for people using Truebend and wondering about the hole in the middle. It can easily be filled with a circle using the same number of segments as used in the bend. An edge drawn between two opposite vertices will give you a midpoint from which to draw your circle. Here you can see I've used inferencing to create the edge needed.
                                    https://i.imgur.com/w5FzBzH.gif
                                    • BoxB
                                      Split is a great tool when you want to make a shape that is basically the junction of two other shapes. Split will divide two shapes into their component parts rather than removing the one or the other or the bits that join. This keeps that bit that is often discarded.
                                      I should point out that the Intersect Option is the correct tool for this result. I usually use split though because I tend to want the other pieces too.
                                      https://i.imgur.com/EMjyb3o.gif
                                      • BoxB
                                        This is a better example of how to use the split tool, it lets you pick and choose which parts you want to keep.
                                        https://i.imgur.com/Mj388pM.gif
                                        • BoxB
                                          This is a tip mostly for 3d printing.
                                          When creating solids Thomthom's Solid Inspector is a brilliant tool, but sometimes it doesn't find and fix all the errors leaving you with a non solid and no real clue as to what the issue may be.
                                          Anton S' very handy Fixit101 can often find and fix the missing issues for you. I must admit it is one of my most used, most liked extensions.
                                            Good to know! πŸ‘
                                            • 11
                                            • 7 / 11
