    Some tips and tricks from out of the Box
    203 Posts 20 Posters 242.3k Views 20 Watching
    • BoxB
      Here's a simple knife using Autofold to give the blade shape.
      https://i.imgur.com/ECDkeCO.gif
      • BoxB
        Using a .png image as a texture is a handy way of faking detailed geometry.
        https://i.imgur.com/qlifXdA.gif
        • BoxB
          Here's a simple method for making low poly vent louvers.
          https://i.imgur.com/woHS703.gif
          • bazB
            baz
            I Lurve a Louvre.
            Nicely done.
            Cheers Baz.
            PS: You don't need to get out more?
            • BoxB
              One of the many useful tools that people often miss amongst all of Fredo's wonders is the Convert to Arc/Circle (part of Curvisard) that puts arcs and circles back together so the Cardinal points function.
              Follow me explodes Arcs and Circles and if you weld them they become Curves, which don't have the special feature that is Cardinals.
              https://i.imgur.com/sH3nTyp.gif
              • GD3DesignG
                GD3Design
                Every time I check this thread, I either learn something new or realize a different way to approach a problem. Thanks for sharing, Box!
                • BoxB
                  That's good, I'm glad a few people get something out of my ramblings.
                  • BoxB
                    Here's a pretty simple twilight render of a basic scene animation. Two components, 17 scenes, odd number because it loops.
                    • HornOxxH
                      HornOxx
                      @gd3design said:
                      ...Every time I check this thread, I either learn something new or realize a different way to approach a problem. Thanks for sharing, Box!
                      So do I πŸ‘ πŸ‘
                      never trust a skinny cook
                      • BoxB
                        Here's a dose of Fredo.
                        Curved wall framing for windows.
                        https://i.imgur.com/tRG8zEU.gif
                        • HornOxxH
                          HornOxx
                          πŸ‘ πŸ‘ Thanks! an extremely instructive Dose of Fredo video! Everything 3D is generated from this "curved sheet of paper" πŸ˜„
                          • BoxB
                            I did miss one pane of glass though, so it will be a bit drafty.
                            • BoxB
                              Some things in Sketchup aren't immediately obvious, one is that when you use the 'Hide Rest of Model' option, you can still intersect faces with things that aren't visible.
                              https://i.imgur.com/EsOhh7U.gif
                              • BoxB
                                Here's a little tip for making all those fancy railing fences.
                                Note: I'm using keyboard shortcuts for copy and paste in place.
                                https://i.imgur.com/TxSrwOA.gif
                                • tuna1957T
                                  tuna1957
                                  Bravo ! The Box goodness never ends πŸ‘
                                  • BoxB
                                    Here's a Sunday doodle
                                    and the method used to make it.
                                    https://i.imgur.com/DQwkN8l.gif
                                    • HornOxxH
                                      HornOxx
                                      ...toll toll toll! πŸ‘ πŸ‘
                                        Simple is beautiful! β˜€
                                        • BoxB
                                          Some pipes and the basic method used to make them.
                                          https://i.imgur.com/2UOLV8d.gif
                                          • BoxB
                                            Tig's excellent Grow plugin makes creating tapering dots very simple.
                                            • 11
                                            • 7 / 11
