    Some tips and tricks from out of the Box
    203 Posts 20 Posters 242.3k Views 20 Watching
    • BoxB
      Some things in Sketchup aren't immediately obvious, one is that when you use the 'Hide Rest of Model' option, you can still intersect faces with things that aren't visible.
      https://i.imgur.com/EsOhh7U.gif
      • BoxB
        Here's a little tip for making all those fancy railing fences.
        Note: I'm using keyboard shortcuts for copy and paste in place.
        https://i.imgur.com/TxSrwOA.gif
        • tuna1957T
          tuna1957
          Bravo ! The Box goodness never ends πŸ‘
          • BoxB
            Here's a Sunday doodle
            and the method used to make it.
            https://i.imgur.com/DQwkN8l.gif
            • HornOxxH
              HornOxx
              ...toll toll toll! πŸ‘ πŸ‘
              never trust a skinny cook
                Simple is beautiful! β˜€
                • BoxB
                  Some pipes and the basic method used to make them.
                  https://i.imgur.com/2UOLV8d.gif
                  • BoxB
                    Tig's excellent Grow plugin makes creating tapering dots very simple.
                    • G
                      Glenn at home
                      LOL, nice exhaust header tutorial, great stuff! I just had some installed on my car last week. I should have took a shot at designing my own πŸ˜‰
                      Thanks for sharing.
                      • BoxB
                        A little something for people using the web version or deliberately avoiding extensions.
                        There are various extensions that can be used to draw spirals but it is useful to know how to draw them manually. By using offset on a square I can layout the number and size of the rotations I want. Then join the midpoints with 'half circles'. Watch for the inference either Tangent if the arc is the right way around or Half Circle if you need to make it go the other way.
                        • BoxB
                          A tip for people using Truebend and wondering about the hole in the middle. It can easily be filled with a circle using the same number of segments as used in the bend. An edge drawn between two opposite vertices will give you a midpoint from which to draw your circle. Here you can see I've used inferencing to create the edge needed.
                          https://i.imgur.com/w5FzBzH.gif
                          • BoxB
                            Split is a great tool when you want to make a shape that is basically the junction of two other shapes. Split will divide two shapes into their component parts rather than removing the one or the other or the bits that join. This keeps that bit that is often discarded.
                            I should point out that the Intersect Option is the correct tool for this result. I usually use split though because I tend to want the other pieces too.
                            https://i.imgur.com/EMjyb3o.gif
                            • BoxB
                              This is a better example of how to use the split tool, it lets you pick and choose which parts you want to keep.
                              https://i.imgur.com/Mj388pM.gif
                              • BoxB
                                This is a tip mostly for 3d printing.
                                When creating solids Thomthom's Solid Inspector is a brilliant tool, but sometimes it doesn't find and fix all the errors leaving you with a non solid and no real clue as to what the issue may be.
                                Anton S' very handy Fixit101 can often find and fix the missing issues for you. I must admit it is one of my most used, most liked extensions.
                                  Good to know! πŸ‘
                                  • BoxB
                                    I've neglected this thread lately so,
                                    A little truebend and twilight for some 'different' Chrissy decorations.
                                    • bazB
                                      baz
                                      Nice. I am tempted to print,(2d), a couple out and hang em on a stick.
                                      • BoxB
                                        My first test of Fredo's Animator, what a great tool.
                                        So much more to learn.
                                        https://i.imgur.com/FRhpy2L.gif
                                        • HornOxxH
                                          HornOxx
                                          great! - and what a beautiful mechanical study on top
                                          • ntxdaveN
                                            ntxdave
                                            That is really great Box. Would be a great one for one of your informative tutorials!
                                            Press F1...thank me later
                                            • 11
                                            • 8 / 11
