    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 402.6k Views 80 Watching
    • simjoubertS Offline
      simjoubert
      Hello and thank you for this plugin which will facilitate and improve the transition from modeling to customer presentation!
      The number of plugins in my toolbar has grown without my being able to get rid of a single one! Can you imagine saving different toolbar configurations to switch from one working environment to another depending on the state of play of the model. Modeling, texturing, Animation, Render, ...
      thanks again
      Bonjour et merci pour ce plugin qui va faciliter et améliorer le passage modélisation à la présentation client !
      Le nombre de plugins dans ma barre d'outils grossi sans que je puisse me défaire d'un seul ! Pouvez vous imaginer l'enregistrement de différente configurations de barre outils pour passer d'un environnement de travail à un autres selon l'atat d'avancement du modèle. Modélisation, texturing, Animation, Render,...
      Merci encore
        DanBie
        Great. Good job! 😄
          RoCas777
          I have installed the plugin on SketchUp but I can't find the toolbar or the settings on Extensions menu or anywhere else 😞 😞 anyboydy had the same trouble and know how to fix it???
          Cheers!
            Read the first post in this thread. It clearly states it does not work on Mac.
            It also indicates that in the Extension Store entry.
            • Y Offline
              yinliangxxxx
              Thank you Anton_S, I’m very sorry for my poor English, I can only use Google Translate to communicate, may I consider adding a multi-language library, it is convenient for other countries’ plug-in lovers to translate your plug-in, thank you again
              • E Offline
                eseraphim
                Hi Anton, I was used AMS window settings but just upgraded to Fullscreen and SketchUp 2021.
                In SketchUp 2020 I had to shortcuts mapped -- one hid everything and went fullscreen and the other restored my window back to my working space -- it worked perfectly. However, I seem to be unable to do the same workflow with your latest update? Trays do not seem to want to show/hide whenever I apply saved settings, I have to check "trays and dialogs" to bring them back no matter what even if they are supposed to disappear as part of the saved settings -- additionally, I set a shortcut key to the apply saved settings, but it doesn't seem to do anything. Am I missing something? thank you for the help.
                  awadrummer
                  I love the plugin, but I was wondering if it would be possible to have Sketchup save the toggle for floating toolbars. I have to hide the floating toolbars manually every time I restart Sketchup even though I use Fullscreen to hide them and click the save and check the "Apply Saved On Start" option.
                  Thank you!
                  Chris B.
                    gianlucaf
                    @awadrummer said:
                    Thank you!
                    Chris B.
                    Apparently I have the same problem, or maybe I don't quite understand how it works.
                    Still a great help.
                      rv1974
                      Try Fredo LOTT
                        Anton_S
                        @gianlucaf said:
                        @awadrummer said:
                        Thank you!
                        Chris B.
                        Still a great help.
                        Please update to version 5.1.0, where floating toolbars and dialogs are shown/hidden along with saved state.
                          joerg
                          Bug: If you skip to the next scene with a shortcut, than its skipping 2 scenes in one step. Same thing backwards. (SU 2021 pro)
                            Anton_S
                            Interesting find. Does that occur with the menu bar hidden or even with the menu bar visible?
                            Edit: I can reproduce the bug with the menu bar hidden. Working on a fix.
                              joerg
                              Hi Anton,
                              Thanks for your quick reply! As you suspected, the error only happens when the menu bar is hidden.
                              A fix would be great! Thank you for the effort.
                              • fredo6F Offline
                                If te menu bar is truly hidden (at Windows level), then NO custom shortcut will work.
                                What I do in LOTT is to increase the size of the Sketchup window so that the menu bar is outside the screen.
                                  Anton_S
                                  In fullscreen, I read all the sketchup shortcut and have my own keyboard WM_KEY_DOWN message handler which triggers the associated commands when the menubar is hidden.
                                  As an alternative, with regards to moving the window above, I believe you can get the height of the menubar and then use SetWindowPos with start position to be negative menubar height and and height to be screenheight + menubar height.
                                  To get menubar height: https://docs.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-getmenubarinfo?redirectedfrom=MSDN
                                    Anton_S
                                    @joerg said:
                                    Hi Anton,
                                    Updated!
                                      LeoHominis
                                      Essa extensão é uma das melhores que eu já baixei, colocando atalhos de teclado nela fica uma delicia o ambiente. Muito obrigado e parabéns por tornar o SketchUp MELHOR. 👊 👊 😎
                                      • designerbursaD Offline
                                        designerbursa
                                        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/ams_windowsettings/imagesui.png
                                          Anton_S
                                          Why am I getting this error in ruby console?
                                          It's a console log. Forgot to remove. Not an error.
                                            rv1974
                                            Anton could your tool apply dark theme to SU's UI elements? I'm so tired of this white\light grey
                                            Thank you
                                            • 14
                                            • 15
                                            • 6 / 15
