    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.1k Views 110 Watching
    • EdsonE Offline
      Edson
      hi juju,
      no, the setup is the same as before. but I am on mac so the fact that it is working for you does not mean much in this case.
      thanks.
      http://www.mahfuz.arq.br
      • Rubber DuckyR Offline
        Rubber Ducky
        I am also having this problem and am also on a Mac. The main panel simply will not show on my computer screen. This plugin worked well for several months before the main panel disappeared. I have also uninstalled and reinstalled the plugin. Near as I can tell, the panel "thinks" it is showing properly. The Mac version of Sketchup doesn't have any kind of "show all panels onscreen" sort of command.
        Layers Panel was a very useful plug-in while it worked. If anyone has a suggestion for fixing this problem, pleas post it.
        • EdsonE Offline
          Edson
          I am afraid our complaints will reach a dead end as the author of this extension is no longer developing nor mantaining it. pity. it showed great promise.
          perhaps someone would take it up and fix it.
            resmas
            Amazing plugin mate, great work.
            SU should implement it by default.
            I have a request, cna you add Octane Render support?
            I use Octane to render my work, and would be a charme if i had the Octane layer option.
            You can find more information in here.
            404 Not Found
            (sketchucation.com)
            cheers
            resmas
            all the best to you, and one mote time a big thanks πŸ˜‰
              art3mii
              Hello!
              When i push "R" on layer Panel, error: "Vray is not installed jn this system? or is disabled"
              what am I doing wrong?((
              SU pro2017 17.2.2555 64bit + V-Ray 3.60.03 Trial.
              • jiminy-billy-bobJ Offline
                jiminy-billy-bob
                Layers Panel is quite old, I don't think it works with V-Ray 3, sorry.
                  RubenB
                  I know this is an old thread and no one has posted any changes to the open source code. Sure would be nice if someone would take up the task of updating this to SU 19 and adding support for line types. Sure heat to give up this tool but without line type support it's pretty much useless now, Quite the shame sense this layer manager is so much better than the SU layer tool
                    jiminy-billy-bob
                    There is a new plugin based on Layers Panel: https://extensions.sketchup.com/sv/content/layers-organizer
                      arquibaires
                      HOW CAN I ALPHABETICALLY ORDER THE LAYERS IN THE PLUGIN LAYERS PANEL?
                      THANKS
                        samodelkin_77
                        THANKS
                        you can find the link on page 1 ))
                        By the way, guru in Ruby, please tell me how to add a little code so that you can change the name of the layer by pressing F2 ?
                        ((Now it works by double-clicking, I'm more familiar with F2, and I can't substitute an addition and a check for F2 in the code in any way-it doesn't work out = little experience)
                          PropertyToday
                          Hello.
                          I have some problem with layer panel plugin v 1.2.2 (Thomas Hauchecorne)
                          Sometimes, all groups disappear and all layers appear in one row with no groups. Do you know this bug? Do you know how to deal with it. Is it possible to restore groups or do we have to build the entire group structure from the begining? Adam
                          • X Offline
                            xongchaksin
                            Extension Errors Report
                            SketchUp: 26.1.252
                            OS: Windows 11
                            Ruby: 3.2.2
                            Extension: Layers Panel (1.2.2)
                            Error: LoadError (cannot load such file -- Win32API)
                            <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require' <internal:C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in require'
                            C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:21:in <module:JBB_LayersPanel>' C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel/layers_panel.rb:5:in <top (required)>'
                            C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:197:in load'
                            C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:51:in register_extension' C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:51:in module:JBB_LayersPanel'
                            C:/Users/thana/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/jbb_layers_panel.rb:35:in `<top (required)>'
                            • 30
                            • 31
                            • 32
                            • 33
                            • 34
                            • 34 / 34
