    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F Offline
      Could you send me the offset.rb file that is mentioned
      C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:56:in `offset'
      I don't know what it is but it may cause a conflict.
        rv1974
        some info:
        http://www.smustard.com/script/Offset
        Please download the updated offset.rb from there.
        After I updated the offset.rb from the link above the error message slightly changed:
        Error: #<ArgumentError: wrong number of arguments (given 2, expected 1)>
        C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/offset.rb:149:in offset' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2793:in close_loop_by_Bezier'
        C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2049:in call_compute_curve' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/bezierspline/bezierspline_main.rb:984:in draw'
        • fredo6F Offline
          You should definitely disregard this plugin.
          It redefines base methods for native Sketchup objects (Face, Array, ...). So it causes conflicts with other plugins, among which mine. There is nothing I can do about it.
          By the way, this offset.rb is a library to be used by other plugins or extensions. Which one requires offset.rb?
            rv1974
            at least this one:
            https://sketchucation.com/forums/viewtopic.php?f=180&t=14095
            damn.. from 2008 (sketchup 6) .. I have to put it down with heavy nostalgia.
            • fredo6F Offline
              @rv1974 said:
              at least this one:
              I publish a fix with version BezierSpline v2.1b.
              But, frankly, offset.rb should be avoided, because it redefines methods in base classes of Sketchup Ruby.
              • fredo6F Offline
                NEW RELEASE 2.1b - 14 Apr 21
                This release prevents a conflict with offset.rb (RickW).
                More info at main post
                Download BezierSpline at Sketchucation Plugin Store
                  rv1974
                  Huge thank you Fredo!
                  I assume PB assembly problem is not at your end, is it?
                  PS I said good-buy to windowizer 4+offset, thank you for pointer.
                  PPS Some F3 for 'done and exit'- not this time?
                    DarthKeidran
                    I don't know if you're updating this to work with Sketchup 2021 (Running macOS Big Sur), but the only functions of this plugin I can use are "Classic Bezier Curve", "Polyline", "Catmull Spline", "F Spline", and "Courbette". From tutorials I can find, the other tools are supposed to bring up a Parameters dialogue box (or contextual menu based on what the Rubi Console says), which I can't get to appear no matter what I try.
                    A good example of this is the action in this sketchup discussion: https://forums.sketchup.com/t/divide-existing-arc-into-equal-segments/74870/2
                    I, more specifically, am trying to get an ellipse with equally sized segments as is demonstrated with your tool in this sketchup discussion: https://forums.sketchup.com/t/elliptical-array/17102/13
                    If you have any suggestions to fix this, let me know please.
                    DarthKeidran.
                    • fredo6F Offline
                      NEW RELEASE 2.2a - 22 Apr 21
                      This release improves performance for selection contextual menu.
                        R0bBot
                        Is there any way to turn off the "double shift" feature? Im not sure the technical term but how the curve's controls changes when pressing shift twice. Im not sure how to remove that feature since its more of a nuisance than an addon
                        • E Offline
                          elviocb
                          Toolbar Icons are really small on Sketchup 2022. Any plans to update it?
                          • fredo6F Offline
                            No Plan....
                            Except if someone provides me with icons in size 128x128.
                              atrodler
                              re:Bezier spline
                              is there a way to use the convert feature on more than 1 line/polyline segment at a time? I convert topo lines to equally divided lines using the bezier spline toolbar but can only run the "convert to" command on one line at a time. Can be tedious and timely. is there a batch process / command to convert multiple lines/polylines in one execution?
                              • fredo6F Offline
                                Not with BezierSpline, but possible with FredoSpline.
                                • 19
                                • 20
                                • 21
                                • 22
                                • 23
                                • 23 / 23
