    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
    • B
      bsfranza
      hey there,
      i have a problem, the fredo corner toolbar does not show up?!
      in the extension manager its shown, also in sketchucatino licence manager etc, plugin manager, .. its tehre everywhere but i cant get the "toolbar" or menue items to show up?! also removing the plugina and reinstalling from rbz dos not help :I
      im running the latest su 2021..
      any help much appreciated,
      best, bsfranz
      • fredo6F
        Did you install the companion library LibFredo6?
        • B
          bsfranza
          oh silly me :I .. sorry for stealing your time - i have installed the library now it works as expected...
          thx
          • B
            Buckyman
            @fredo6 said:
            The errors comes from the rounding of the upper part and the large offset.
            Currently FredoCorner does not round edges when one of the edge has a length smaller than the offset.
            So, it works with an offset of 2'', but not beyond.
            PS: RoundCorner does not do a better job
            Yes I did see success with 2", and I did try RoundCorner
            Thanks for your quick response and all your great plugins 😄
            • NJDesignN
              NJDesign
              I am getting a Ruby console error when I try to round these corners. Can you tell me what is wrong?
              -Never mind. I found a way around it.
              screenshot
              skp file
              Ce qui mérite d'être fait mérite d'être bien fait.
              • NJDesignN
                NJDesign
                Since I purchased the license I keep getting Ruby code errors. I have not managed to use the plugin successfully. Here is an example of the errors I get:
                Date: 20-Mar-21 13:51:43
                An error occurred in FredoCorner
                An error occured in the Ruby code
                undefined method `[]' for nil:NilClass
                fredocorneralgo.rbe:: 2618 -- chemin_analyze_crossing
                fredocorneralgo.rbe:: 2421 -- brane_intersect_chemins
                fredocorneralgo.rbe:: 2060 -- block in catena_process_branes_protected
                fredocorneralgo.rbe:: 2047 -- each
                fredocorneralgo.rbe:: 2047 -- catena_process_branes_protected
                fredocorneralgo.rbe:: 2009 -- block in catena_process_branes
                fredocorneralgo.rbe:: 2008 -- catch
                fredocorneralgo.rbe:: 2008 -- catena_process_branes
                fredocorneralgo.rbe:: 965 -- block in solid_construct_branes
                fredocorneralgo.rbe:: 964 -- each
                fredocorneralgo.rbe:: 964 -- solid_construct_branes
                fredocorneralgo.rbe:: 919 -- block in solid_reconstruction
                fredocorneralgo.rbe:: 918 -- each
                fredocorneralgo.rbe:: 918 -- solid_reconstruction
                fredocorneralgo.rbe:: 883 -- solid_add_remove_edges
                fredocornertool.rbe:: 1845 -- selection_change
                fredocornertool.rbe:: 1833 -- selection_add_remove_edges
                fredocornertool.rbe:: 1856 -- selection_set
                fredocornertool.rbe:: 1538 -- block in preselection_instantiate
                fredocornertool.rbe:: 1535 -- each
                fredocornertool.rbe:: 1535 -- preselection_instantiate
                fredocornertool.rbe:: 1530 -- preselection_analyze
                fredocornertool.rbe:: 766 -- true_activate
                fredocornertool.rbe:: 751 -- block in activate
                lib6plugin.rbe:: 1568 -- tem_context
                fredocornertool.rbe:: 751 -- activate
                fredocornertool.rbe:: 194 -- select_tool
                fredocornertool.rbe:: 194 -- launch
                fredocornertool.rbe:: 176 -- action__mapping
                lib6plugin.rbe:: 129 -- call
                lib6plugin.rbe:: 129 -- launch_action
                lib6plugin.rbe:: 227 -- launch_action
                bootstrap_fredocorner.rbe:: 103 -- launch_action
                bootstrap_fredocorner.rbe:: 118 -- block in startup
                lib6plugin.rbe:: 1347 -- command_invoke
                lib6plugin.rbe:: 1328 -- block (2 levels) in build_config_commands
                lib6traductor.rbe:: 1377 -- block in add_command
                • fredo6F
                  Depending on the model, FredoCorner may get into error.
                  So the best would be to PM me or post the model so that I have a look.
                  PS: This has nothing to do with the license. The error is in the algorithm.
                  • B
                    Brickokermis
                    Like many people around the world, I was surprised that Fredo plugins went from free to paid. This is absurd!
                    Having plugins that have been free for decades and that are quietly going from free to paid, I don't know what quality could I give to this maneuver ...
                    Yesterday evening I saw, in an instant, the error message indicating "trial version finished", I thought it was April Fool's Day a little too fresh, but not when I got to the download page that it was not my astonishment when I saw that it was paying, whereas it was free just before. it's a very, very stupid operating system!
                    I have absolutely nothing against people who are looking for a return on investment. But the way to do it is not possible!
                    Inform people, take opinions, etc.
                    Especially that, 15 days ago when I updated I did not see that it was paid, since it is not displayed on the list of the plug-in store.
                    Another thing, buying it will not be a problem for me, if I have to I would buy it. But not individually, at 22 € / plug-in it's very, if not too expensive.
                    Make a pack of all plugins, or in this case lower the price from 10 to ~ 12 € / plug-in
                    22 € x (number of plugins) = too expensive.
                    Sketchup is starting to take the path of software that is losing value, already that the license is very expensive, if even the plug-ins are not affordable, Sketchup is losing more and more credibility, and that I have read on hundreds of forums around the world about the Fredo plug-in which switched to the Pay system
                    Do not forget, behind there is Blender much more efficient, Open Source, with a more family interface that allows you to learn faster than before. At this speed it's soon the end of Sketchup
                      Fredo didn't just quietly spring this change on the world yesterday. It was announced months ago that some of his extensions would be changing to requiring paid licenses. It's a one time license fee for each extension and includes the updates as they come along. You aren't being forced to purchase the license for FredoCorner. You can choose to use RoundCorner instead. There's still no charge for that one.
                        rv1974
                        @Brickokermis: 22€ per plugin is not too cheap, but lets suppose you used some of (now commercial) Fredeo plugins for 10 years in the past and will continue to use it for additional 10 years in the future; this is approx 1€/year. Just think about it.
                        P.S. I'd agree though that bundle would be much more user-friendly format.
                        • G
                          grigorescustelian
                          👎 It used to be free... At least let us use our old versions, why do you have to make them expire?
                            @grigorescustelian said:
                            At least let us use our old versions...
                            You can still use RoundCorner without paying for it.
                              Aroundthebend
                              Hi, I'm having trouble validating the licence. I keep getting this message:
                              Sorry - An error occured in the communication with Sketchucation
                              I've checked I've got the up-to-date Plug-in:
                              ExtensionStore v4.0.0
                              FredoCorner 3.2
                              LibFredo 11.6a
                              Screen Shot:
                              • fredo6F
                                Are you connected to the Internet when doing the validation?
                                  Aroundthebend
                                  I am, still no luck!
                                    Are you still using SketchUp 2017 as indicated in your profile? What version of the Mac OS?
                                    • G
                                      GoatmanZ
                                      Two things. One the plug in is GREAT. Second, mine seems to have expired. I have NO problem with paying for a perpetual license but there is NO way I can find, to pay! I NEED the plugin but it won't install. Or at least appear for me to use. The sketchUcation extension manager says it's installed but I keep getting errors and it doesn't appear for me to use. Help!!! I have the latest version of the Fredo6 library installed.
                                      • fredo6F
                                        @GoatmanZ
                                        When FredoCorner expires, it displays a dialog.
                                        Just click on the button Manage License. You get this dialog (accessible also from the menu Tools > Fredo6 Collection > FredoCorner > License....
                                        The just click on Obtain License to get to the Purchase page.
                                          Aroundthebend
                                          Yes; still using SU pro 2017 on Mac OS X 10.11.6
                                          • E
                                            elfis
                                            There is tax in the checkout, in my country we use vat so I should be charged with no tax for sale outside US or be able to claim vat. For now price is more the 30$. Can you advice. Thanks
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
