    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 674.6k Views 151 Watching
      LEGOsketcher
      re: seat limit and licenses
      God day, I am The LEGO companies Sketchup admin and wonder would like to include the latest Fredocorner release to our plugin collection.
      The company scripts a SU package with plugins included, Sketchucation should not be part of the basic package as most users won't use the Sketchucation plugins and it adds a level of complexity. Some users might use FredoCorner, most not. (maybe 5 -15 users)
      I wonder how to best approach the licensing issue as it will be hard administer individual seats / usage. Would that mean I need to install the SUcation plugin and seat license for the users that actually need Fredo corner? I'm also worried about budget for individual seats run up compared to the SU budget. They might ask me to find an alternative if the setup is too complex/time consuming.
      Will there be something like a studio license so I can avoid individual seats or floating licenses?
      Feel free to PM me, looking forward to hearing from you
        mwkinley
        Loving this plugin but my trial has expired and I can't buy the license...any tips?
        I have tried uninstalling , restarting , downloading again but of course it remembers the trial version had expired...all I get is this when I click on 'manage license'.
        Any help greatly appreciated.
        Matt
        • fredo6F Offline
          Could you reinstall the Sketchucation Tools v4.0.0.e.
          There must be something wrong in its current installation (most likely out of date).
          Please advise if it does not solve the problem.
            mwkinley
            Fixed, thankyou Fredo.
            I will buy the license now!
            Regards
            Matt
              Buckyman
              I am getting Ruby error when I try to round corners.
              Can you review the files attached and tell me if it is possible?
              The JPG shows the parameters that I need
              51140_drain_cap.skp
              • fredo6F Offline
                The errors comes from the rounding of the upper part and the large offset.
                Currently FredoCorner does not round edges when one of the edge has a length smaller than the offset.
                So, it works with an offset of 2'', but not beyond.
                I am planning to evolve the algorithm to overcome this limitation, but this is quite complex. So, not for an immediate release...
                PS: RoundCorner does not do a better job
                  bsfranza
                  hey there,
                  i have a problem, the fredo corner toolbar does not show up?!
                  in the extension manager its shown, also in sketchucatino licence manager etc, plugin manager, .. its tehre everywhere but i cant get the "toolbar" or menue items to show up?! also removing the plugina and reinstalling from rbz dos not help :I
                  im running the latest su 2021..
                  any help much appreciated,
                  best, bsfranz
                  • fredo6F Offline
                    Did you install the companion library LibFredo6?
                      bsfranza
                      oh silly me :I .. sorry for stealing your time - i have installed the library now it works as expected...
                      thx
                        Buckyman
                        Yes I did see success with 2", and I did try RoundCorner
                        Thanks for your quick response and all your great plugins 😄
                        • NJDesignN Offline
                          NJDesign
                          I am getting a Ruby console error when I try to round these corners. Can you tell me what is wrong?
                          -Never mind. I found a way around it.
                          screenshot
                          skp file
                          Ce qui mĂ©rite d'ĂȘtre fait mĂ©rite d'ĂȘtre bien fait.
                          • NJDesignN Offline
                            NJDesign
                            Since I purchased the license I keep getting Ruby code errors. I have not managed to use the plugin successfully. Here is an example of the errors I get:
                            Date: 20-Mar-21 13:51:43
                            An error occurred in FredoCorner
                            An error occured in the Ruby code
                            undefined method `[]' for nil:NilClass
                            fredocorneralgo.rbe:: 2618 -- chemin_analyze_crossing
                            fredocorneralgo.rbe:: 2421 -- brane_intersect_chemins
                            fredocorneralgo.rbe:: 2060 -- block in catena_process_branes_protected
                            fredocorneralgo.rbe:: 2047 -- each
                            fredocorneralgo.rbe:: 2047 -- catena_process_branes_protected
                            fredocorneralgo.rbe:: 2009 -- block in catena_process_branes
                            fredocorneralgo.rbe:: 2008 -- catch
                            fredocorneralgo.rbe:: 2008 -- catena_process_branes
                            fredocorneralgo.rbe:: 965 -- block in solid_construct_branes
                            fredocorneralgo.rbe:: 964 -- each
                            fredocorneralgo.rbe:: 964 -- solid_construct_branes
                            fredocorneralgo.rbe:: 919 -- block in solid_reconstruction
                            fredocorneralgo.rbe:: 918 -- each
                            fredocorneralgo.rbe:: 918 -- solid_reconstruction
                            fredocorneralgo.rbe:: 883 -- solid_add_remove_edges
                            fredocornertool.rbe:: 1845 -- selection_change
                            fredocornertool.rbe:: 1833 -- selection_add_remove_edges
                            fredocornertool.rbe:: 1856 -- selection_set
                            fredocornertool.rbe:: 1538 -- block in preselection_instantiate
                            fredocornertool.rbe:: 1535 -- each
                            fredocornertool.rbe:: 1535 -- preselection_instantiate
                            fredocornertool.rbe:: 1530 -- preselection_analyze
                            fredocornertool.rbe:: 766 -- true_activate
                            fredocornertool.rbe:: 751 -- block in activate
                            lib6plugin.rbe:: 1568 -- tem_context
                            fredocornertool.rbe:: 751 -- activate
                            fredocornertool.rbe:: 194 -- select_tool
                            fredocornertool.rbe:: 194 -- launch
                            fredocornertool.rbe:: 176 -- action__mapping
                            lib6plugin.rbe:: 129 -- call
                            lib6plugin.rbe:: 129 -- launch_action
                            lib6plugin.rbe:: 227 -- launch_action
                            bootstrap_fredocorner.rbe:: 103 -- launch_action
                            bootstrap_fredocorner.rbe:: 118 -- block in startup
                            lib6plugin.rbe:: 1347 -- command_invoke
                            lib6plugin.rbe:: 1328 -- block (2 levels) in build_config_commands
                            lib6traductor.rbe:: 1377 -- block in add_command
                            • fredo6F Offline
                              Depending on the model, FredoCorner may get into error.
                              So the best would be to PM me or post the model so that I have a look.
                              PS: This has nothing to do with the license. The error is in the algorithm.
                                Brickokermis
                                Like many people around the world, I was surprised that Fredo plugins went from free to paid. This is absurd!
                                Having plugins that have been free for decades and that are quietly going from free to paid, I don't know what quality could I give to this maneuver ...
                                Yesterday evening I saw, in an instant, the error message indicating "trial version finished", I thought it was April Fool's Day a little too fresh, but not when I got to the download page that it was not my astonishment when I saw that it was paying, whereas it was free just before. it's a very, very stupid operating system!
                                I have absolutely nothing against people who are looking for a return on investment. But the way to do it is not possible!
                                Inform people, take opinions, etc.
                                Especially that, 15 days ago when I updated I did not see that it was paid, since it is not displayed on the list of the plug-in store.
                                Another thing, buying it will not be a problem for me, if I have to I would buy it. But not individually, at 22 € / plug-in it's very, if not too expensive.
                                Make a pack of all plugins, or in this case lower the price from 10 to ~ 12 € / plug-in
                                22 € x (number of plugins) = too expensive.
                                Sketchup is starting to take the path of software that is losing value, already that the license is very expensive, if even the plug-ins are not affordable, Sketchup is losing more and more credibility, and that I have read on hundreds of forums around the world about the Fredo plug-in which switched to the Pay system
                                Do not forget, behind there is Blender much more efficient, Open Source, with a more family interface that allows you to learn faster than before. At this speed it's soon the end of Sketchup
                                  Fredo didn't just quietly spring this change on the world yesterday. It was announced months ago that some of his extensions would be changing to requiring paid licenses. It's a one time license fee for each extension and includes the updates as they come along. You aren't being forced to purchase the license for FredoCorner. You can choose to use RoundCorner instead. There's still no charge for that one.
                                    rv1974
                                    @Brickokermis: 22€ per plugin is not too cheap, but lets suppose you used some of (now commercial) Fredeo plugins for 10 years in the past and will continue to use it for additional 10 years in the future; this is approx 1€/year. Just think about it.
                                    P.S. I'd agree though that bundle would be much more user-friendly format.
                                      grigorescustelian
                                      👎 It used to be free... At least let us use our old versions, why do you have to make them expire?
                                        @grigorescustelian said:
                                        At least let us use our old versions...
                                        You can still use RoundCorner without paying for it.
                                          Aroundthebend
                                          Hi, I'm having trouble validating the licence. I keep getting this message:
                                          Sorry - An error occured in the communication with Sketchucation
                                          I've checked I've got the up-to-date Plug-in:
                                          ExtensionStore v4.0.0
                                          FredoCorner 3.2
                                          LibFredo 11.6a
                                          Screen Shot:
                                          • fredo6F Offline
                                            Are you connected to the Internet when doing the validation?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
