    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      @manoamo
      Thank you. Very useful.
      I think this is a bug in the core ruby engine.
      I'll see what I can do in order to overcome the problem.
      • fredo6F Offline
        @manoamo
        Could you try
        ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\\/, "/")
          manoamo
          I tried the last typing but I failed again
          I typed the codes in this sequence
          1. ENV["LOCALAPPDATA"].encoding.inspect
          2. a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8")
          3. a.encoding.inspect
          1. a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub(/\/, "/")
          2. a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub("\", "/")
          3. ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\/, "/")
          1. LibFredo6.get_dir_from_ENV "LOCALAPPDATA"
          • fredo6F Offline
            @manoamo
            Could you tell me what is the erroryou get with this statement
              manoamo
              This is my ruby console
              #Encoding:CP949
              C:\Users\￈ᆱ﾿↓ᄎ￳\AppData\Local
              a.encoding.inspect
              #Encoding:UTF-8
              C:/Users/■ルヘ↓レᄚ→ᄍネ/AppData/Local
              Error: #<ArgumentError: invalid byte sequence in UTF-8>
              c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
              <main>:in <main>' SketchUp:1:in eval'
              This is what I get after restart
              Error Loading File Fredo6_!LibFredo6.rb
              c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
              c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
              C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
              • fredo6F Offline
                Ok. Thanks I think we progress.
                Can you try this statement (only this one)
                File.directory? ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\\/, "/")
                if there is an error, can you try this one
                File.directory? ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub("\\", "/")
                Many thanks
                  manoamo
                  Good to hear!
                  These are what I got back
                  First,
                  File.directory? ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\/, "/")
                  true
                  Second,
                  File.directory? ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub("\", "/")
                  true
                  • fredo6F Offline
                    OK. Thanks.
                    I will publish a fix and it should hopefully work for you.
                      manoamo
                      Thank you so much for your kind help 😢
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v11.4f - 02 Dec 20
                        LibFredo6 11.4d provides fixes
                        • for handling some cases of non-ascii Windows username
                        • for a bug in some tools (MoveAlong and a few others)
                        • 1 Offline
                          1409 douglas
                          I have your latest version as of 02 december 2020 of libFredo6. I have SketchupPRO 2021.
                          I believe I have followed your instructions to load libFredo6 and Curvizard v2.4b.
                          There is libFredo6 under Window, but no Curvizard under Extensions. I have restarted (several times).
                          Any Ideas?
                          Thank you
                          rj
                            No matter how many times you restart SketchUp, Curvizard isn't supposed to show up under Extensions. It shows up in Tools>Fredo6 Collection. Or you can turn on its toolbar button under View>Toolbars.
                              Aiden900
                              Hello fredo, Hope you're fine, I have tried everything in order to make the fredo tools work and it still not workingm the tool bare's aren't even showing up. I even uninstalled and installed sketchup 2019 pro, installed the extensions several times but still no fix, could you or someone please help me out.
                              Kind regards
                              A.F
                                @Aiden900
                                A few things to consider...
                                Did you install SketchUp correctly ?
                                You can repair it and avoid a full re-installation...
                                While you are logged into Windows as your normal user account, ensure SketchUp is closed.
                                Find the v2019 installer exe file - usually in your Downloads folder ?
                                Select its icon, right-click > context-menu > "Run as administrator"
                                When prompted choose "Repair"...
                                After it completes restart SketchUp and retest...
                                I assume you are installing from the RBZ using the Extension Manager > Install... button ??
                                Fredo's extensions [almost all] need his latest LibFredo RBZ installing - available separately from the PluginStrore.
                                Have you downloaded and installed that too ?
                                On its own a Lib does nothing - but it adds vital support for his other extensions...
                                So have you downloaded and installed the latest Fredo Tools from the PluginStore ?
                                Are you aware where the Fredo Tools menu is ? [i.e. under Tools]
                                The FredoTools toolbar button might need activating in your View > Toolbars... dialog's list ?
                                When clicked that toolbar button opens a second dialog listing many of Fredo's tools - click on the name of one of them and it launches...
                                Are the two expected Fredo entries listed in the Extension Manager dialog ?
                                Are they activated in the listing ?
                                • BoxB Offline
                                  Just checking, libfredo doesn't do anything on it's own. It is a helper folder for various Fredo extensions.
                                  So installing just LibFredo does nothing.
                                    Aiden900
                                    Hello TIG, I've been using Fredo for almost all my projects and work and it was working fine, but i had to get a newer version of Sketchup 2019 pro so i got that and yes i've followed the tutorial and everything but still nothing. Also one thing i've noticed is that when i install the extension from the extension manager specially Libfredo 6 and check the version it still says 1.0. I am signed into trimble and stuff and other extensions are working fine except for all the plugin related to Libefredo, like scel corner rounds etc. I've checked under the tools bar and i cannot find the fredo or Lib at all.
                                    If you would like to directly contact me you can. Just let me know what would be suitable.
                                      Here's what my current Extension Manager lists in v2019...
                                      If yours shows something else [and you've installed the latest versions] then it's broken...
                                      Have you tried the "Repair" idea ?
                                      The Lib doesn't appear, except as a 'helper' - the FredoTools is in Tools submenu and a Toolbar of the same name...
                                        Aiden900
                                        Hello TIG,
                                        I've tried repair in administrator mode, Yes i am signed into my windows account as a genuine user. I tried installing the extension again from the beginning by downloading them again and it still not working, Maybe i could be doing something wrong.. It's a suggestion so tell me if it's okay for you. How about you just make a zip file of the Libfredo 6 Rbz file with fredo scale the max and share with me. And i'll let you know if it works by sharing a screenshot. ?
                                          Did you download the Fredo extensions/lib from the SketchUcation PluginStore ?
                                          Retry, using these links...
                                          https://sketchucation.com/pluginstore?pln=LibFredo6
                                          https://sketchucation.com/pluginstore?pln=FredoScale
                                          https://sketchucation.com/pluginstore?pln=FredoTools
                                          Install them all using Extension Manager > Install, restart SketchUp, look at the menus, toolbars and Extension Manager listings... any better ?
                                            Before you install the current version of these extensions, go to the Plugins folder and delete all related files.
                                            Also please update your profile. It says you are using SU2016.
                                            • 80
                                            • 81
                                            • 82
                                            • 83
                                            • 84
                                            • 108
                                            • 109
                                            • 82 / 109
