    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    597 Posts 120 Posters 2.2m Views 120 Watching
      Danial Ismail
      Thank you for your videos and extension, I have a problem for exporting the animation as a video(all format options have the same problem). I use a Mac and have already installed LibFredo6, Animator and FFMPEG. When exporting the animation as video, i have chosen MP4 but it only renders as PNG images and there is no play button under the MP4 format button in the menu. How can i solve this? Thank you in advance!
      https://drive.google.com/file/d/1MIblLevGT2WRjx_8OP5P_DcvnX0KoaEp/view?usp=sharing
      https://drive.google.com/file/d/16NjrfxCdQEBOCHxPPhIG6a_Y2uOw3zIu/view?usp=sharing
      https://drive.google.com/file/d/1cSjdBnmuVJn_dKd3VIPnd8jge4NFki12/view?usp=sharing
      https://drive.google.com/file/d/1yu5zEQh5hdVrnyleU0OseUhbxYfyUnKL/view?usp=sharing
      • fredo6F
        Could you open the Ruby Console before launching the video generation.
        At the end of the process, you should see something like
        Command FFmpeg for mp4 = "C:/Google Drive/Ruby/Ruby/AA_SCRIPT_20/ffmpeg.exe" -framerate 25 -i "Image%02d.png" -c:v libx264 -pix_fmt yuv420p -q:v 1 -vf scale=2*trunc(iw/2*3):-2 "Film 1.mp4" 2> FFmpeg_log_mp4.txt ===> Status FFmpeg for mp4 = true
        Can you tell me what you see.
        Also, could you type (copy paste and return) the following command in the ruby console
        [Sketchup.active_model.active_view.vpwidth, Sketchup.active_model.active_view.vpheight]
        It should return the viewport dimensions.
        Many thanks
          Danial Ismail
          Many thanks
          Hi Fredo,
          I changed the video output dimensions and it solved the problem! Thanks you for your kind attention to reply my question and trying to help. Keep being awesome.
          Best
          Danial
          • fredo6F
            Definitely, one of the problem is the generation of the video when one or both dimensions of the viewport are odd in pixels. FFmpeg, which stitches the images, requires they are even. I introduced some hack to work around the problem, but apparently this sometimes fails.
            • L
              lrainero
              @fredo6 said:
              @lrainero said:
              When generating mp4 video the process stops without doing anything. Sometimes it stops at frame 10 and sometimes at 30 ... and I can't render the video.
              My animation has a duration of 145 seconds and approximately 3,400 frames, with an estimated time of 50 hours.
              I think you push Animator quite far. If I understand, each frame would take over 50 seconds to render. Maybe you can try to simplify to have a faster unitary render.
              With VRay 4.2, there is a problem of stability with the API and I would not recommend to engage in such long process.
              I am currently investigating VRay 5, which has a cleaner API and may be more reliable.
              Thank you very much for your answer.
              I'm going to try to divide the animation into shorter parts and then put them together with some editing program.
              I hope that with vray 5 you can achieve better results in this case, even so I am very happy and grateful with your plugin.
              Thank you very much for everything Fredo!
              • fredo6F
                New Release: Animator - v2.9a - 19 Nov 20
                Requirement: LibFredo6 v11.3
                Major release
                • Support of VRay 5
                • Bug fixing
                • Extension of validity
                See plugin home page of Animator for Download of RBZ from the PluginStore.
                See Main Post of the Animator thread for more information.
                  mitch7780
                  Hi Fredo6,
                  I generated two animations this week, after the update to v2.9a, and they both came out perfectly.
                  However when I send them Via WeTransfer, DropBox etc for others to view they are experiencing errors or corrupted files and the videos become unwatchable. The videos are still absolutely fine on my machines though.
                  This has only happened since the update, is there anything else I need to do to correct this? Do you know why this could be happening?
                  Thank you.
                  • fredo6F
                    @mitch7780,
                    Strange. Last update did not touch the video part.
                    Did you generate with NO rendering or with a rendering software?
                    What is the format of the video?
                      mitch7780
                      Just a standard video, no Vray etc.
                      File formats in .mov & mp4
                      • fredo6F
                        What happens if you download your video posted on DropBox onto your own computer. Would they be corrupted too?
                          mitch7780
                          I just tried transferring the file, via DropBox, from my PC to my Imac and it downloaded and played fine.
                          I'm not too sure what's happening when I send the file over to a client. I've been using WeTransfer previously for other animations and it's been no problem.
                          Your extension is absolutely fantastic by the way, please don't think that this issue has any effect on how I continue to use Animator. It's probably just one of those things but I had to bring it to your attention just in case you had a solution.
                          One thing I would like to ask is about the sizing or dimension of the viewport before I start processing, is there a rule of thumb for optimal size, i.e 1920 or 1200 etc...
                          Thanks again.
                          • fredo6F
                            New Release: Animator - v3.0a - 06 Jan 21
                            Maintenance release
                            • fredo6F
                              New Release: Animator - v3.1a - 17 Jan 21
                              Requirement: LibFredo6 v11.5
                              Major release
                              • Introduction of Camera Around, allowing the creation a camera travelling around a set of objects
                              • Bug fixing
                              • Cosmetic and technical adjustments
                              Here is a short presentation on Camera Around:
                              • JClementsJ
                                JClements
                                A great way to begin the new year**!** THANK YOU.
                                Really nice features and interface/easy-to-understand controls.
                                Should satisfy long awaited needs. The demo is well explained.
                                Could Scenes be generated? Export to movie formats or images (jpg, gif, etc.)?
                                • fredo6F
                                  What do you mean 'generated'?
                                  • JClementsJ
                                    JClements
                                    Have scenes created at specified intervals along the camera path (eg., at 10% intervals or intervals at a specified distance).
                                    • fredo6F
                                      New Release: Animator - v3.2a - 28 Jan 21
                                      Maintenance release
                                      • T
                                        tomasz
                                        Great to see the beta. It is good timing since we prepare a new release too.
                                        I always appreciate how detailed and well thought your feature implementations are!
                                        • fredo6F
                                          New Release: Animator - v3.3a - 22 Feb 21
                                          Maintenance release
                                          • Fixed a major bug for Camera Tracker introduced in v3.3a. Unfortunately, you will have to remove camera tracker sequences created with v3.3a and recreate new ones.
                                            axetect
                                            Hello, first of all I would like to thank you for creating such ingenius tool, now I would like to ask if there is any way to make it render at cloud, it would be a game changer for me as a low spec pc user. Thanks
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 29
                                            • 30
                                            • 20 / 30
