[Plugin Library] LibFredo6 - v14.5b - 24 May 24
@spablo said:
instale el plugin y no funciona
LibFredo no hace nada por sí solo, ayuda a sus otras extensiones ...
¿Cómo no funcionó?
¿Reiniciaste SketchUp para sincronizar cosas?
Ayuda a Fredo, ¡no es un psíquico!
The LibFredo does nothing on its own - it helps his other Extensions...
How did it not work ?
Did you restart SketchUp to sync things ?
Give Fredo some help - he is not a psychic ! -
I am having issues with the animator. I have made animations in the past no problem. I try to make them now and i either get the hundreds of images OR nothing at ALL. I have uninstalled and reinstalled libfredo, FFFmpeg and it worked once, but now is not working.
Please advise.... thanks
I really want to use your tools but I can't install Liebefredo6 ..
Whenever I install Liebefredo6, this message pops up
Error Loading File Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:ingsub' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in
get_dir_from_ENV'
c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:insu_appdata' c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in
dir_appdata'
c:/users/xxx/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:instartup' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in
process'
C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in<module:LibFredo6_Loader>' C:/Users/xxx/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in
<top (required)>'Please help...
Thank you so much -
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:ingsub' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in
get_dir_from_ENV'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:insu_appdata' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in
dir_appdata'
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:instartup' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in
process'
C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in<module:LibFredo6_Loader>' C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in
<top (required)>'I'm having an issue installing and loading LibFred6... please help
NEW RELEASE: LibFredo6 v11.3a - 19 Nov 20
LibFredo6 11.3a is dedicated to
- Bug fixing
- Support of VRay 5 in Animator
- Some cosmetic adjustments
- Compatibility SU2021
NEW RELEASE: LibFredo6 v11.3b - 21 Nov 20
LibFredo6 11.3b contains small adjustments over v11.3a
Hello LibFredo6!! Just installed the new versions of animator and the library plugin. I use Vray next to render and i notice that after te first image is rendered Animator doesn't start with the second image. It just keeps counting the seconds even after the render is finished. I also noticed that in the menu, the preset dimensions are gone. I only have the viewport option.
Greetings, Simon
Could you open the Ruby Console before launching the video generation and check the traces and potential errors.
Can you also confirm the version of VRay you use. Thanks. -
Hello Fredo! Thank you for answering!! This is what te ruby console showed when opening Animator and starting the generation of the movie:
RENDERING INIT
Status natural = {}
Status thea = :not_supported
Status ambient_occlusion = :not_supported
Status sketchFX = :not_supported
Status twilight = :not_supportedVRAY4 Init
Status vray4 = nil
Status vray = :not_supported
:beg_time => 0
:end_time => 90.5
:frame_rate => 25
:speed_factor => 1.0
:reversed_play => nil
:transparent => false
:dimX => 1920
:dimY => 1080
:dim_mode => "custom"
:filter => {
} (:filter)
:root_dir => "C:/Users/Gebruiker/Desktop/PROJECTEN/CARPENTIER/7. MONTAGEFILM HOUTEN WAND PERGOLA/Animator Videos"
:movie_dir => "BASIS ANIMATOR 4 - 23-Nov-2020 15-23-52"
:movie_name => "Film 1"
:date_modified => 1606130042.267186
:break_aspect_ratio => true
:movie_formats => {
:mp4 => true
:mov => false
:img_seq => true
} (:movie_formats)
:rendering_method => :vray4
MOVIE PX = 1920 PY = 1080 transpa = false
FORMATTED===========================VRAY Movie frame 1
Animation time = 0.00s
AFTER launching Rendering and Timer: status = true
VRAY Status check - status = 6
VRay rendering not finished yet elapsed = 1.99s
Error: #<NoMethodError: undefined methodstate' for nil:NilClass> c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:445:in
vray_status_check'
c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:553:in `block in vray4_status_check'
INTERRUPT true
VRAY STOP timer =
VRAY STOP timer =My Version of Vray is: V-Ray for SketchUp 4.20.02
Greetings
NEW RELEASE: LibFredo6 v11.4a - 23 Nov 20
LibFredo6 11.4a fixes a problem introduced with v11.3a in the support of VRay 4.2 for Animator
Everything works fine with the update!! Thank you so much!! Greetz
I'm having a " invalid byte sequence in UTF-8 error "
I watched your installation video 4 times, Searched about this error for days.
I found out that this might be a encoding problem, but I have no idea how to solve this problem.
please help .. Below is error log(?) when I restart SU after Libfredo6 installation.Error Loading File Fredo6_!LibFredo6.rb
c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:ingsub' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in
get_dir_from_ENV'
c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:insu_appdata' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in
dir_appdata'
c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:instartup' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in
process'
C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in<module:LibFredo6_Loader>' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in
<top (required)>' -
@manoamo said:
I'm having a " invalid byte sequence in UTF-8 error " .
It's definitely related to your Windows user name not in ascii.
Difficult to fix as there are so many situations.
If you agree, we could try to troubleshoot together the problem (I would send you some small lines of Ruby to test).
In the Ruby console, can you type (just copy / paste the statement and Enter)
ENV["LOCALAPPDATA"].encoding.inspect
Then tell me what you see as a response
Thank you so much for your kind help! Much appreciated!!
#Encoding:CP949This is what I got !
Could you now execute the following commands in the Ruby console, one after the other
a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8")
a.encoding.inspect
#Encoding:CP949
C:\Users\ᆱ↓ᄎ\AppData\Local
a.encoding.inspect
#Encoding:UTF-8This is what I got
#Encoding:CP949
a.encoding.inspect
Then, can you try the following commands
a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub(/\\/, "/")
a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub("\\", "/")
and then this command
LibFredo6.get_dir_from_ENV "LOCALAPPDATA"
NEW RELEASE: LibFredo6 v11.4d - 27 Nov 20
LibFredo6 11.4d fixes two issues for Animator (VRay5 rendering of apparation and rotation with variable speed)
#Encoding:CP949
a.encoding.inspect
#Encoding:UTF-8
a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub(/\/, "/")Error: #<ArgumentError: invalid byte sequence in UTF-8>
<main>:ingsub' <main>:in
<main>'
SketchUp:1:in `eval'a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub("\", "/")
C:/Users/ᆱ↓ᄎ/AppData/Local
Error: #<NameError: uninitialized constant LibFredo6>
<main>:in<main>' SketchUp:1:in
eval'I followed every step that you told me!
but still same errors occur -
Thank you. Very useful.
I think this is a bug in the core ruby engine.
I'll see what I can do in order to overcome the problem.
