    Alfa Romeo 33 Stradale final
    17 Posts 9 Posters 3.9k Views 9 Watching
      I think I learned enough with the Dusenberg SJ to just render this.
      1.
      • N
        nickchun
        Beautiful, I want one.
        Maybe a bit of a bump map to the grey texture in the wheel arch and its as good as.
          Thanks mate.
          • Gus RG
            Gus R
            Excellent.
            www.instagram.com/gusrobatto/
            www.facebook.com/gusrobatto
            • HornOxxH
              HornOxx
              ... it´s perfect! the lighting (hdri ?) is so well chosen 👍
              never trust a skinny cook
                Thanks mate. Not hdri, a physical studio model. I have some tips on the Twilight forum to iron out some slight faults. Apparently the shape of the lights and reflectors is wrong for the model and gives the large artefacts across the body of the car.
                • majidM
                  majid
                  What is your rendering engine? Nice job!
                  • Bryan KB
                    Oh yes! 👍
                      Thanks folks, Ywilight V2 Pro. Looking to remove the lighting artifacts.
                        Adjustments as per suggestion, any thoughts?
                        Adjusted.
                        • ntxdaveN
                          ntxdave
                          Just a personal opinion, I liked the shade of red a little better in the first image but the other adjustments are much better in this one.
                          Press F1...thank me later
                            Thanks mate, all things to think about so very handy.
                            • tademaT
                              tadema
                              Very nice Mike 👍 👍 👍
                                Thanks mate, you are still an inspiration.
                                  OK, done after this, a new 3d studio helps a bit,
                                  fini.
                                  • ely862meE
                                    ely862me
                                    Looking good!
                                    Usually the inner wheel arches are painted in darker colors, mostly black.
                                    https://upload.wikimedia.org/wikipedia/commons/d/d5/Alfa_Romeo_Tipo_33_Stradale_Front.jpg
                                    Elisei (sketchupper)
                                    Come and See EliseiDesign
                                      Thanks mate, I am a contrary bugger tho'.
                                      The 360 degree light is a 40 watt emitter and is the majority of the light. I have a further render using additional lighting via a three petal sky portal. I'm quite happy with the studio setup. It took quite a bit of testing but simple works best in the end.
                                      Inferences from sky portal on the bodywork.
