    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
      abhi100
      @kumarakeke said:
      hi Fredo,
      thank you for this useful plug in!
      anyway i'm facing an issue using the newest Animator version (2.7a). everytime i click 'Generate a Video for the Film' button, a ruby console window always shows up. pls see below image:
      https://i.ibb.co/vjw2jTG/Annotation-2020-07-21-172231.png
      im using Sketchup Pro 2019 19.2.222, Windows 10 Pro and also already installed the latest LibFredo6 10.9a.
      did i miss something?
      thank you very much
      Yes the exact problem happens to me and I can't generate videos. I am running Sketchup version 2017-17.2.2555 64bit. I haven't seen any solution for this problem in any forum yet
      • fredo6F
        Just in case, could you tell me what is the version of your Internet Explorer browser (go to IE and find menu version).
        I don't know if this is related however.
        But as I cannot reproduce the problem, I need to have more information.
          mitch7780
          I'm new to animating in Sketchup but I've seen so many good reviews for Animator that I thought I would give it a go.
          Really easy to learn, simple but detailed and gives a great result.
          However, I'm experiencing a few issues, they are as follows:
          On occasion some of the buttons disappear or are missing segments.
          Groups or components aren't highlighting when you need to make a selection when creating a new movement.
          Sometimes when a new movement is selected none of the action tabs appear to select to enable you to make your desired movement.
          A number of times I've created an entire film, which takes time, I press the save button and exit the extension. If I go to open the extension back up the entire film has gone.
          Also, once a film has been created, I've saved it, opened it back up and all of my groups and components have moved, either reversed their original positions or are totally somewhere else in the model.
          Really sorry to highlight these issues, especially if it's something I am doing wrong. I would very much like to keep using this extension but I need some help with the above.
          Many thanks
          • fredo6F
            I would need some examples or screenshots in order to troubleshoot or at least understand the kind of issues you are facing.
            • ntxdaveN
              ntxdave
              Fredo6, we would like your feedback/input on a thread we have started about animating 3D characters in SketchUp.
              Press F1...thank me later
                mitch7780
                Hi Fredo6,
                Thank you for replying.
                I have one example that I have taken a couple of sreenshot's of, please see attached.
                You'll notice that some of the icons are missing or only partially there.
                When this happens the highlight of objects also doesn't function, i.e no coloured bounding boxes.
                Let me know what you think, I'll try my best to give you further examples.
                • fredo6F
                  Could you leave the Ruby console opened when you work with Animator. I suspect the partial display is due to some errors that will show up in the Ruby console when they happen.
                    mitch7780
                    Hey Fredo,
                    I'll give it a try.
                    Thank you.
                    Ben
                    • fredo6F
                      New Release: Animator - v2.8a - 17 Sep 20
                      Requirement: LibFredo6 v11.1
                      Minor release
                      • Bug fixing
                      • Extension of validity
                      See plugin home page of Animator for Download of RBZ from the PluginStore.
                      See Main Post of the Animator thread for more information.
                      • C
                        CMC007
                        Hi Fredo,
                        Thanks very much for the ongoing development of this excellent tool!
                        One feature request I have that I think would go a long way towards ease of integration with other renderers would be the ability for Animator to save individual animation frames to SketchUp scenes - each scene could then be batch rendered (for example by Enscape) without requiring any direct integration.
                        Is this functionality in your development plans at all? I have also been requesting Enscape to work on integrating their rendering functionality with Animator so hopefully this can happen some day!
                        Thanks again,
                        Christian
                        • fredo6F
                          There are two problems with this
                          1. Scenes do not record the position of objects. So this would only be working for camera movements
                          2. I am not sure SketchUp would be happy with a huge number of scenes. At 25fps, you generate 250 scenes for a clip of 10 seconds....
                          I can possibly contact Enscape to see if they have an API. I have never done it as I don't have their contact.
                            mitch7780
                            Good afternoon,
                            I've had an issue with v2.8a today, I generated a video of around 68s and has taken just oven 3.5hrs. When it finished it came up with the message box asking me to save and exit. I did this and when I opened the folder where it had saved to there was only one video at 9s long.
                            Not too sure what to do now, is there a way to get back to that message window to try and salvage the file?
                            If I have to generate another I will but would prefer not to have to start the process again if I can.
                            Any thoughts?
                            Many thanks
                            • fredo6F
                              @mitch7780
                              Did you generate the video with a renderer?
                              If so, do you get the same problem when you generate in Natural mode (i.e. no renderer)?
                              Otherwise, it's difficult to say anything without more information, possibly getting the model.
                                SAJD2000
                                hello can you help me ?
                                I install 2.8 version and animator panel disappered 😞
                                How can i bring it back ?
                                https://img.imageupload.net/2020/10/01/Beztytulu.jpg
                                • fredo6F
                                  Could you check that
                                  • You have Animator in the menu Tools > Fredo6 Collection
                                  • You should also have it in the dialog box View Toolbars... The Animator toolbar may just be set to non visible.
                                    SAJD2000
                                    no 😞 i don't have in anywhere, but in extension manager it is install and updated
                                    https://img.imageupload.net/2020/10/01/Beztytulu1.jpg
                                      SAJD2000
                                      Fredo please help i need animator
                                      • H
                                        HuiJax
                                        Hey Fredo,
                                        is there a shortcut or a other way to skip the animation frame by frame? I want to render each single frame with enscape and put the single frames togehter in Adobe Premiere... but clicking all single frames with the mouse is a little bit stressy πŸ˜„ would be great if you can help
                                        best regards
                                        • fredo6F
                                          Not clear to me. What do you need exactly?
                                          For info, Animator does not support Enscape in the list of renderers.
                                          • H
                                            HuiJax
                                            Hey Fredo,
                                            thx for the Answer. I would like to make Animation like in this Video...
                                            Short Summary. He Move each object step by step and capture this movement of the Enscape "Frame Buffer" on a Second Screen. In Adobe Premiere he cut it together and it looks smooth.
                                            I want to the same with the support of Animator. When i play the Animation it goes to fast an the live Render have a bad quality. So i must rest for a second and then move on with the next frame. Like this i can manage the movement of different object simultaneously and coordinate it much better the manuell with hand... i hope i could explain this a bit better and sorry for the bad english...
                                            best regards
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 29
                                            • 30
                                            • 19 / 30
