    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
    • fredo6F
      @cmc007 said:
      One feature request I have that I think would go a long way towards ease of integration with other renderers would be the ability for Animator to save individual animation frames to SketchUp scenes - each scene could then be batch rendered (for example by Enscape) without requiring any direct integration.
      There are two problems with this
      1. Scenes do not record the position of objects. So this would only be working for camera movements
      2. I am not sure SketchUp would be happy with a huge number of scenes. At 25fps, you generate 250 scenes for a clip of 10 seconds....
      I can possibly contact Enscape to see if they have an API. I have never done it as I don't have their contact.
        mitch7780
        Good afternoon,
        I've had an issue with v2.8a today, I generated a video of around 68s and has taken just oven 3.5hrs. When it finished it came up with the message box asking me to save and exit. I did this and when I opened the folder where it had saved to there was only one video at 9s long.
        Not too sure what to do now, is there a way to get back to that message window to try and salvage the file?
        If I have to generate another I will but would prefer not to have to start the process again if I can.
        Any thoughts?
        Many thanks
        • fredo6F
          @mitch7780
          Did you generate the video with a renderer?
          If so, do you get the same problem when you generate in Natural mode (i.e. no renderer)?
          Otherwise, it's difficult to say anything without more information, possibly getting the model.
            SAJD2000
            hello can you help me ?
            I install 2.8 version and animator panel disappered 😞
            How can i bring it back ?
            https://img.imageupload.net/2020/10/01/Beztytulu.jpg
            • fredo6F
              Could you check that
              • You have Animator in the menu Tools > Fredo6 Collection
              • You should also have it in the dialog box View Toolbars... The Animator toolbar may just be set to non visible.
                SAJD2000
                no 😞 i don't have in anywhere, but in extension manager it is install and updated
                https://img.imageupload.net/2020/10/01/Beztytulu1.jpg
                  SAJD2000
                  Fredo please help i need animator
                  • H
                    HuiJax
                    Hey Fredo,
                    is there a shortcut or a other way to skip the animation frame by frame? I want to render each single frame with enscape and put the single frames togehter in Adobe Premiere... but clicking all single frames with the mouse is a little bit stressy πŸ˜„ would be great if you can help
                    best regards
                    • fredo6F
                      Not clear to me. What do you need exactly?
                      For info, Animator does not support Enscape in the list of renderers.
                      • H
                        HuiJax
                        Hey Fredo,
                        thx for the Answer. I would like to make Animation like in this Video...
                        Short Summary. He Move each object step by step and capture this movement of the Enscape "Frame Buffer" on a Second Screen. In Adobe Premiere he cut it together and it looks smooth.
                        I want to the same with the support of Animator. When i play the Animation it goes to fast an the live Render have a bad quality. So i must rest for a second and then move on with the next frame. Like this i can manage the movement of different object simultaneously and coordinate it much better the manuell with hand... i hope i could explain this a bit better and sorry for the bad english...
                        best regards
                        • fredo6F
                          @huijax said:
                          Hey Fredo,
                          best regards
                          You can indeed construct this kind of animation with Animator, as it implies just moving objects.
                          However, Enscape is not supported by Animator. So, you would have to render it with another rendering software.
                          Otherwise, the method described in the video is quite astute and you can mimic it.
                          • H
                            HuiJax
                            Again, thank you very much for your Answer! Iam a big Fan of your Work an love to use your PlugInΒ΄s!
                            So the concept of the Animation is clear. I made an animation with Animator. A simple movement of an Object. In the next Step i skip Frame by Frame the Animation and record the live renderig with Enscape and put them together in Premiere. So my question is (and sry for the big explanation) is there an shortkey to skip frame by frame in the Timeline (in Premiere it is a arrow key). If not, it would be Great if there coulde be one in the future Version...
                            Thank you for your Time and your patience!
                            • L
                              lrainero
                              Hey Fredo,
                              Thank you very much because Animator is helping me a lot in my work.
                              I have a problem and I don't know if you could help me.
                              I use Sketchup 20 and V-Ray 4.20.01
                              When generating mp4 video the process stops without doing anything. Sometimes it stops at frame 10 and sometimes at 30 ... and I can't render the video.
                              My animation has a duration of 145 seconds and approximately 3,400 frames, with an estimated time of 50 hours. My PC has 16Gb of Ram, a Ryzen 2700x processor and my graphics card is an Nvidia gtx 6Gb.
                              I don't know if you can help me, but thank you very much anyway.
                              P.D: Sorry for the text if it is not well understood because I do not speak English and I am using a translator.
                              • fredo6F
                                I think you push Animator quite far. If I understand, each frame would take over 50 seconds to render. Maybe you can try to simplify to have a faster unitary render.
                                With VRay 4.2, there is a problem of stability with the API and I would not recommend to engage in such long process.
                                I am currently investigating VRay 5, which has a cleaner API and may be more reliable.
                                  Danial Ismail
                                  Thank you for your videos and extension, I have a problem for exporting the animation as a video(all format options have the same problem). I use a Mac and have already installed LibFredo6, Animator and FFMPEG. When exporting the animation as video, i have chosen MP4 but it only renders as PNG images and there is no play button under the MP4 format button in the menu. How can i solve this? Thank you in advance!
                                  https://drive.google.com/file/d/1MIblLevGT2WRjx_8OP5P_DcvnX0KoaEp/view?usp=sharing
                                  https://drive.google.com/file/d/16NjrfxCdQEBOCHxPPhIG6a_Y2uOw3zIu/view?usp=sharing
                                  https://drive.google.com/file/d/1cSjdBnmuVJn_dKd3VIPnd8jge4NFki12/view?usp=sharing
                                  https://drive.google.com/file/d/1yu5zEQh5hdVrnyleU0OseUhbxYfyUnKL/view?usp=sharing
                                  • fredo6F
                                    Could you open the Ruby Console before launching the video generation.
                                    At the end of the process, you should see something like
                                    Command FFmpeg for mp4 = "C:/Google Drive/Ruby/Ruby/AA_SCRIPT_20/ffmpeg.exe" -framerate 25 -i "Image%02d.png" -c:v libx264 -pix_fmt yuv420p -q:v 1 -vf scale=2*trunc(iw/2*3):-2 "Film 1.mp4" 2> FFmpeg_log_mp4.txt ===> Status FFmpeg for mp4 = true
                                    Can you tell me what you see.
                                    Also, could you type (copy paste and return) the following command in the ruby console
                                    [Sketchup.active_model.active_view.vpwidth, Sketchup.active_model.active_view.vpheight]
                                    It should return the viewport dimensions.
                                    Many thanks
                                      Danial Ismail
                                      Many thanks
                                      Hi Fredo,
                                      I changed the video output dimensions and it solved the problem! Thanks you for your kind attention to reply my question and trying to help. Keep being awesome.
                                      Best
                                      Danial
                                      • fredo6F
                                        Definitely, one of the problem is the generation of the video when one or both dimensions of the viewport are odd in pixels. FFmpeg, which stitches the images, requires they are even. I introduced some hack to work around the problem, but apparently this sometimes fails.
                                        • L
                                          lrainero
                                          Thank you very much for your answer.
                                          I'm going to try to divide the animation into shorter parts and then put them together with some editing program.
                                          I hope that with vray 5 you can achieve better results in this case, even so I am very happy and grateful with your plugin.
                                          Thank you very much for everything Fredo!
                                          • fredo6F
                                            New Release: Animator - v2.9a - 19 Nov 20
                                            Requirement: LibFredo6 v11.3
                                            Major release
                                            • Support of VRay 5
                                            • Bug fixing
                                            • Extension of validity
                                            See plugin home page of Animator for Download of RBZ from the PluginStore.
                                            See Main Post of the Animator thread for more information.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 29
                                            • 30
                                            • 19 / 30
