    [Plugin] Gradientator v1.21
    54 Posts 24 Posters 52.6k Views 24 Watching
      @utiler said:
      So do I. Would love to try this plugin....
      The post just before yours offers a solution http://sketchucation.com/forums/viewtopic.php?p=575140#p575140, and @sdmitch gave an even simpler version a few posts earlier http://sketchucation.com/forums/viewtopic.php?p=541222#p541222
      Just edit the RB using a plain-text editor like Notepad++, then find the do |@grad_dialog, text around line #79, and remove the @ so it's do |grad_dialog,.
      Save the RB and restart SketchUp...
      Since the @grad_dialog is defined earlier it is not necessary to redefine it in the do block, so using ANY name which doesn't start with a @ will work !
      • utilerU
        utiler
        Thanks Dave / TIG. Trust me to jump into a new plugin without reading through recent posts.... Cheers, I'll give it a crack tonight!
        Just Curious...
        • utilerU
          utiler
          😉 Worked a treat, guys. Thanks!!!
          I'll post in a few days what I needed it for. Glad to share.... 😉
          Just Curious...
            Works fine! 😄
            • G
              GianfrancoGalli
              hi, just landed on this post. the plugin is not working in make 15/16. i can select it in both Make 15 as 16, but it's not doing anything.
              i've used v1.21. downloaded it to C:\Users\YOUR USERNAME\AppData\Roaming\SketchUp\SketchUp 201X\SketchUp\Plugins
              thanks for your thoughts!
              • sdmitchS
                sdmitch
                404 Not Found
                (sketchucation.com)
                http://sdmitch.blogspot.com/
                  JaysonBata
                  why is it not functioning to my sketchup 2017? 😞
                    The script needs some editing to work. Scroll up a few posts and read what sdmitch wrote. Edit the .rb file to make that change and it'll work. this is in SU2020 after editing the script and installing it.
                      dlightsey
                      Does anybody have the repaired file. When I open the RBZ file using note pad, I get a bunch of garbage. I have tried all the standards when opening.
                      Thanks,
                        Download the .rb file from the first post of the thread and make the edit according to the this post.
                        • I
                          its3Dmade
                          I have tried this fix but when I go to notepad or any word process to open I get this -(on PC)
                          PK   쉄B4‹"Ût
                            $     gradientator.rbYûsÛ6þٝéÿ€Ò7gi,ÓŽÓÞñܼsžKš'éM'ÓÑ€$(¡¦­¸±ÿ÷û IP–œô&±FÝÅ>¾}p—½_Èšá?gµ\V…`F©¬Ò*Y£yQ\³¹(…æF`›Yh!RU(ÍæšgR”†©’-EÍTÎržŠ;þö›]öÊïàÛ“kVq%˜&Ž…LEY‹Œ5e&4Î?Ó‚‰ÇÏÔr©Êš=1Fˤ1R•?©’–…N%/Þ-¸O
                          y)ØÃøˆ}(+¥
                          H½v4‰5qÙh³z©´˜@p0­UnV8Kà†W2鈓
                          "ÆËŒ­¤Y¨Æàû5Ÿ*-jÜòB7[qVóÒàž&Ë´h2YÎ'í)âYÈ¥Äu!3±N’†è"üä‰,¤¹¶¬siJb—+ÒFŵ‘iSpͪFW*¸žÓ•  ¶.-/²€½`U4s	Ö0%¯»’µ4laLurxˆÝͲŽëKaÒE“Úƒqª–‡WR¬ŒªdW‹êÇ|úðøá_ÍôûþùÃÏs`Ç«ñqûàg¡kâ_*#ê¿h7ÐvÀžd¤â«p›{ð†g‚ýW$ÏaP5gдüƒ',EÊ0ð;¡ã€ §÷j›E®%m¯ÉYeY^¦¢_õ<T&sÒ>Ybů™õ[x;´—ò‚Ô·yÄæ
                          '㢆¹Ôµ™°¥Ì²Vž‚צ=½’EÁCÍÒS’gÓ¹¦v"bÒòyY5&QŸHRÞ_Ù¹Íæ@ËX¦Uu©ˆ«O.š¼&Z;”Ÿ°IæÏYÂ3Hþ’<…óà6£•æU…mÎ/ (Xª¬¡{Á
                          Æ¡‘8=÷¢rcEON•D“d/
                          µê.J+µ(DêvZ\h5$K»ÖâCÈ$z.½­r­–ì­–à‘.y'KxÊbö¦IÁ°ƒƒ4…©¿cïEŸ”rä•ò”×2e0fâCþ";øEÐ^Ëe'«*‹ëo¿ùö-~o$übÏÇGëd8u±w³0
                          èÉÎ.„1†Ôóó‹‹§oß½ ¥”² j]	Ü;Q
                          ddåîýʾàf‘4>vÁ ŒKæƒLðÿ/-ù)Q·¬3‘“úóXU¢\IÜw5‚5whûN—éB¤—äp×LUäY–ÿ+¥æ…ðäwûøœy%d`ô÷øÈ2Ú‘9½kuâ7ÆFÍrvÊî´"Xš;Îã%ð†‚C¢_TÖ
                          t°àWÝe+±ý»Tˆ|éS7l‹ÙÏÔ;3ÍÝU d´»©Èê"Žœ$Z˜F—P¢ÌZ=†]E‹vw£ ¹3»Þki'‘¥p©š\ßgPºvv"ÑŒÐ~É/q$™b{`=JmÊc
                          ܆¼«;#õ
                          †` ¸š}8gyÁçä7µ0t÷ºläî­‘4KS{I?xjªŒ[ßsÖ¯)†ˆ“u¨­»µ6ÅkAâC¸Mà•Ú•‰;E¶¥53µ¤¿/¹f ÈQ­CÅD}´àg„lˆj½N‹ª™/<Ø¤É3BMÜ‹$çä. °’Tȵ•…ÃQ„¯?ÓKâOY+RKÕûÌnÄ
                          ±¬güÇΧON^âØ˜ÝöÂ]X¯©	…Ö”ÿó÷2™•{¦Å>*,Û	ëö][Pñ; ÑL[9Øç„QÎáWÓ);Ú;ïq$á.ÃìnÓ_«†Jro|e+ÕÈ`T-‘æª
                          ²`k”O¹¨¹#‡\!ùœSÔ±—ôrByãä¡«w*ö˜ílf3$/ê.CˆlNrŠ£öwŸH£¨ŽIm”óRiç‡á‡ípðnT[DFh„‰ÖûNCÅ&WÖŠ6Ó¹èÝÁ~¿»¸+Œ4”+ð7WŸh$ÅÚèkv	Kûç+™™Å„-„œ/P…Èñ‰šjÒ6½›’êg™ã5eÎON;Þq)V£(¼7"'‡*Á#Â×ãMØÃ#|ÿ
                          ¾?r5^'—7³„§—sDX™Íl¶EÏÒ¿(Èï­AìUÂâœÁÇ­ôj!¡ôIe
                          ¡©ü|„£v–CE!©ÞvUàpUŽ«¥Ó5Óia5fÜúØŒØÐFÑ·üñhÌ2Ån¿¹äKqãRÅ[°JÑY!gó¤Êyd÷ºÜyl5¦JáN°LÄž
                          ,5³+^4bÙí3ì·,¼³z*f¥þìßD…J¬?G‡N)…ç¬%Üz¯1Ü|2¸ÁdM’‰C±‰Üq ?“;ÛÔoyÏgfÎøCåoóéAè¿òÕ³-¾Ð;RÙê|ºÒ²¦Î«t¿
                          ^vPaQš Œö±?JÐùÚ\Sšâs›uPt¡p•qZ®¤³‚£\õ¨9øu)#儬hAÚ rGP+]t^—`6îýß>§Žñ;(PNNžÑrL;¬í¶…Yv«•Z6PˆI,—úz‹<6bY9)60+æ¾Æa,Ný­£M÷¢}±í9=M{¥¸	Á‰ž'£h¿g·ÅÝ~4¬ÏÉ¡6>IÀÆ?ŸYn§‡N„³ˆµ×
                          r·hPö$õŠ<¶ª³)¯3ý¿Þ¿y.ÏŽ;ºÔà!«‡â!‘& «½SúrvJÕRc^WbñÉþƯ¸[Îò¦tY‘ë¢I®	ÑGcöù÷Fh²iT_V'-ˆ=¦"x# =òÀX(ß®#ðr·dÝÞaóŒBå|îFÞ¸œºk¦Lè³ÓÄý½sÉÝ;
                          {pÂ;õù^fÓu@<ÛÛzÓþÛí›	o&ØaãŸ&øpÁ$¿†ä©«œá“Æ ýŽ ,i Ɂ½#%{ûoûWöVìO?£†¹ …NˆÃÖ‡Ö÷6fN*èñ¨÷à
                          uÂB­¨çáE×?TÙ.{O€Ú¶F3ìAÃì1HƒÜ±–;\æè‡ß'†Bß´5&E¤ƒòÚu=ú»ºÙd×9k«ä7˜­Ž·óZìQž@a‚Úl9a°;vL‹>9¸R°R•9IZ~{TsÃ%/<럠íÁ‰­£°£T†æ‰® ÉÉ"(wlä·?úÂc2‡
                          @Ë÷ðF؉Í}GZSÙCðÛšE]¬ï~帝°‹WOiµ“ž ËáŠùµ5‚÷Ûè‡ãŽƒ|–×8ÐÊ;ZÛÂáaÏ¡½çô`‹]»ÃÇ®öœè…ê;ލMÝ`¤ŠžÒºuèóRþ!l©‚è³­œ›T}õÕAÙó)M/©0S1Í+™!ÝفÍ&ºz£¦QÚJ—ç–èêÚõQ7£Aùªkq©Éæ1gP«@?õBæ†Ã—Fã°6p‡ñáhv½vŠ4><è$Ö %Où~JÖ;›d²RÙ•¯¥vG²!½ŽÃýôÈK6	GëÙhá+IÝ‘l@¬¥~/±Ö—º
                          W–Ò e Ã]HT·mË.~o¸}Oä‹ßR"ᅝñN‡`öJÝ´«+ó¶µUa¾VøýFÆK!*ÔëÕ(ÅEEÎ5ÂAÑ´Ì5»[Ô°oÕÁõA0\€2ý”M‹+©š‘Ö”Jg‚¼ÔM`\桤 (éøŸíQ6+;‘;2
                          T¬W¦9…íïig?(*ël)×}6¼8NД}¶%²³¾mnèû
                          s>ҏ_§o/Î_ÿ·òYg‰ªçëØãžÙÃŽkh…¡Ãà“ä†ñ~e§Ó3–ЗÛxÉ+zVÞ°òãѯá”íCyàæ‘ÆO…h8“‰¤™Ïí[÷Ú‹Þ´å¬Ú8ñGŽ¿´Rì~]ú–-x‘cñ®£ÃÏcÛ›8ˆÞ
                          ’Qñï £ÅõÖÓnÏÏTƒgÇá3ŠÁÛ8äó„½£@uœ<`ÚXÙß=<ä|z÷|²v>žOúTäÇ­u7oW¨ì픵
                          gÒ~¨;qƒÂ¾‡Öš¼xI3éBŸÜ¨s´À³ØM~Ó§½Ýþ32‡
                          ér›5µ}7A3\†•—%¢U|â©AdÙ~YRÞ"9H éÊ'Ûi[ït<œŽhÁšÀFîm«3#½ÒÂ… g|­`?ò¸»ð”}ÍyÒ„
                          €¬[¨¹µ_ƒÎ»–},­šÎs`Ó ‰<˜^V¶ÆÚ„SvÚì‡	‚xÖPSÒ ×
                          x»šPé š³ãȪm‰ãžgA
                          3jÕ²åRlñm®ü¶’èjUÞB(Ùôtí‹êÿ—.‰ßÓµym0Sê1š²ßö€ïmLN¾¦è&O2S—Úý¦Mi©Í²=7QÔ¡”§l“Œ[„ƒwô•Õ&Ñö§,,t6F;z4Ù*”Š5ÃmÒV[“Ý§Š®¹W©}
                          5N|…J’/«$ù’J’-3Å.E¹·Hë¯üîm’ÃNxLÃçÁ¶7[_%ïÒëñà}‡hçˆ4i·/ôh¨U61m¦|ˆfX³Bq$ÆG/ñ#Nxm™Ñlöòüõ‹Ùlì;uÛ{”Í(ú£íX]¢×;‘«×Ä;9	;›ÀíµH’@„­0¼áúÒ5ónnæÎÄÿPK    쉄B4‹"Ût
                            $                  gradientator.rbPK      =   ¡
                          -Mark
                            An RBZ file is a type of Compressed ZIP file - hence the PK at the start of the opening in Notepad++
                            You cannot edit it that way.
                            Take the RBZ and install it, that should leave you with an RB file containing the script's code.
                            Edit that RB file as explained in earlier posts, using Notepad++.
                            Replace that RB in the Plugins folder and restart SketchUp to se the changes.
                            An alternative is to use the RB file directly, or rename the RBZ with a .ZIP file-type suffix and extract its contents.
                            The result will contain the RB code file etc - proceeded as directed previously...
                              sywong425 Newcomers
                              how do i install this plugin to SketchUp pro 2022? i tried to add it from extension manager but it didn't appear after i enabled it.
                                Scroll up a few posts to one made by SDMitch which shows the fix to make this work. I haven't tried it in SU2022 but I'll give it a try.
                                • 3 / 3
