    [Plugin] Gradientator v1.21
    54 Posts 24 Posters 50.1k Views 24 Watching
      stuartmitch
      @steve r said:
      It seems like the issue you might be having is with the number of faces. This plugin only applies one color to one face at a time, and doesn't sub-divide them. In the picture you've provided, it looks like you've got two different applications of the plugin, but each time it's to only three faces. So, Gradientator sees that you've got three faces selected, and just applies the three colors; no gradient needed. However, with more than three faces, it will begin to gradient to greater degrees. So, trying to replicate your image with more faces:
      http://i.imgur.com/MpHENl.png
      As you can see, it's still applying those three colors, but the "in-between" faces are getting the gradient colors, or colors that are in-between those main colors. So, the amount of gradientating you'll get is dependent on the number of faces you select at one time. Does that help?
      Steve,
      many thanks for clarifying that for me. I had missed the point that I needed more than three faces. From the initial illustrations it had looked like only 1 face was having colours gradiented (no such word??) across it.
      I've got it now. Just needed to be belted on the head a couple of times!
      Cheers...>Scotty
        chuzhuo
        its so cool!
          leefordjudes
          It shows an error on sketchup 2014
          Error Loading File gradientator.rb
          Error: #<SyntaxError: C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/gradientator.rb:79: formal argument cannot be an instance variable
          ...ck("get_data") do |@grad_dialog,action_name|
          how to
          • sdmitchS Offline
            sdmitch
            how to
            Using Notepad or similar text editor, simply remove the '@' in |@grad_dialog,action_name| in line 79 to this
            @grad_dialog.add_action_callback("get_data") do |grad_dialog,action_name|
            http://sdmitch.blogspot.com/
            • BoxB Offline
              That works, Cheers Sd. 👍
                dtrarch
                Thx a bunch Mitch.
                Just plain fun to mess with. 👎 👎
                Works too ☀
                dtr
                • bomastudioB Offline
                  bomastudio
                  In SketchUp 2015 I get the following error after the install:
                  Error: #<SyntaxError: C:/Users/nessuno/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/gradientator.rb:79: formal argument cannot be an instance variable
                  ...ck("get_data") do |@grad_dialog, action_name|
                  C:/Users/nessuno/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubytoolbar/rubytoolbar.rb:144:in load' C:/Users/nessuno/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubytoolbar/rubytoolbar.rb:144:in rt_load'
                  C:/Users/nessuno/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubytoolbar/rubytoolbar.rb:190:in block in <module:RubyToolbar>' SketchUp:1:in call'
                  I solved changing row 79 to the end of the do block in this way
                  @grad_dialog.add_action_callback("get_data") do |grad_dialog, action_name|
                  			if action_name == "begin_gradientating"
                  				@grad_dialog = grad_dialog
                  				@coloronename = @grad_dialog.get_element_value("color_one_name")
                  				@colortwoname = @grad_dialog.get_element_value("color_two_name")
                  				@colorthreename = @grad_dialog.get_element_value("color_three_name")
                  				@grad_dialog.close
                  				gradientate(@coloronename,@colortwoname,@colorthreename,@faces,@model)
                  			if action_name == "close_this_window"
                  				@grad_dialog.close
                  • utilerU Offline
                    utiler
                    So do I. Would love to try this plugin....
                    Just Curious...
                      Andrew, did you try the solution offered by sdmitch? I just tried it and that makes it work in SU2015.
                        The post just before yours offers a solution http://sketchucation.com/forums/viewtopic.php?p=575140#p575140, and @sdmitch gave an even simpler version a few posts earlier http://sketchucation.com/forums/viewtopic.php?p=541222#p541222
                        Just edit the RB using a plain-text editor like Notepad++, then find the do |@grad_dialog, text around line #79, and remove the @ so it's do |grad_dialog,.
                        Save the RB and restart SketchUp...
                        Since the @grad_dialog is defined earlier it is not necessary to redefine it in the do block, so using ANY name which doesn't start with a @ will work !
                        • utilerU Offline
                          utiler
                          Thanks Dave / TIG. Trust me to jump into a new plugin without reading through recent posts.... Cheers, I'll give it a crack tonight!
                          Just Curious...
                          • utilerU Offline
                            utiler
                            😉 Worked a treat, guys. Thanks!!!
                            I'll post in a few days what I needed it for. Glad to share.... 😉
                            Just Curious...
                              Works fine! 😄
                                GianfrancoGalli
                                hi, just landed on this post. the plugin is not working in make 15/16. i can select it in both Make 15 as 16, but it's not doing anything.
                                i've used v1.21. downloaded it to C:\Users\YOUR USERNAME\AppData\Roaming\SketchUp\SketchUp 201X\SketchUp\Plugins
                                thanks for your thoughts!
                                • sdmitchS Offline
                                  sdmitch
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=45951%26amp;p=601292#p541222
                                    JaysonBata
                                    why is it not functioning to my sketchup 2017? 😞
                                      The script needs some editing to work. Scroll up a few posts and read what sdmitch wrote. Edit the .rb file to make that change and it'll work. this is in SU2020 after editing the script and installing it.
                                        dlightsey
                                        Does anybody have the repaired file. When I open the RBZ file using note pad, I get a bunch of garbage. I have tried all the standards when opening.
                                        Thanks,
                                          Download the .rb file from the first post of the thread and make the edit according to the this post.
                                          • I Offline
                                            its3Dmade
                                            I have tried this fix but when I go to notepad or any word process to open I get this -(on PC)
                                            PK   쉄B4‹"Ût
                                              $     gradientator.rbYûsÛ6þٝéÿ€Ò7gi,ÓŽÓÞñܼsžKš'éM'ÓÑ€$(¡¦­¸±ÿ÷û IP–œô&±FÝÅ>¾}p—½_Èšá?gµ\V…`F©¬Ò*Y£yQ\³¹(…æF`›Yh!RU(ÍæšgR”†©’-EÍTÎržŠ;þö›]öÊïàÛ“kVq%˜&Ž…LEY‹Œ5e&4Î?Ó‚‰ÇÏÔr©Êš=1Fˤ1R•?©’–…N%/Þ-¸O
                                            y)ØÃøˆ}(+¥
                                            H½v4‰5qÙh³z©´˜@p0­UnV8Kà†W2鈓
                                            "ÆËŒ­¤Y¨Æàû5Ÿ*-jÜòB7[qVóÒàž&Ë´h2YÎ'í)âYÈ¥Äu!3±N’†è"üä‰,¤¹¶¬siJb—+ÒFŵ‘iSpͪFW*¸žÓ•  ¶.-/²€½`U4s	Ö0%¯»’µ4laLurxˆÝͲŽëKaÒE“Úƒqª–‡WR¬ŒªdW‹êÇ|úðøá_ÍôûþùÃÏs`Ç«ñqûàg¡kâ_*#ê¿h7ÐvÀžd¤â«p›{ð†g‚ýW$ÏaP5gдüƒ',EÊ0ð;¡ã€ §÷j›E®%m¯ÉYeY^¦¢_õ<T&sÒ>Ybů™õ[x;´—ò‚Ô·yÄæ
                                            '㢆¹Ôµ™°¥Ì²Vž‚צ=½’EÁCÍÒS’gÓ¹¦v"bÒòyY5&QŸHRÞ_Ù¹Íæ@ËX¦Uu©ˆ«O.š¼&Z;”Ÿ°IæÏYÂ3Hþ’<…óà6£•æU…mÎ/ (Xª¬¡{Á
                                            Æ¡‘8=÷¢rcEON•D“d/
                                            µê.J+µ(DêvZ\h5$K»ÖâCÈ$z.½­r­–ì­–à‘.y'KxÊbö¦IÁ°ƒƒ4…©¿cïEŸ”rä•ò”×2e0fâCþ";øEÐ^Ëe'«*‹ëo¿ùö-~o$übÏÇGëd8u±w³0
                                            èÉÎ.„1†Ôóó‹‹§oß½ ¥”² j]	Ü;Q
                                            ddåîýʾàf‘4>vÁ ŒKæƒLðÿ/-ù)Q·¬3‘“úóXU¢\IÜw5‚5whûN—éB¤—äp×LUäY–ÿ+¥æ…ðäwûøœy%d`ô÷øÈ2Ú‘9½kuâ7ÆFÍrvÊî´"Xš;Îã%ð†‚C¢_TÖ
                                            t°àWÝe+±ý»Tˆ|éS7l‹ÙÏÔ;3ÍÝU d´»©Èê"Žœ$Z˜F—P¢ÌZ=†]E‹vw£ ¹3»Þki'‘¥p©š\ßgPºvv"ÑŒÐ~É/q$™b{`=JmÊc
                                            ܆¼«;#õ
                                            †` ¸š}8gyÁçä7µ0t÷ºläî­‘4KS{I?xjªŒ[ßsÖ¯)†ˆ“u¨­»µ6ÅkAâC¸Mà•Ú•‰;E¶¥53µ¤¿/¹f ÈQ­CÅD}´àg„lˆj½N‹ª™/<Ø¤É3BMÜ‹$çä. °’Tȵ•…ÃQ„¯?ÓKâOY+RKÕûÌnÄ
                                            ±¬güÇΧON^âØ˜ÝöÂ]X¯©	…Ö”ÿó÷2™•{¦Å>*,Û	ëö][Pñ; ÑL[9Øç„QÎáWÓ);Ú;ïq$á.ÃìnÓ_«†Jro|e+ÕÈ`T-‘æª
                                            ²`k”O¹¨¹#‡\!ùœSÔ±—ôrByãä¡«w*ö˜ílf3$/ê.CˆlNrŠ£öwŸH£¨ŽIm”óRiç‡á‡ípðnT[DFh„‰ÖûNCÅ&WÖŠ6Ó¹èÝÁ~¿»¸+Œ4”+ð7WŸh$ÅÚèkv	Kûç+™™Å„-„œ/P…Èñ‰šjÒ6½›’êg™ã5eÎON;Þq)V£(¼7"'‡*Á#Â×ãMØÃ#|ÿ
                                            ¾?r5^'—7³„§—sDX™Íl¶EÏÒ¿(Èï­AìUÂâœÁÇ­ôj!¡ôIe
                                            ¡©ü|„£v–CE!©ÞvUàpUŽ«¥Ó5Óia5fÜúØŒØÐFÑ·üñhÌ2Ån¿¹äKqãRÅ[°JÑY!gó¤Êyd÷ºÜyl5¦JáN°LÄž
                                            ,5³+^4bÙí3ì·,¼³z*f¥þìßD…J¬?G‡N)…ç¬%Üz¯1Ü|2¸ÁdM’‰C±‰Üq ?“;ÛÔoyÏgfÎøCåoóéAè¿òÕ³-¾Ð;RÙê|ºÒ²¦Î«t¿
                                            ^vPaQš Œö±?JÐùÚ\Sšâs›uPt¡p•qZ®¤³‚£\õ¨9øu)#儬hAÚ rGP+]t^—`6îýß>§Žñ;(PNNžÑrL;¬í¶…Yv«•Z6PˆI,—úz‹<6bY9)60+æ¾Æa,Ný­£M÷¢}±í9=M{¥¸	Á‰ž'£h¿g·ÅÝ~4¬ÏÉ¡6>IÀÆ?ŸYn§‡N„³ˆµ×
                                            r·hPö$õŠ<¶ª³)¯3ý¿Þ¿y.ÏŽ;ºÔà!«‡â!‘& «½SúrvJÕRc^WbñÉþƯ¸[Îò¦tY‘ë¢I®	ÑGcöù÷Fh²iT_V'-ˆ=¦"x# =òÀX(ß®#ðr·dÝÞaóŒBå|îFÞ¸œºk¦Lè³ÓÄý½sÉÝ;
                                            {pÂ;õù^fÓu@<ÛÛzÓþÛí›	o&ØaãŸ&øpÁ$¿†ä©«œá“Æ ýŽ ,i Ɂ½#%{ûoûWöVìO?£†¹ …NˆÃÖ‡Ö÷6fN*èñ¨÷à
                                            uÂB­¨çáE×?TÙ.{O€Ú¶F3ìAÃì1HƒÜ±–;\æè‡ß'†Bß´5&E¤ƒòÚu=ú»ºÙd×9k«ä7˜­Ž·óZìQž@a‚Úl9a°;vL‹>9¸R°R•9IZ~{TsÃ%/<럠íÁ‰­£°£T†æ‰® ÉÉ"(wlä·?úÂc2‡
                                            @Ë÷ðF؉Í}GZSÙCðÛšE]¬ï~帝°‹WOiµ“ž ËáŠùµ5‚÷Ûè‡ãŽƒ|–×8ÐÊ;ZÛÂáaÏ¡½çô`‹]»ÃÇ®öœè…ê;ލMÝ`¤ŠžÒºuèóRþ!l©‚è³­œ›T}õÕAÙó)M/©0S1Í+™!ÝفÍ&ºz£¦QÚJ—ç–èêÚõQ7£Aùªkq©Éæ1gP«@?õBæ†Ã—Fã°6p‡ñáhv½vŠ4><è$Ö %Où~JÖ;›d²RÙ•¯¥vG²!½ŽÃýôÈK6	GëÙhá+IÝ‘l@¬¥~/±Ö—º
                                            W–Ò e Ã]HT·mË.~o¸}Oä‹ßR"ᅝñN‡`öJÝ´«+ó¶µUa¾VøýFÆK!*ÔëÕ(ÅEEÎ5ÂAÑ´Ì5»[Ô°oÕÁõA0\€2ý”M‹+©š‘Ö”Jg‚¼ÔM`\桤 (éøŸíQ6+;‘;2
                                            T¬W¦9…íïig?(*ël)×}6¼8NД}¶%²³¾mnèû
                                            s>ҏ_§o/Î_ÿ·òYg‰ªçëØãžÙÃŽkh…¡Ãà“ä†ñ~e§Ó3–ЗÛxÉ+zVÞ°òãѯá”íCyàæ‘ÆO…h8“‰¤™Ïí[÷Ú‹Þ´å¬Ú8ñGŽ¿´Rì~]ú–-x‘cñ®£ÃÏcÛ›8ˆÞ
                                            ’Qñï £ÅõÖÓnÏÏTƒgÇá3ŠÁÛ8äó„½£@uœ<`ÚXÙß=<ä|z÷|²v>žOúTäÇ­u7oW¨ì픵
                                            gÒ~¨;qƒÂ¾‡Öš¼xI3éBŸÜ¨s´À³ØM~Ó§½Ýþ32‡
                                            ér›5µ}7A3\†•—%¢U|â©AdÙ~YRÞ"9H éÊ'Ûi[ït<œŽhÁšÀFîm«3#½ÒÂ… g|­`?ò¸»ð”}ÍyÒ„
                                            €¬[¨¹µ_ƒÎ»–},­šÎs`Ó ‰<˜^V¶ÆÚ„SvÚì‡	‚xÖPSÒ ×
                                            x»šPé š³ãȪm‰ãžgA
                                            3jÕ²åRlñm®ü¶’èjUÞB(Ùôtí‹êÿ—.‰ßÓµym0Sê1š²ßö€ïmLN¾¦è&O2S—Úý¦Mi©Í²=7QÔ¡”§l“Œ[„ƒwô•Õ&Ñö§,,t6F;z4Ù*”Š5ÃmÒV[“Ý§Š®¹W©}
                                            5N|…J’/«$ù’J’-3Å.E¹·Hë¯üîm’ÃNxLÃçÁ¶7[_%ïÒëñà}‡hçˆ4i·/ôh¨U61m¦|ˆfX³Bq$ÆG/ñ#Nxm™Ñlöòüõ‹Ùlì;uÛ{”Í(ú£íX]¢×;‘«×Ä;9	;›ÀíµH’@„­0¼áúÒ5ónnæÎÄÿPK    쉄B4‹"Ût
                                              $                  gradientator.rbPK      =   ¡
                                            -Mark
                                            • 3 / 3
