[Plugin Library] LibFredo6 - v14.4c - 18 May 24
Did you reboot your Mac?
hallo , i have install on my Mac book last version of fredolibrary and new version of fredo corner, but have an error,
the precedent version goes whiteout any problem.
the error message after install and restart sketchup are the follow:
Error Loading File Fredo6_!LibFredo6.rb
Error: #<LoadError: dlopen(/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
Referenced from: /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
Reason: image not found - /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
/private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire' /private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in
require'
/users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:inload_binary' /users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:in
startup'
/Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:inprocess' /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in
module:LibFredo6_Loader'
/Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>' -
I am merging this into the main thread - where Fredo is more likely to see it !
thanks , sorry I don't see an other post exit.
for fredo6,
i ave look your message but system say I'm not able to reply at PM
last update I have manual cancelled any files of fredo lib and reinstall,
now go
NEW RELEASE: LibFredo6 v11.1c - 08 Sep 20
LibFredo6 11.1c includes various bug fixes.
It looks like I completely missed LibFredo6 v11.1b, thanks for the update.
Error: #<ArgumentError: invalid byte sequence in UTF-8>
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:ingsub' c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in
get_dir_from_ENV'
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:insu_appdata' c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in
dir_appdata'
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:instartup' C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in
process'
C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in<module:LibFredo6_Loader>' C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in
<top (required)>'i experienced load errors.
Plz tell me how to fix it -
Fredo will reply in detail, but it looks like your Korean user-name [정영호] is causing the issue.
Ruby expects any text-strings to be UTF-8 encoded.
In earlier Ruby versions non-ASCII characters always caused problems.
In the newer versions of SketchUp there is text-encoding possibilities.
I know Fredo uses these latest methods.
But somehow your Korean user-name is almost certainly causing the problem... -
Hi. Im having a trouble finding the file via extension manager. The files are in .rbz.skp, how can I convert it to purely .rbz file?
Why are the files .RBZ.SKP ??
A downloaded .RBZ file from the PluginStore should be saved with that file-type.
How did it get changed ?
I suspect your web-browser settings for downloaded file-types are FUBAR...Alternatively try renaming it without the .SKP ending and then the .RBZ file might be usable...
However, you need to fix your download options...
NEW RELEASE: LibFredo6 v11.2a - 27 Sep 20
LibFredo6 11.2a includes technical adjustments for some dialogs.
@fredo6 said:
Iain
One thing to check is whether the binary file has been successfully copied.
Could you do the following in SU2019
Open the RubyConsole
Type
File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles')
The console should display the result, something like
/var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles -
Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
If you open the directory in the finder, could you check if there is
- a subfolder: binaries
- and within it a subfolder SU19 with a file bin_LibFredo6.bundle
If there is no file, then we have the explanation. This might be a problem of security settings.
If there is a file, then this is another problem.
The same problem. But in the folder Binaries\SU19 i have a file bin_body_Lib6G6.so
NEW RELEASE: LibFredo6 v11.2b - 09 Oct 20
LibFredo6 11.2b includes technical adjustments for video generation used by Animator
NEW RELEASE: LibFredo6 v11.2c - 11 Oct 20
LibFredo6 11.2c fixes a bug in the generation of videos for Animator (.MOV format can now be excluded)
I've installed several extensions plus Libfredo6 months ago, and they all worked well,(thank you).
Today they do not work. Please advise. -
Today they do not work. Please advise.Maybe you can indicate which one and give more info on the issues. This would help....
instale el plugin y no funciona
LibFredo no hace nada por sí solo, ayuda a sus otras extensiones ...
¿Cómo no funcionó?
¿Reiniciaste SketchUp para sincronizar cosas?
Ayuda a Fredo, ¡no es un psíquico!
The LibFredo does nothing on its own - it helps his other Extensions...
How did it not work ?
Did you restart SketchUp to sync things ?
Give Fredo some help - he is not a psychic !
