๐Ÿ”Œ Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Advanced roof
Scheduled Pinned Locked Moved Organic Modelling
19 Posts 6 Posters 13.9k Views 6 Watching
  • E Offline
    Epix3D
    Working on a complex roof trying to skin profiles without sucess. Maybe I am using the wrong tools using Fredos Curviloft? Can someone show me how to do it?
    Contours for skinning
    SketchUp file
    • H Offline
      HornOxx
      ... Hi, down-saving to some much earlier skp-file than SU2020 could give more people the chance to look ๐Ÿ˜‰
      never trust a skinny cook
      • E Offline
        Epix3D
        I found out. Seems like profiles was not touching eachother.
          You beat me to it, but I'll post it anyway.
            I can't load the SKP but here an another method ๐Ÿ˜„
            Extrude Tools by TIG
            • E Offline
              Epix3D
              Well, I still have some problems with constructing this. Here is a screenshot of what I am trying to achieve:
              I am trying to recreate this model which is a big 70mb imported inner ceiling from a CAD program. I want to recreate in SketchUp and reduce it to a visually minimum so it can be easily maneuvered in SketchUp.
              I meet a problem with construction going outside the expected result + constructing the ends of this banana shape. Can anybody see if it is doable?
              Here is a link to the original file in SKP2017
              https://www.dropbox.com/sh/tczxh7b53vzrnrc/AAAeyOYinR6WoN9dj_672rEBa?dl=0
                  Why recreate ?
                  Absolutly no problem to reload it (few minutes (3 - 4) of course so be patient ๐Ÿ˜„ and Move / Rotate etc...(2017 Make)
                  You can also ask only "wire frame" if you have some problem of display speed...!
                  (and remodeling from the wires if absolutly necessary)
                  And / Or Use something like Skimp for avoid to re-modeling! ๐Ÿ˜‰
                  • E Offline
                    Epix3D
                    This model is part of a big (400mb) model so I am reducing size all over. I have/use Skimp and it does a great job reducing the model but I am also looking for a cleaner model without the triangulation. I think I am onto something now modelling it part by part and merge together with Solid Tools. Itยดs a job fixing the overlapping geometry manually ๐Ÿ˜‰
                      If there is a triangulation visible that signify that your faces are not planar! ๐Ÿ˜„
                      So not an easy job for clean all that! Some arcs edges must be // etc ...
                      Even the TIG Extrude Tools who can show quads don't make specifically "planar faces" ! ๐Ÿค“
                      When hidden geometry is asked...
                      https://images2.imgbox.com/f2/46/hLV3Jmeu_o.jpg
                      • E Offline
                        Epix3D
                        So I come to the point where I have managed to create a reduced model in SketchUp.
                        Now the challenge is how to paint the model with right UV pattern. Iยดve tried with Thrupaint and SketchUV with no succes. The pattern should be horisontal following the shape both outside and inside. Size is O.k, but how do I make the texture continous?
                        New SU Model attached
                        https://www.dropbox.com/s/bzcs7bgplhqesl3/InnerCeiling.skp?dl=0
                          tuna1957
                          Took a look at the last model you posted. I think the crazy mesh may be causing your texturing difficulties. Re-skinned a section of the roof using Curviloft. Had no problem using Thru Paint on the new mesh , painted with the quad face painting option. Texture follows the curve no problem. There is some squeezing of the texture at the smaller end but that is expected. Posting some images , hope they make sense.
                          • E Offline
                            Epix3D
                            Sorry, must have linked to the original model. The reason for remodelling was to reduce model size. This is part of a big model 400mb which so far I managed to reduce to 55mb.
                            Here is a snapshot of the curviloft model which was further reduced with Transmutr.
                            This is the model I am trying to texture
                            https://www.dropbox.com/s/8905ybp61tf4gn7/CeilingUV.skp?dl=0
                              tuna1957
                              Suspected you might have linked to the old model... Can't have a go with the fixed model you linked, it's a 2020 SU model. Back save it to 2018 or earlier and I'll have a go at it. Quick question.. just how large do you want that texture to look ? It has all those "form board" seam in it.
                              • E Offline
                                Epix3D
                                Size approx which is on the model allready
                                Here is the model in 2018 version. I appreciate your effort ; )
                                https://www.dropbox.com/s/rb0ujv4crwhmj04/CeilingUV2018.skp?dl=0
                                  tuna1957
                                  Hope somebody smarter than me comes along with a fix for you. Messed about trying different approaches. Only met limited success. ๐Ÿ˜• Was able to get a decent result on the sloping sides using ThruPaint ( quads , Face by face mode ). Could get the lower curved section using native Paint Bucket tool . Worked straight down from the slope , sampling the face painted with ThruPaint. Texture followed the curve o.k. minimum distortion. Big trouble was the ridge and the end pieces. The mesh has enough irregularities that I wasn't able to get a decent result. Posting a couple of images . Hope to clarify what I tried. Second image I highlight some of the mesh issues that make for the difficulties. Got to say short of a total work over of the mesh to make it more "texture friendly" I think I'd paint the whole thing a nice uniform concrete color and call it done.....
                                    Maybe ?
                                    Click the link for see the video! ๐Ÿค“
                                    • E Offline
                                      Epix3D
                                      Thank you for the tips ๐Ÿ˜‰
                                      I see, -itยดs all about modelling to get a clean model. However in my case itยดs all about polycount to keep the size down. I know the model is abit rough but my goal is a visually manueverable model much smaller than the original which is very accurate but much too big.
                                      • N Offline
                                        nlipovac
                                        I used Curviloft to create skin then add some cut loops to get more polygons so ThruPaint can texture skin with great precision.
                                        After placing textures and creating holes in used Transmutr to reduce polygons and keep texturing intact.
                                        Your finished model skin is not continuous and there is a great deal of holes and internal faces so I do not see a way for you to get great UV texture on that roof.
                                        Hidden lines on
                                        Smooth shade
