    Advanced roof
    Scheduled Pinned Locked Moved Organic Modelling
    19 Posts 6 Posters 16.2k Views 6 Watching
        Why recreate ?
        Absolutly no problem to reload it (few minutes (3 - 4) of course so be patient 😄 and Move / Rotate etc...(2017 Make)
        You can also ask only "wire frame" if you have some problem of display speed...!
        (and remodeling from the wires if absolutly necessary)
        And / Or Use something like Skimp for avoid to re-modeling! 😉
        • Epix3DE
          Epix3D
          This model is part of a big (400mb) model so I am reducing size all over. I have/use Skimp and it does a great job reducing the model but I am also looking for a cleaner model without the triangulation. I think I am onto something now modelling it part by part and merge together with Solid Tools. It´s a job fixing the overlapping geometry manually 😉
            If there is a triangulation visible that signify that your faces are not planar! 😄
            So not an easy job for clean all that! Some arcs edges must be // etc ...
            Even the TIG Extrude Tools who can show quads don't make specifically "planar faces" ! 🤓
            When hidden geometry is asked...
            https://images2.imgbox.com/f2/46/hLV3Jmeu_o.jpg
            • Epix3DE
              Epix3D
              So I come to the point where I have managed to create a reduced model in SketchUp.
              Now the challenge is how to paint the model with right UV pattern. I´ve tried with Thrupaint and SketchUV with no succes. The pattern should be horisontal following the shape both outside and inside. Size is O.k, but how do I make the texture continous?
              New SU Model attached
              InnerCeiling.skp
              Shared with Dropbox
              Dropbox (www.dropbox.com)
              • tuna1957T
                tuna1957
                Took a look at the last model you posted. I think the crazy mesh may be causing your texturing difficulties. Re-skinned a section of the roof using Curviloft. Had no problem using Thru Paint on the new mesh , painted with the quad face painting option. Texture follows the curve no problem. There is some squeezing of the texture at the smaller end but that is expected. Posting some images , hope they make sense.
                • Epix3DE
                  Epix3D
                  Sorry, must have linked to the original model. The reason for remodelling was to reduce model size. This is part of a big model 400mb which so far I managed to reduce to 55mb.
                  Here is a snapshot of the curviloft model which was further reduced with Transmutr.
                  This is the model I am trying to texture
                  CeilingUV.skp
                  Shared with Dropbox
                  • tuna1957T
                    tuna1957
                    Suspected you might have linked to the old model... Can't have a go with the fixed model you linked, it's a 2020 SU model. Back save it to 2018 or earlier and I'll have a go at it. Quick question.. just how large do you want that texture to look ? It has all those "form board" seam in it.
                    • Epix3DE
                      Epix3D
                      Size approx which is on the model allready
                      Here is the model in 2018 version. I appreciate your effort ; )
                      CeilingUV2018.skp
                      Shared with Dropbox
                      • tuna1957T
                        tuna1957
                        Hope somebody smarter than me comes along with a fix for you. Messed about trying different approaches. Only met limited success. 😕 Was able to get a decent result on the sloping sides using ThruPaint ( quads , Face by face mode ). Could get the lower curved section using native Paint Bucket tool . Worked straight down from the slope , sampling the face painted with ThruPaint. Texture followed the curve o.k. minimum distortion. Big trouble was the ridge and the end pieces. The mesh has enough irregularities that I wasn't able to get a decent result. Posting a couple of images . Hope to clarify what I tried. Second image I highlight some of the mesh issues that make for the difficulties. Got to say short of a total work over of the mesh to make it more "texture friendly" I think I'd paint the whole thing a nice uniform concrete color and call it done.....
                          Maybe ?
                          Click the link for see the video! 🤓
                          • Epix3DE
                            Epix3D
                            Thank you for the tips 😉
                            I see, -it´s all about modelling to get a clean model. However in my case it´s all about polycount to keep the size down. I know the model is abit rough but my goal is a visually manueverable model much smaller than the original which is very accurate but much too big.
                            • N
                              nlipovac
                              I used Curviloft to create skin then add some cut loops to get more polygons so ThruPaint can texture skin with great precision.
                              After placing textures and creating holes in used Transmutr to reduce polygons and keep texturing intact.
                              Your finished model skin is not continuous and there is a great deal of holes and internal faces so I do not see a way for you to get great UV texture on that roof.
                              Hidden lines on
                              Smooth shade
