    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 608.6k Views 92 Watching
    • N Offline
      nlipovac
      Finally, I can move vertex along edges. Yay!! πŸ˜„
      Thx for customer discount.
        Vertex Slide is my personal favorite. πŸ˜„
          rv1974
          Amazing product in every aspect Thomthom πŸ‘
          • N Offline
            nlipovac
            Well, I reallllllllyyyyyyy love Vertex Slide A LOT!
            Still having some pole issues but this time I have patients to finish it.
            Control mesh
            Subdivided
            • HornOxxH Offline
              HornOxx
              ... for Dummies like me πŸ˜‰ - do I have to uninstall the previous vertex tools somehow before or does the new version overwrite the old one?
              EDIT:
              I have found the answer to my question πŸ˜„
              https://evilsoftwareempire.com/vertex-tools/manual/getting_started#updating
              never trust a skinny cook
                I want to find a 3D printing service that can make this in ceramic for me!
                Version 2 can be installed side by side with version 1. (But v2 got everything v1 got - so I don't see the need.)
                • N Offline
                  nlipovac
                  I found this one in US.
                  https://kwambio.com/
                    Can you share the 3D model with me?
                    • N Offline
                      nlipovac
                      Sure, IΒ΄ve sent you a PM with the model.
                        rv1974
                        tessellated variant will look more interesting. it'd be neat to print before\after subd set.
                          kaas
                          Nice update and generous to give a discount to existing users. πŸ‘
                          • cmeedC Offline
                            cmeed
                            Love this - a fantastic update..
                            Loving the vertex slide. question - Can we copy the vertexes along the edge?
                            the cursor changes, adds plus and minus with the addition of shift. I assume there isn't a copy function? (yet?)
                            Fantastic Extension - Professional in every way - I feel spoilt.
                            Cheers
                              That's interesting. I'll have to think a little on how that would technically work. But I logged it for consideration. πŸ‘
                              • CadFatherC Offline
                                CadFather
                                when i choose the select tools from the menu, I only get the rectangle selection.
                                works fine from the panel though
                                (fantastic update btw)
                                  Menu or toolbar? Exactly what item do you select? Can you do a screenshot for me?
                                    CadFather
                                    Menu. same thing if i assign a shortcut to them (polygon, freehand, etc)
                                      Ah! I see the same thing. That's a bug - thank you for reporting!
                                      • cmeedC Offline
                                        cmeed
                                        this has probably been asked before - can I move the gizmo and have it snap to a point? in 10 years of questions I think this has been asked.... 'negative' will be the answer.
                                        maybe i need to ask why cant it?
                                        cheers
                                        c
                                          Not so.
                                          Right click on the gizmo, choose the option and hold Shift while clicking to place it.
                                          Click on the picture
                                            Because it's not been entirely clear what to snap to. The user grabs hold of the gizmo which is offset from the gizmo origin, so is snapping supposed to snap the origin to the point snapped? Or the point grabbed?
                                            There's been some conversations about this - this thread for instance: http://sketchucation.com/forums/viewtopic.php?f=323&t=66039#p606094
                                            Snapping is described to relate relative to the gizmo origin, and with improved control of setting the origin.
                                            If you have your own idea of how snapping should work with the Gizmo I'm happy to hear it. I'm not sure everyone has the same expectations on how this would work.
                                            Because of that the separate Move/Rotate/Scale tools has been the main means of precision adjustments. While the gizmo is more eyeballing it.
                                            I'd be curious to hear why you prefer the Gizmo to snap as oppose to using the separate Move/Rotate/Scale tools. (Maybe there's some improvements with them that you achieve the same thing?)
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 30 / 34
