    JHS Powerbar 2020: bugs
    extensions
    17 Posts 10 Posters 14.2k Views 10 Watching
    • O Offline
      optimaforever
      Hello all,
      I just installed the JHS powerbar in SU 2020 Pro and so far, I got one bug (but an annoying one):
      When I use EXTRUDE LINE (by Didier Bur), SU hangs when trying to extrude more than one line at once.
      Previously, I had no problem doing that (2015 2016 2017 2018 2019).
      Now I must be aware that SU crashes (or hangs for eternity) when doing that.
        rv1974
        almost for sure you have faulty linework
        • O Offline
          optimaforever
          Did you try? trace 2 separate lines and try to extrude them?
            rv1974
            it's ok on several PC's (I use independent (from powerbar) same-named plugin BTW.
            • O Offline
              optimaforever
              Ah thanks. I'll try to install it independently.
                Kiranbabu
                Hi,...
                i am trying to install JHS Powerbar for sketchup 2020 ..but is show errore message
                Error Loading File /Users/froyobabu/Library/Application Support/SketchUp 2020/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
                Error: #<SyntaxError: /Users/froyobabu/Library/Application Support/SketchUp 2020/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:298: Invalid return in class/module body
                return if not settings.include?("tr...
                /Applications/SketchUp 2020/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require' /Applications/SketchUp 2020/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load'
                /Users/froyobabu/Library/Application Support/SketchUp 2020/SketchUp/Plugins/_jhs01_powerbar.rb:16:in register_extension' /Users/froyobabu/Library/Application Support/SketchUp 2020/SketchUp/Plugins/_jhs01_powerbar.rb:16:in module:JHS_powerbar'
                /Users/froyobabu/Library/Application Support/SketchUp 2020/SketchUp/Plugins/_jhs01_powerbar.rb:8:in <module:Max_Coppoletta>' /Users/froyobabu/Library/Application Support/SketchUp 2020/SketchUp/Plugins/_jhs01_powerbar.rb:7:in <top (required)>'
                can you hlpe me how to fix this
                  gavin712
                  @optimaforever said:
                  Hello all,
                  I MET THE SAME QUESTION,HAVE U SOLVED THE QUESTION?
                    What version of SketchUp are you using? Your profile says you are using SketchUp 8. Is that correct? If not please update your profile.
                      In more general cases about Didier Bur's Plugins i am affraid that he will not more update them! 🤓 From 2020...and following!
                        @kiranbabu said:
                        Hi,...
                        There are two versions of the JHS Powerbar extension.
                        The version that is compatible with v2019, AND therefore v2020, does not include that troublesome 'return' in line #298.
                        So I suspect you don't have the correct version installed ??
                        https://sketchucation.com/pluginstore?listtype=1&author=0&category=0&search=power+bar&submit=%3F
                        You might need to manually remove the incompatible RB loader and subfolder before installing the good version [e.g. if you get on going issues]...
                          gavin712
                          SKETCHUP 2020 PRO
                            See my recent post about the two versions of this tool...
                            Ensure you have the >=v2019 compatible one...
                              mcristhine
                              I have the same problem but I cant install JHSPB... as soon as I open the instal window, I cant see the version! Im using skp Pro 2020 and I found "Version made compatible for Sketchup 2019".
                              may anyone help me? thanks!
                                The PluginStore version:
                                https://sketchucation.com/pluginstore?pln=JHS_Powerbar_2019
                                Should let you download an RBZ file.
                                This can then be installed using the native Extension Manager dialog's red-button...
                                I can't understand why you refer to 'version' ?
                                After clicking the red-button, then navigate to the downloaded RBZ file, choose it, and it's installed for you...
                                Works fine for me...
                                  anthonywong92
                                  Hi all,
                                  I've installed the JHS 2019 version but when installed on SU2020, I am seeing 'unsigned' under the extension manager. Does anyone know how I could go around this?
                                  Thank you!
                                    There's nothing to "go around". Just ignore it. As long as you leave the loading permission set to allow the extension to load, it'll be fine. Not all extensions are signed but as long as they come from a trustworthy source such as Sketchucation, it won't be a problem.
                                    By the way, since you are using SketchUp 2020, please update your profile.
                                      PTraveler
                                      Hello all,
                                      I had/ have the same problem with SU 2019 and now with 2020. I am aware that JHS is not updated for 2020.
                                      Crash occurs usually when I want to return/ undo the last command, or do work to fast and the I get unwanted lines. My solution is to work slow and save at each step.
