    Styles won't save? YES THEY DO!
    26 Posts 6 Posters 8.1k Views 6 Watching
      Peter, have you tried the drag and drop method from the primary to secondary windows?
      • pbacotP Offline
        Yes. Dragging a style down, the lower pane highlights (thin green line at the top. Letting go of the mouse button, nothing happens. Refresh does not make a difference.
          driven
          try this in 'Ruby Console' and post result [or PM if you prefer]
          last_visit = %x(defaults read ~/Library/Preferences/com.sketchup.SketchUp.2015.plist "SketchUp.DefaultFolder.Styles" )
          favs = %x(defaults read ~/Library/Preferences/com.sketchup.SketchUp.2015.plist UserStyleFolders6 )
          puts last_visit
          puts favs
          • pbacotP Offline
            It lists the desktop location and then the locations of two favorite styles folder I've made (both of which are empty). No change to the styles window in SU.
            • H Offline
              Heaps
              Just tried saving a new style (for the first time) by the right click method and getting the same 'Error saving the style file. The file could not be saved.' message
              OS 10.14.6 SU 20.1.228
                Where were you trying to save it to?
                Did you try the drag and drop method?
                • H Offline
                  Heaps
                  Not sure what is meant by that, can you elaborate?
                    If you right click on the style to save it, you have to choose where it's going to be saved. What location are you trying to use?
                    The drag and drop method involves opening the second pane in the Styles panel. Little button top right corner above Create New Style. Set the primary pane to In Model and the secondary pane to the desired style library then drag the style thumbnail from the top pane to the bottom one.
                    • H Offline
                      Heaps
                      Sorry for delayed response, family and work interuptions. Lockdown is strange.
                      Trying to save to Library/Application Support/SketchUp 2020/SketchUp/Styles.
                      Have tried drag and drop, the green+ indicator appears, but no copy forms in window and I cannot find a copy in the folder( or by attempting find on the computer)
                        Are you going to User/Library/Application Support...?
                        • H Offline
                          Heaps
                          Yes, that is the route as shown when I try via right click- save as
                          • pbacotP Offline
                            I think this is the case where you need to drag the icon view version to the second pane. Other methods do not work on the Mac (Still?). I thought we solved this somewhere on the forum before. (Shows how much I manage styles these days.).
                            I just tried it. I have a folder called "My Styles" that I created by the prescribed method, show it in the lower pane and dragged a style icon from the upper pane to the lower. And it works.
                            Instead of saving to */Styles, you need to create a new collection and save it there. or did you try that? Sorry--juggling emails and first cup.
                            • H Offline
                              Heaps
                              Tried that, I'm still having no success.
                              I'll try restarting and recheck what I'm doing and digging a little further.
                              Thanks for your help in this case, it's the first time we have conversed, but I have appreciated your sound advice over the years as I have followed other Forum threads.
                              I'll let you know how I get on.
                              • pbacotP Offline
                                I'm using 2019 by the way, so your results may vary. Have you also looked under Preferences ? Files to see where your styles folder is designated?
                                • H Offline
                                  Heaps
                                  /Users/******/Library/Application Support/SketchUp 2020/SketchUp/Styles
                                    bruorlando
                                    I've once run into something similar - not being able to save files .styles
                                    I use Sketchup For MAC and what I have found out was a sort of bug-ish:
                                    • I normally use the LIST VIEW for my style window. That was the problem. I dont know why, but SU won't save any style if the window is with LIST VIEW...
                                    • I just switched to LARGE ICON view and it worked.
                                    How knows?... It might work for you as well.
                                      Hi Bruno, welcome to SketchUcation.
                                      FWIW, this behavior has been like this for more than a decade.
                                      • pbacotP Offline
                                        Yeah, this is how it works in Mac anyway.
                                          Same on the PC.
                                          • EdsonE Offline
                                            Edson
                                            I had this problem for ages. You nailed it! Thanks! It is working perfectly.
                                            http://www.mahfuz.arq.br
