    Styles won't save? YES THEY DO!
    26 Posts 6 Posters 8.4k Views 6 Watching
      If you right click on the style to save it, you have to choose where it's going to be saved. What location are you trying to use?
      The drag and drop method involves opening the second pane in the Styles panel. Little button top right corner above Create New Style. Set the primary pane to In Model and the secondary pane to the desired style library then drag the style thumbnail from the top pane to the bottom one.
      • H
        Heaps
        Sorry for delayed response, family and work interuptions. Lockdown is strange.
        Trying to save to Library/Application Support/SketchUp 2020/SketchUp/Styles.
        Have tried drag and drop, the green+ indicator appears, but no copy forms in window and I cannot find a copy in the folder( or by attempting find on the computer)
          Are you going to User/Library/Application Support...?
          • H
            Heaps
            Yes, that is the route as shown when I try via right click- save as
            • pbacotP
              I think this is the case where you need to drag the icon view version to the second pane. Other methods do not work on the Mac (Still?). I thought we solved this somewhere on the forum before. (Shows how much I manage styles these days.).
              I just tried it. I have a folder called "My Styles" that I created by the prescribed method, show it in the lower pane and dragged a style icon from the upper pane to the lower. And it works.
              Instead of saving to */Styles, you need to create a new collection and save it there. or did you try that? Sorry--juggling emails and first cup.
              • H
                Heaps
                Tried that, I'm still having no success.
                I'll try restarting and recheck what I'm doing and digging a little further.
                Thanks for your help in this case, it's the first time we have conversed, but I have appreciated your sound advice over the years as I have followed other Forum threads.
                I'll let you know how I get on.
                • pbacotP
                  I'm using 2019 by the way, so your results may vary. Have you also looked under Preferences ? Files to see where your styles folder is designated?
                  • H
                    Heaps
                    /Users/******/Library/Application Support/SketchUp 2020/SketchUp/Styles
                    • B
                      bruorlando
                      I've once run into something similar - not being able to save files .styles
                      I use Sketchup For MAC and what I have found out was a sort of bug-ish:
                      • I normally use the LIST VIEW for my style window. That was the problem. I dont know why, but SU won't save any style if the window is with LIST VIEW...
                      • I just switched to LARGE ICON view and it worked.
                      How knows?... It might work for you as well.
                        Hi Bruno, welcome to SketchUcation.
                        FWIW, this behavior has been like this for more than a decade.
                        • pbacotP
                          Yeah, this is how it works in Mac anyway.
                            Same on the PC.
                            • EdsonE
                              Edson
                              I had this problem for ages. You nailed it! Thanks! It is working perfectly.
                              http://www.mahfuz.arq.br
                              • 2 / 2
