    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.8m Views 589 Watching
      @craigcclick said:
      Trying to install LibFredo6 - v10.3a for the first time, not having installed LibFred06 before. SU Pro/Mac/Mojave. Successfully downloaded, saying it'll open with SU, but I cannot find it anywhere; neither going directly to the Sk'ucation Plug-In Manager, SU/Extension Manager, or ~/Library/Application Support/SU2020/SU/Plugins. I've restarted, quit and restarted several times. Is it my issue or SU?
      As Dave R says [beat me to the draw !]
      It's your problem...
      This all depends on your browser settings on how to deal with downloaded file-types.
      It looks like you have set downloaded extension's RBZ files to be opened with SketchUp.
      This is completely wrong.
      All RBZ downloads should be set to save - usually these end up in your Downloads folder.
      You then use the native Extension Manager > Install Extension button ... navigate to/choose the RBZ file and auto-install it.
      All of the necessary files/folders are downloaded into the right places without you having to do anything further...
      In the case of a 'Lib' you need to restart SketchUp to get everything in sync...
      A 'Lib' does nothing on its own.
      It's a collection of code that add functionality to other related extensions.
      So to get any useful you need to download/install one of Fredo's other extensions, which will then use the appropriate parts of the Lib to do their magic...
      If you download the SketchUcation Toolset's RBZ and install that as outlined above, then it creates a menu-entry / toolbar which opens a dialog which lets you browse through all of the [hundreds of] Plugins/Extensions housed at SketchUcation - e.g. Fredo's or mine... - and then one-click auto-install them, without worrying about manually getting the RBZ file at all !
      It also has update reminders etc...
      • F
        fedser
        I found a problem with svg in SU2020. Problems were found in the registry. SU2020 does not register entries in EMU IE (as previous versions) why this is not known to me. This prevents fredo6 and SU2020 plugins from using IE resources. In order not to have this problem we need to register SU2020. Here are the keys:
        [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION]
        "sketchup.exe"=dword:00002af8
        [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BROWSER_EMULATION]
        • fredo6F
          At least this explains the problem of not loading SVG. Thanks.
          It should be th role of the Sketchup installer to do the registration however.
          • F
            fedser
            yes, but the SU2020 installer does not. SU developers may have missed this or it was intended to be. I registered manually, all plugins work fine ...
              SU2020 does the registration correctly for me on three different computers. Are you certain you installed SketchUp correctly?
              • fredo6F
                NEW RELEASE: LibFredo6 v10.3b - 30 Apr 20
                LibFredo6 10.3b is a maintenance release for cosmetic adjustments.
                • F
                  fedser
                  The problem only occurs with a clean installation. If you have installed SU19 or SU19 + SU20 together or are doing an update, then there will be no problem. Keys will already be registered. Maybe my installer is broken, but other users have the same problem. Now there is a solution ...
                  • fredo6F
                    NEW RELEASE: LibFredo6 v10.4a - 16 May 20
                    LibFredo6 10.4a is a major maintenance release, with bug fixing and cosmetic adjustments, some for Mac OSX.
                    • T
                      TBoy
                      Fredo6, there is a tool in your plugin to show load times for plugins called 'Performances'.
                      Is it possible to track the load times for any plugin - not only yours?
                      • fredo6F
                        General answer is No.
                        If you use my plugin AdditionalPluginFolders, which allows loading extensions from alternative directories (useful to share plugins between Sketchup versions), then you could see the load time for any plugin loaded, mine and others.
                        You just need to go to Window > LibFredo6 Settings... > View Trace Log files, and in the dialog box, scroll and expand the item AdditionalPluginFolders. Below an example from my machine. You see that WorkPlane (by TIG) took 26 ms to load.
                        • fredo6F
                          NEW RELEASE: LibFredo6 v10.4b - 17 May 20
                          LibFredo6 10.4b is a maintenance release, with bug fixing and cosmetic adjustments, some for Mac OSX and support of FredoTools 4.0a
                            masloprojekt
                            I think this update caused SUClock (which is brilliant btw) to stop working. Is it possible or should i look for a reason elsewhere? Thank You !
                            EDIT:
                            It looks like the time is counting correctly, but it doesn't display the watch.
                              signup
                              When drawing guide lines with draw tools in version 8.9b, they are divided automatically into segments like what you see in this gif
                              https://media.giphy.com/media/dvg4Fslq9q2yr4F08u/source.gif
                              However, in the new version, there is no segment shown up in a guide line. So, is this feature deleted in the new version or is it bugged?
                              https://media.giphy.com/media/MZKjeIrPXAEXvnFJsS/source.gif
                              • fredo6F
                                EDIT:
                                I found the problem. Very strange because it should have been present since long...
                                Anyway, I will publish and update to SUClock (v4.0a).
                                Note however that SUClock 4.0a will only be available for SU 2017 and above.
                                • fredo6F
                                  The behaviour you mention with LibFredo6 8.9b (division of guide line) is weird. There has never been a feature to divide guide lines in DrawAlong.
                                  IMPORTANT: You seems to be on SU2016. Please note that LibFredo6 v10.0 and above does not support SU2016 and previous versions of Sketchup. It should only be installed for SU2017 and above.
                                    signup
                                    I've been using SU for 4 years and I often use this feature in any drawings of mine. It helps me divide lines equally and arrange everything quickly with divided segments.
                                    Now, I'm using SU2019 along with new updates of LibFredo 6 which doesn't enable me to have those guiding lines and segments anymore. I hope you will figure it out and recover that feature.
                                    Please watch my gifs carefully again.
                                    • fredo6F
                                      I actually forgot about the feature '/', and its dual '*'.
                                      I found the problem, and it will go into LibFredo6 v10.4c.
                                      Thanks for signaling.
                                        signup
                                        Thanks for your help!
                                          @signup said:
                                          Now, I'm using SU2019...
                                          Please update your profile. It says you are still using SketchUp 2016 Make which is what made Fredo6 think that's what you are using.
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v10.4c - 19 May 20
                                            LibFredo6 10.4c is a maintenance release, with bug fixing for FredoTools::DrawAlong
                                            • 76
                                            • 77
                                            • 78
                                            • 79
                                            • 80
                                            • 113
                                            • 114
                                            • 78 / 114
