    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Oops, you're right.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.7.4 - 05.02.2020
        • Fixed a bug with the soffit and fascia module for all truss types.
        This bug fix is specifically for the boxed soffit for truss roofs. Previously if one did not enable the fascia but enabled the soffit then it would throw an error. There may be other similar bugs in this module or others so I am constantly testing combinations of various parameters to make sure no interdependencies have been overlooked.
        *** This should have been posted in the Truss plugin thread ***
        design.medeek.com
        • jujuJ Offline
          juju
          @medeek said:
          Oops, you're right.
          yeah, but not as often as you are, thanks for the great work!
          • medeekM Offline
            medeek
            Per a customer request I will be including a material for HardiPlank Colonial Roughsawn siding in the next release of the plugin. It is a slightly different texture than the lap siding with a 6.75" reveal (versus 7").
            If you would like to utilize the material right away you can find it attached to this model:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.4.1 - 05.12.2020
              • Enabled a tapered wrap for a free standing columns.
              • Added a HardiPlank Colonial (Rough Sawn) built-in material into the material library.
              http://design.medeek.com/resources/wallplugin/images/wall_su354_800.jpg
              Two new parameters: Taper and Taper Offset
              View model here:
              3D Warehouse
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.4.1b - 05.13.2020
                • Added a "Style2" hardware option (Lever & Lock) to the garage door module.
                http://design.medeek.com/resources/wallplugin/images/wall_su355_800.jpg
                This additional hardware option added per customer request.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.4.2 - 05.14.2020
                  • Added a layer for posts to the advanced layer options (Layer tab of the global settings).
                  • Added a layer for blocking to the advanced layer options (Layer tab of the global settings).
                  http://design.medeek.com/resources/wallplugin/images/wall_su356_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    First look at the blocking toolbar:
                    I will also be removing the Fixtures toolbar from the Wall plugin, this toolbar will become part of the upcoming Medeek Interior plugin.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      My intent is to have the blocking tool place the blocks within the wall panel assembly/group. However would there be a case where the user would want to create the blocks as stand alone entities outside of any wall, roof or floor assembly?
                      design.medeek.com
                      • jujuJ Offline
                        juju
                        Probably only if you're adding an additional low level wall with some ledge or similar, which wouldn't normally form part of the usual wall.
                        • medeekM Offline
                          medeek
                          Version 1.4.3 - 05.17.2020
                          • Added a blocking tool/module for inserting custom blocks into Medeek walls, roofs, floors or generic groups.
                          • Added the Blocking toolbar and icons.
                          • Removed the Fixtures toolbar and icons.
                          http://design.medeek.com/resources/wallplugin/images/wall_su357_800.jpg
                          Note, that the blocking is automatically retained within the wall, roof or floor assembly after a regen or edit of the primary assembly.
                          After selecting the first point one can toggle the positioning of the blocking with the "Ctrl" key. There are nine possible positions the block can be inserted at.
                          The blocking is placed on the framing layer unless the advanced layers are turned on, in which it is placed on a specific blocking layer.
                          I will be releasing a tutorial video shortly on this new tool.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            After putting this new tool through its paces for a few more minutes it immediately jumps out at me that it would be really nice to have a hot key for toggling the rotation (zero or ninety). For other custom rotations the user can simply key in the desire rotation in the menu.
                            What key should I use to toggle the rotation? Iโ€™m already using the Ctrl key to toggle placement location.
                            design.medeek.com
                              TAB ?
                              But remember that you need to spot it using onKeyUp, because onKeyDown with TAB fails on MACs...
                              • medeekM Offline
                                medeek
                                Version 1.4.3b - 05.17.2020
                                • Added the "Shift" hotkey to the blocking draw tool in order to toggle the block rotation between zero and ninety degrees.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Tutorial 12 - Blockingย (12:42 min.)
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.4.4 - 05.24.2020
                                    • Added I-Joist blocks to the the blocking module: TJI, BCI, LPI, Red-I, PKI.
                                    http://design.medeek.com/resources/wallplugin/images/wall_su358_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.4.5 - 05.29.2020
                                      • Fixed a number of minor issues with the ladder blocking option for tee intersections.
                                      • Tee intersection blocking is now assigned to the blocking layer if the advanced layer option is turned on.
                                      If you are using ladder blocking for your tee intersections then I consider this to be a critical update.
                                      design.medeek.com
                                      • pbacotP Offline
                                        I'd love to know how you organize your work. There must be some times when you circle back to fix stuff but it sure seems like you take on a task and work at it very efficiently until done! Good job all around!
                                        • medeekM Offline
                                          medeek
                                          With coding its fairly simple, you decide on a task or project and then you do your best to complete it in one go. The problem with jumping around between tasks is that a lot of what I do requires some very deep levels of concentration, some of the code can get very complex and it is hard to really understand it unless you are completely absorbed and focused.
                                          In fact, some of it is so complex (even though I do my best to document it liberally) that after leaving that piece of code for couple of months it is hard to come back to it and understand what exactly I did. In some cases it requires me to essentially re-learn portions of my code. That is the reason why once I get started on a module I pound on it hard for a few days. It is very inefficient to have to come back to partially finished code and essentially restart (sometimes it's unavoidable).
                                          What I choose to work on is largely dictated by the users of the plugins. Currently bug fixes are taking priority, however once I start on a major upgrade I usually cease to work on any bug fixes until that module or upgrade is complete. Even after I move on to another project if an additional feature becomes necessary or is requested for a recently completed module I will usually immediately return to that chunk of code and implement that feature. Again, the reason for this is because the code is still fresh in my mind so it is the path of least resistance.
                                          As they say the squeaky wheel gets the grease. If I get enough requests for a specific feature and it appears to make sense within the scope of the plugin(s) then I will usually push that item to the top of the list and do my best to complete it as soon as possible.
                                          design.medeek.com
                                          • pbacotP Offline
                                            Thank you! Nice explanation!
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 74
                                            • 75
                                            • 17 / 75
