    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 1.3.7b - 04.25.2020
      • Added a Global Reset button in the General tab of the Global Settings.
      http://design.medeek.com/resources/trussplugin/images/truss_su687_800.jpg
      No more messing around with registry entries, plist files and JSON files. Just click the button and you start with a clean slate, why didn't I think of this before.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.3.8 - 04.26.2020
        • Added additional logic to the blocking and insulation modules for short wall panels.
        http://design.medeek.com/resources/trussplugin/images/truss_su688_800.jpg
        design.medeek.com
        • medeekM
          medeek
          Version 1.3.9 - 04.28.2020
          • Added a "Terminal" end wall condition.
          http://design.medeek.com/resources/trussplugin/images/truss_su691_800.jpg
          The principal use of this end condition is for interior walls terminating against multi-wall corners as shown above.
          design.medeek.com
          • medeekM
            medeek
            Version 1.4.0 - 05.01.2020
            • Enabled a second layer of gypsum for interior and exterior walls.
            http://design.medeek.com/resources/trussplugin/images/truss_su692_800.jpg
            This update adds an optional 2nd layer of gypsum to the wall assembly. By disabling the first layer of gypsum one can create an air gap between the 2nd layer of gypsum and the framed wall.
            This update also addresses a minor bug caused by the updates in Version 1.3.8.
            This latest update will require the user to recreate their wall presets since three new parameters have been added to the wall attribute library.
            View an example of double gypsum walls here:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            design.medeek.com
            • medeekM
              medeek
              Version 1.4.0b - 05.01.2020
              • Fixed a critical bug with the tee intersection ladder blocking with walls with no openings.
              • Added a "Rustic Shiplap" built-in material into the material library.
              http://design.medeek.com/resources/trussplugin/images/truss_su693_800.jpg
              http://design.medeek.com/resources/trussplugin/images/truss_su694_800.jpg
              design.medeek.com
              • medeekM
                medeek
                The Wall plugin has been slowly maturing over the last few months, however I am quite sure there are still a few more bugs that I am hoping to uncover and resolve.
                In an effort to flush out these last remaining bugs I will be offering a "Bug Discovery" incentive program. If you find and report a bug and I then verify that it is indeed a bug in the code (not an unfinished feature/module or user error), you will then be entitled to an additional year added on to your current update expiration date of your license/serial number.
                This program will also be extended to all other Medeek plugins. The credit can only be applied to the plugin(s) in which they were found.
                Hopefully this will encourage users to help find and report bugs and ultimately make all of the plugins that much more robust.
                Please send all bug reports directly to me at nathan@medeek.com
                Please do not include any SketchUp models large than 2 MB or large video files or MS Word documents. Screen shots and output from the ruby console is always very helpful.
                design.medeek.com
                • jujuJ
                  juju
                  @medeek said:
                  Version 2.7.4 - 05.02.2020
                  • Fixed a bug with the soffit and fascia module for all truss types.
                  This bug fix is specifically for the boxed soffit for truss roofs. Previously if one did not enable the fascia but enabled the soffit then it would throw an error. There may be other similar bugs in this module or others so I am constantly testing combinations of various parameters to make sure no interdependencies have been overlooked.
                  wrong thread?
                  • medeekM
                    medeek
                    Oops, you're right.
                    design.medeek.com
                    • medeekM
                      medeek
                      *** This should have been posted in the Truss plugin thread ***
                      design.medeek.com
                      • jujuJ
                        juju
                        @medeek said:
                        Oops, you're right.
                        yeah, but not as often as you are, thanks for the great work!
                        • medeekM
                          medeek
                          Per a customer request I will be including a material for HardiPlank Colonial Roughsawn siding in the next release of the plugin. It is a slightly different texture than the lap siding with a 6.75" reveal (versus 7").
                          If you would like to utilize the material right away you can find it attached to this model:
                          3D Warehouse
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.4.1 - 05.12.2020
                            • Enabled a tapered wrap for a free standing columns.
                            • Added a HardiPlank Colonial (Rough Sawn) built-in material into the material library.
                            http://design.medeek.com/resources/wallplugin/images/wall_su354_800.jpg
                            Two new parameters: Taper and Taper Offset
                            View model here:
                            3D Warehouse
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.4.1b - 05.13.2020
                              • Added a "Style2" hardware option (Lever & Lock) to the garage door module.
                              http://design.medeek.com/resources/wallplugin/images/wall_su355_800.jpg
                              This additional hardware option added per customer request.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.4.2 - 05.14.2020
                                • Added a layer for posts to the advanced layer options (Layer tab of the global settings).
                                • Added a layer for blocking to the advanced layer options (Layer tab of the global settings).
                                http://design.medeek.com/resources/wallplugin/images/wall_su356_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  First look at the blocking toolbar:
                                  I will also be removing the Fixtures toolbar from the Wall plugin, this toolbar will become part of the upcoming Medeek Interior plugin.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    My intent is to have the blocking tool place the blocks within the wall panel assembly/group. However would there be a case where the user would want to create the blocks as stand alone entities outside of any wall, roof or floor assembly?
                                    design.medeek.com
                                    • jujuJ
                                      juju
                                      Probably only if you're adding an additional low level wall with some ledge or similar, which wouldn't normally form part of the usual wall.
                                      • medeekM
                                        medeek
                                        Version 1.4.3 - 05.17.2020
                                        • Added a blocking tool/module for inserting custom blocks into Medeek walls, roofs, floors or generic groups.
                                        • Added the Blocking toolbar and icons.
                                        • Removed the Fixtures toolbar and icons.
                                        http://design.medeek.com/resources/wallplugin/images/wall_su357_800.jpg
                                        Note, that the blocking is automatically retained within the wall, roof or floor assembly after a regen or edit of the primary assembly.
                                        After selecting the first point one can toggle the positioning of the blocking with the "Ctrl" key. There are nine possible positions the block can be inserted at.
                                        The blocking is placed on the framing layer unless the advanced layers are turned on, in which it is placed on a specific blocking layer.
                                        I will be releasing a tutorial video shortly on this new tool.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          After putting this new tool through its paces for a few more minutes it immediately jumps out at me that it would be really nice to have a hot key for toggling the rotation (zero or ninety). For other custom rotations the user can simply key in the desire rotation in the menu.
                                          What key should I use to toggle the rotation? I’m already using the Ctrl key to toggle placement location.
                                          design.medeek.com
                                            TAB ?
                                            But remember that you need to spot it using onKeyUp, because onKeyDown with TAB fails on MACs...
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 80
                                            • 81
                                            • 42 / 81
