    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 290.1k Views 17 Watching
      pibuz
      So cool! Thanks!
      ...did you guys had a look to the bug that I reported some time ago, about componentfinder including objects in folders different from the selected?
      https://sketchucation.com/forums/viewtopic.php?f=403&t=71638
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • utilerU Offline
        utiler
        This is so so good!!! Congratulations to you guys to continually listening to your user base and implementing new features! 👍 👍 👍
        Just Curious...
        • halroachH Offline
          halroach
          @pibuz said:
          So cool! Thanks!
          Yes, we'll try to have this fixed in the next ComponentFinder update.
          FlexTools - Super Quick Windows, Doors, Slats...
            pibuz
            Wonderful! Thanks!!!!
            • halroachH Offline
              halroach
              Check out the updated FlexDoor & FlexDoor Glass - Learn Page.
              Find out what you can do with these flex components, including how to change the glass distributions, assign materials, make a glass pivot door, and more.
              https://flextools.cc/wp-content/uploads/2020/03/FlexDoor-Glass_main-anim_02-gif_03.gif
              • utilerU Offline
                utiler
                Super cool additions guys...!! nice to see you expanding this great suite of tools!!
                Just Curious...
                • halroachH Offline
                  halroach
                  Many thanks to Justin from 'The SketchUp Essentials' for a great FlexDoor Glass review!
                  • halroachH Offline
                    halroach
                    • mogrenM Offline
                      mogren
                      UN bonus serait d'avoir dans le arch window une possibilité paramétrable d'entourage de l'arc (voir capture)
                      Je ne sais pas si c'est une tannée de programmation.
                        On doit pouvoir tricher avec une texture! 😉
                        Maybe cheat with a texture ?
                          Even by default, it's not so bad! 😄
                          Separate for have more size acceptable (no made here! 😄
                          • mogrenM Offline
                            mogren
                            Oui.. un peu long comme mise en oeuvre tout ça.
                            De mon cotĂ© j'avais recréé une arche avec l'outil dĂ©calage, fermĂ©e avec mĂȘme diamĂštre et mĂȘme nombre de segments (nombre impair pour la clĂ© de voute) juste au-dessus de mon composant puis utilisĂ© le plugin Split tool pour l'appareillage qui s'adapte aux segments
                            En derniÚre étape si je veux que l'appareillage soit saillant du nu du mur: un Fredo's Joint push pull pour l'extrusion de toutes les pierres ou au choix une par une.
                            D'ailleurs au moment de ce dernier l'application a sauté, je me demande si ce n'est pas un conflit entre Joint push pull et Split view?
                            C'est une méthode aussi trop longue, le but de ma question s'adressait au dévellopeur de Flex s'il imaginait pouvoir rajouter la fonction à l'Archwindow (qui est déjà trÚs pratique)
                              Il semble qu'il a pris bonne note et donnĂ© une cool astuce! ☀ (voir 2 posts plus haut! 😉
                              • mogrenM Offline
                                mogren
                                What I would like ☀
                                • mogrenM Offline
                                  mogren
                                  Exemple
                                    Hospices imaginaires ou ayant existés ?
                                    • mogrenM Offline
                                      mogren
                                      Décor film
                                      • halroachH Offline
                                        halroach
                                        @mogren said:
                                        What I would like ☀
                                        You should be able to get that with the following settings.
                                        'Inset' to move the window in/out in relation to the wall.
                                        'Frame - Depth' to get it as deep as you need.
                                        Play with the 'Frame - Width' setting to change what you wrote as Height in your picture.
                                        • mogrenM Offline
                                          mogren
                                          @halroach said:
                                          @mogren said:
                                          What I would like ☀
                                          [attachment=1:3clrfqal]<!-- ia1 -->flexwindow arch in arch settings.png<!-- ia1 -->[/attachment:3clrfqal]
                                          To follow your example we need two windows one above the other to have the wooden frame (see the red arrow)?
                                            Je crois que oui, c'est ce qui Ă©tait dĂ©crit dans les posts prĂ©cĂ©dents 😉
                                            Il faut utiliser 2 composants l'un dans l'autre!
                                            I took two arch components, and placed one in the other.
                                            • 8 / 9
