    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 342.8k Views 17 Watching
    • halroachH
      halroach
      Introducing a new flex component - FlexRamp.
      From now on you’ll be able to create sloped walkways & parking lot ramps in seconds!
      Learn more in the blog: https://flextools.cc/blog/flexramp
      https://flextools.cc/wp-content/uploads/2019/11/FlexRamp_02_02e.gif
      FlexTools - Super Quick Windows, Doors, Slats...
      • P
        pibuz
        This is real wonder 😍 😍 😍 😍
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        • halroachH
          halroach
          Meet the new FlexDoor Glass component!
          Now you can easily create different dynamic glass doors with additional panels and multiple muntin distributions. The detailed documentation is in the works.
          See more at https://flextools.cc/blog/new-flexdoor-glass/
          • P
            pibuz
            So cool! Thanks!
            ...did you guys had a look to the bug that I reported some time ago, about componentfinder including objects in folders different from the selected?
            403 Forbidden
            (sketchucation.com)
            • utilerU
              utiler
              This is so so good!!! Congratulations to you guys to continually listening to your user base and implementing new features! 👍 👍 👍
              Just Curious...
              • halroachH
                halroach
                @pibuz said:
                So cool! Thanks!
                403 Forbidden
                (sketchucation.com)
                Yes, we'll try to have this fixed in the next ComponentFinder update.
                • P
                  pibuz
                  Wonderful! Thanks!!!!
                  • halroachH
                    halroach
                    Check out the updated FlexDoor & FlexDoor Glass - Learn Page.
                    Find out what you can do with these flex components, including how to change the glass distributions, assign materials, make a glass pivot door, and more.
                    https://flextools.cc/wp-content/uploads/2020/03/FlexDoor-Glass_main-anim_02-gif_03.gif
                    • utilerU
                      utiler
                      Super cool additions guys...!! nice to see you expanding this great suite of tools!!
                      Just Curious...
                      • halroachH
                        halroach
                        Many thanks to Justin from 'The SketchUp Essentials' for a great FlexDoor Glass review!
                        • halroachH
                          halroach
                          • mogrenM
                            mogren
                            UN bonus serait d'avoir dans le arch window une possibilité paramétrable d'entourage de l'arc (voir capture)
                            Je ne sais pas si c'est une tannée de programmation.
                              On doit pouvoir tricher avec une texture! 😉
                              Maybe cheat with a texture ?
                                Even by default, it's not so bad! 😄
                                Separate for have more size acceptable (no made here! 😄
                                • mogrenM
                                  mogren
                                  Oui.. un peu long comme mise en oeuvre tout ça.
                                  De mon cotĂ© j'avais recréé une arche avec l'outil dĂ©calage, fermĂ©e avec mĂȘme diamĂštre et mĂȘme nombre de segments (nombre impair pour la clĂ© de voute) juste au-dessus de mon composant puis utilisĂ© le plugin Split tool pour l'appareillage qui s'adapte aux segments
                                  En derniÚre étape si je veux que l'appareillage soit saillant du nu du mur: un Fredo's Joint push pull pour l'extrusion de toutes les pierres ou au choix une par une.
                                  D'ailleurs au moment de ce dernier l'application a sauté, je me demande si ce n'est pas un conflit entre Joint push pull et Split view?
                                  C'est une méthode aussi trop longue, le but de ma question s'adressait au dévellopeur de Flex s'il imaginait pouvoir rajouter la fonction à l'Archwindow (qui est déjà trÚs pratique)
                                    Il semble qu'il a pris bonne note et donnĂ© une cool astuce! ☀ (voir 2 posts plus haut! 😉
                                    • mogrenM
                                      mogren
                                      What I would like ☀
                                      • mogrenM
                                        mogren
                                        Exemple
                                          Hospices imaginaires ou ayant existés ?
                                          • mogrenM
                                            mogren
                                            Décor film
                                            • 6 / 9
