    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
      I think something might be getting lost in translation ?
      For 'Terminal' perhaps read 'SketchUp > Window > Ruby Console' [open it before doing anything]
      Although on a MAC there is a separate 'Terminal' app, surely you'd need it running before the error occurs ?
      • samuel_tS
        samuel_t
        I'm talking about that separate 'Terminal' app.
          So do you need to explain to MAC users to open the Terminal first, and then try your tool...
          And any error-messages might appear in that Terminal window ?
          • samuel_tS
            samuel_t
            No, command line needs to be pasted in Mac's Terminal after that Universal Importer plugin crashes.
            • E
              edwinfolk
              Hello Samuel,
              Thanks for doing this. This looks like a really great plugin that can help with rendering and setting up reference models for a lot of Maxwell users. Attached is a screen shot of the terminal window. Hope you can make sense of it.
                McGordon
                The permission denied means you don't have executable permissions on that assimp file. Can you paste this into Terminal and press return:
                ls -l ~/Library/Application\ Support/SketchUp\ 2018/SketchUp/Plugins/universal_importer/Assimp/Mac
                Then show us the results, which should look something like this:
                total 25448
                -rwxr-xr-x@ 1 gordon  staff      3791 24 Sep  2019 LICENSE.txt
                -rwxr-xr-x@ 1 gordon  staff    149772  6 Jan 16;05 assimp
                -rwxr-xr-x@ 1 gordon  staff  12810620  6 Jan 16;05 libassimp.dylib
                -rwxr-xr-x@ 1 gordon  staff     58316 24 Sep  2019 x.dyl
                I haven't installed this yet, I'm just trying to help as samuel_t doesn't have a Mac. The first 'x' in '-rwxr-xr-x@' for assimp means I could run that file as a program. That's the bit I'm looking for when you run that command which just lists what's in that directory.
                • E
                  edwinfolk
                  Hello McGordon,
                  I attached a screen shot of the command sent through terminal. Not sure what that means - sorry I am not a coder or Ruby specialist. Anyway if you can make sense of this and help Samuel thereby helping us MacOS users, awesome. Thanks for the help and stay safe.
                  Edwin
                    In the first part of the 'report' the "rw" means "read/write".
                    If you see the earlier McGordon example you see "rwx" which means "read/write/execute".
                    So yours is failing because it doesn't have permission to execute the necessary files...
                    You could try selecting the subfolder [.../Plugins/universal_importer] and changing it to have "full" permissions - for all users and all of its contents...
                      McGordon
                      As I suspected, you don't have permission to run that file. You could fix it with another terminal command:
                      chmod u+x ~/Library/Application\ Support/SketchUp\ 2018/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp
                      Be more careful copying and pasting this time. The 'CODE: SELECT ALL' link doesn't work for me, it just scrolls to the top of the page.
                      That command just changes the execute (run) permissions of that one file.
                      They are perfectly readable, but you don't have to screenshot the terminal, just copy the text as if it was any text document in a word processor or text editor.
                      • E
                        edwinfolk
                        Hi Guys,
                        Thanks again for looking at this. I review both your responses. I think I had previously made a mistake entering the cut and paste into terminal and received the wrong information which I sent to you. I went back a step and copy/pasted into terminal the correct line of code and the terminal spit this out.
                        -rw-rw-rw- 1 edfolk staff 3791 Sep 24 2019 LICENSE.txt
                        -rwxrw-rw- 1 edfolk staff 149772 Jan 6 17:05 assimp
                        -rw-rw-rw- 1 edfolk staff 12810620 Jan 6 17:05 libassimp.dylib
                        -rw-rw-rw- 1 edfolk staff 58316 Sep 24 2019 x.dyl
                        I did try to paste into the line McGordon sent but the plugin did not complete the import. I attached a series of 3 screenshots to show you. As you can imagine I am not the computer guy. Decent enough designer but shit when it comes to this sort of thing.
                        Thanks again you guys are really great.
                        Edwin
                          McGordon
                          It looks like the previous chmod command worked:
                          @edwinfolk said:
                          > -rwxrw-rw-  1 edfolk  staff    149772 Jan  6 17;05 assimp
                          I think you've made a bit of progress. You're now getting a different error from another program that probably doesn't have executable permissions either. Here's
                          one more command to make it run too:
                          chmod u+x ~/Library/Application\ Support/SketchUp\ 2018/SketchUp/Plugins/universal_importer/MeshLab/Mac/MacOS/meshlabserver
                          run that then try to do your import again. I think there might be other files on your system with the wrong permissions, but I'm only getting you to change one at a time here.
                          • E
                            edwinfolk
                            Hello,
                            Thanks for the help. It seems to work better than before. I attached a jpg so you can see that the file I imported (OBJ) did not completely import successfully. Not sure what the problem is but as you can tell from the image it is not complete. Same thing happened with a Light Wave import although the import image was about 1/100 the expected size. I will try some other imports from other formats and see what happens. If you have any ideas would love to hear them.
                            I have been able to convert some files from these formats using MODO to make a Collada file and then using the normal import to SKU. Cleaning them up and ignoring UV distortion which gives okay results. However, if I can get the universal importer to work well then I can save a lot of time.
                            Thanks again. Really appreciate the help.
                              malditobill
                              Hi. Do I have to install Assimp library and MeshLab software before Universal Importer? Ive just installed only Universal Importer and in the tool bar only get the reduce poligons icons.
                              • samuel_tS
                                samuel_t
                                Hi. No. Assimp library and MeshLab software are bundled with Universal Importer plugin. SketchUp toolbar only contains shortcut to Poly reducer... In SketchUp menu, use "File > Import with Universal Importer...".
                                  rspierenburg
                                  I'm trying to import an OBJ. I want to keep the existing model scale but the plugin keeps asking for the height of the model. Is there a way to ignore that?
                                  • samuel_tS
                                    samuel_t
                                    Hello. You can't ignore that.
                                    • L
                                      Lacee
                                      Unable to reduce a 6,000,000 poly SU2020 file / also unable to import OBJ source file for same #2
                                      Posted in GitHub.
                                      • K
                                        Kolarik
                                        1. Can you explain, how size of imported object is calculated? I am not able to import objects in correct size. See attached example - block 10x20x30mm
                                          Original block
                                          It was exported to STL, and imported back by Universal Importer.
                                          Height set to 1 cm
                                          Size settings
                                          no texture, no reduction.
                                          Result :
                                          Result of import
                                        I do not know, what I am doing bad....
                                        1. I am using milimetres as default in Sketchup - if the sizing rules would work, can it be changed into mm instaed of cm?
                                        • samuel_tS
                                          samuel_t
                                          Posted in GitHub.
                                          Hello Lacee. I just answered you at GitHub πŸ˜‰
                                          • E
                                            Einstein
                                            Hello,
                                            Would it be possible to support importing loose edges from Blender? When a mesh contains faces, it imports properly but if there are only edges, they don't get imported.
                                            It would also be cool if separate Blender objects would be imported to separate SketchUp groups. But I'm aware this can be a lot of work to code.
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
