    3D Truss Models
    1.5k Posts 32 Posters 1.8m Views 31 Watching
    • jujuJ
      juju
      @medeek said:
      Velux has their official models in the warehouse but as usual there are too many details in these models, so I had to create my own low poly versions that are dimensionally accurate:
      https://3dwarehouse.sketchup.com/warehouse/v1.0/publiccontent/7a9c9925-45e3-4a46-8dba-bd543d1f1065
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Different manufacturers have different sizes. A single well constructed DC, where you can enter the overall sizing on a dialogue, would probably be more useful and cause less bloating of the extension?
      • medeekM
        medeek
        First look at the Skylights Toolbar:
        https://aws1.discourse-cdn.com/sketchup/original/3X/9/c/9c74f6e602266b8ada8dc6c6c1b1b855034a2373.jpeg
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          I've thought about this however there are quite a few different types of skylights (ie. surface mount, curb mount, round etc...) so it would seem to make more sense to model a few of the most common ones and then allow the user to drop their own custom skylights into the library folder. However, I do get what you are saying on this, I may need to give it some more thought.
          design.medeek.com
          • jujuJ
            juju
            Maybe touch base with Yoni at FlexTools, they seem to have that process licked!
            • pbacotP
              Surface mount and curb mounted (typically on 2x6 framing over roof deck) are common. Velux is probably the standard though there are other types out there. In our area it's mostly Velux or something like that due to stringent energy requirements. You could have some of these, especially the ones meant to go into 24" o.c. framing. Then if you want branch out to some pyramidal or gable style skylights.
              • medeekM
                medeek
                Version 2.7.2 - 04.24.2020
                • Added wall sheathing thickness and wall cladding thickness parameters to the advanced options for trusses.
                • Enabled advanced options for tail bearing trusses.
                http://design.medeek.com/resources/trussplugin/images/truss_su683_800.jpg
                I still need to enable editing and labels for tail bearing trusses.
                design.medeek.com
                • medeekM
                  medeek
                  Version 2.7.2b - 04.24.2020
                  • Enabled the "Edit Truss Assembly" function for all tail bearing trusses (imperial and metric units).
                  • Labels and callouts added to tail bearing trusses.
                  http://design.medeek.com/resources/trussplugin/images/truss_su685_800.jpg
                  http://design.medeek.com/resources/trussplugin/images/truss_su684_800.jpg
                  This update also resolves a potential bug that could cause the plugin to go into a infinite loop if the birdsmouth cut exceeds the depth of the top chord of the truss. If you are using tail bearing trusses I highly recommend upgrading to this latest release.
                  The updated module is now properly creating the gypsum on the underside of the truss (three pieces).
                  design.medeek.com
                    db11
                    Do you have an option for strapping between the trusses and the gypsum?
                    • medeekM
                      medeek
                      Yes, for some truss types it is enabled.
                      design.medeek.com
                        db11
                        OK, thanks.
                        One other quick question: when do you expect to have your gable wall module completed?
                        • medeekM
                          medeek
                          Maybe I'll wrap that up next. I really want to get this skylight module up and running though in the next couple of days.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.7.3 - 04.26.2020
                            • Added a Global Reset button in the General tab of the Global Settings.
                            https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cd164f87f2a986d3ef495bb9a5cfa6335fd24e5.jpeg
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 2.7.4 - 05.02.2020
                              • Fixed a bug with the soffit and fascia module for all truss types.
                              This bug fix is specifically for the boxed soffit for truss roofs. Previously if one did not enable the fascia but enabled the soffit then it would throw an error. There may be other similar bugs in this module or others so I am constantly testing combinations of various parameters to make sure no interdependencies have been overlooked.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 2.7.5 - 05.05.2020
                                • Enabled a toggle feature (Ctrl key) for the Trim tool so that the selection can be retained or removed.
                                This small adjustment of the Trim tool is to bring it inline with the Trim 2 tool. This feature is per customer request.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  First look at the skylight tool in action:
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/e/4/e492b52c1392aaf9038a71a8d1042273df9e1549.jpeg
                                  Note, that this image shows the skylights added to a generic roof. For the cutouts to work the roof geometry must be a valid solid group or component within an overall assembly group for the roof or building.
                                  Initially there are three skylights (sizes) to choose from however it is possible to add your own skylights into the library.
                                  The cut function can be toggled on/off in order to cut through the sheathing and cladding or in this case just a generic roof solid.
                                  At some point I would also like to add in a few VELUX Sun Tunnels.
                                  Now I just need to figure out how to heal the roof when a skylight is deleted or edited. For a Medeek roof that is fairly straight forward, just regen the roof, however for a generic solid things get a little more tricky.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.7.6 - 05.11.2020
                                    • Added the Skylights toolbar.
                                    • Enabled skylights for all truss, rafter and complex roofs.
                                    • Enabled skylights for generic roofs.
                                    http://design.medeek.com/resources/images/skylight_su_menu_active.jpg
                                    http://design.medeek.com/resources/trussplugin/images/truss_su696_800.jpg
                                    I also added an additional tool for "regenerating" the skylights, this comes in handy after modifying the location of a skylight or if a Medeek roof gets regenerated and the holes in the sheathing and cladding need to be re-cut.
                                    There are few new global settings I still need to add to fully complete this new module but overall it seems to be working quite nicely.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • jujuJ
                                        juju
                                        thanks
                                        since we're expanding with more buttons, how's the work on reducing the amount of buttons on the taskbar coming along?
                                        • medeekM
                                          medeek
                                          Tutorial 18: Skylights (14.22 min.)
                                          I often get a lot of questions that are answered in the tutorial videos. Just a reminder, all of the tutorial videos can be found here:
                                          404 - File or directory not found.
                                          (design.medeek.com)
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 2.7.7 - 07.31.2020
                                            • Fixed a bug with all assemblies when auto-assignment of materials is turned off in the global settings.
                                            design.medeek.com
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 76
                                            • 77
                                            • 67 / 77
