    3D Truss Models
    1.5k Posts 31 Posters 1.5m Views 30 Watching
    • medeekM Offline
      medeek
      Version 2.6.9 - 04.11.2020
      • Enabled the "Edit Truss Assembly" function for all parallel chord trusses (imperial and metric units).
      • Labels and callouts added to parallel chord trusses.
      http://design.medeek.com/resources/trussplugin/images/truss_su672_800.jpg
      There are still a number of truss types and rafter roofs that still need edit capabilities, I am slowly working through this list.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.7.0 - 04.12.2020
        • Enabled the "Edit Truss Assembly" function for all timber trusses (imperial and metric units).
        http://design.medeek.com/resources/trussplugin/images/truss_su673_800.jpg
        design.medeek.com
        • medeekM Offline
          medeek
          Version 2.7.1 - 04.13.2020
          • Enabled the "Edit Roof Assembly" function for shed w/ ledger rafter roofs (imperial and metric units).
          • Enabled soffit and fascia for shed w/ ledger rafter roofs: boxed, gable, angled.
          • Enabled a roof cladding extension parameter for shed w/ ledger rafter roofs.
          • Added the option in the shed w/ ledger rafter roof edit menu to specify a separate front and back overhang length.
          • Enabled a "No Framing" mode for shed w/ ledger rafter roofs.
          http://design.medeek.com/resources/trussplugin/images/truss_su674_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            Skylights have not been on my official todo list but now they are.
            I've actually been tossing the Skylight idea around for a while now, how best to implement it within the various roof modules. I've got some ideas already but I haven't finalized it yet.
            Does anyone have any specifics or suggestions on the actual skylight models/components that I should use. Specific brands, reference drawings, that sort of thing.
            My thinking is to have some fairly generic skylight models that the user could chose from. The skylight module would then bring these components into the model and also cut the corresponding holes in the roof cladding and sheathing. I would also have a tool for editing and deleting a skylight. As far as moving the skylight on the roof plane, I would allow the user to simply click into the roof assembly and moving the skylight with the native tools as they see fit, this would be the simplest way of handling re-positioning.
            Again, I'm still tossing this idea around, trying to shake out the best system for implementing it, any feedback is appreciated.
            design.medeek.com
            • medeekM Offline
              medeek
              Velux has their official models in the warehouse but as usual there are too many details in these models, so I had to create my own low poly versions that are dimensionally accurate:
              https://3dwarehouse.sketchup.com/warehouse/v1.0/publiccontent/7a9c9925-45e3-4a46-8dba-bd543d1f1065
              https://3dwarehouse.sketchup.com/model/f56a0a28-e161-46ce-a051-ea081c9e2a74/Medeek-Skylights-Velux-Low-Poly
              design.medeek.com
              • jujuJ Offline
                juju
                Different manufacturers have different sizes. A single well constructed DC, where you can enter the overall sizing on a dialogue, would probably be more useful and cause less bloating of the extension?
                • medeekM Offline
                  medeek
                  First look at the Skylights Toolbar:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/9/c/9c74f6e602266b8ada8dc6c6c1b1b855034a2373.jpeg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I've thought about this however there are quite a few different types of skylights (ie. surface mount, curb mount, round etc...) so it would seem to make more sense to model a few of the most common ones and then allow the user to drop their own custom skylights into the library folder. However, I do get what you are saying on this, I may need to give it some more thought.
                    design.medeek.com
                    • jujuJ Offline
                      juju
                      Maybe touch base with Yoni at FlexTools, they seem to have that process licked!
                      • pbacotP Offline
                        Surface mount and curb mounted (typically on 2x6 framing over roof deck) are common. Velux is probably the standard though there are other types out there. In our area it's mostly Velux or something like that due to stringent energy requirements. You could have some of these, especially the ones meant to go into 24" o.c. framing. Then if you want branch out to some pyramidal or gable style skylights.
                        • medeekM Offline
                          medeek
                          Version 2.7.2 - 04.24.2020
                          • Added wall sheathing thickness and wall cladding thickness parameters to the advanced options for trusses.
                          • Enabled advanced options for tail bearing trusses.
                          http://design.medeek.com/resources/trussplugin/images/truss_su683_800.jpg
                          I still need to enable editing and labels for tail bearing trusses.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.7.2b - 04.24.2020
                            • Enabled the "Edit Truss Assembly" function for all tail bearing trusses (imperial and metric units).
                            • Labels and callouts added to tail bearing trusses.
                            http://design.medeek.com/resources/trussplugin/images/truss_su685_800.jpg
                            http://design.medeek.com/resources/trussplugin/images/truss_su684_800.jpg
                            This update also resolves a potential bug that could cause the plugin to go into a infinite loop if the birdsmouth cut exceeds the depth of the top chord of the truss. If you are using tail bearing trusses I highly recommend upgrading to this latest release.
                            The updated module is now properly creating the gypsum on the underside of the truss (three pieces).
                            design.medeek.com
                              db11
                              Do you have an option for strapping between the trusses and the gypsum?
                              • medeekM Offline
                                medeek
                                Yes, for some truss types it is enabled.
                                design.medeek.com
                                  db11
                                  OK, thanks.
                                  One other quick question: when do you expect to have your gable wall module completed?
                                  • medeekM Offline
                                    medeek
                                    Maybe I'll wrap that up next. I really want to get this skylight module up and running though in the next couple of days.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.7.3 - 04.26.2020
                                      • Added a Global Reset button in the General tab of the Global Settings.
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cd164f87f2a986d3ef495bb9a5cfa6335fd24e5.jpeg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.7.4 - 05.02.2020
                                        • Fixed a bug with the soffit and fascia module for all truss types.
                                        This bug fix is specifically for the boxed soffit for truss roofs. Previously if one did not enable the fascia but enabled the soffit then it would throw an error. There may be other similar bugs in this module or others so I am constantly testing combinations of various parameters to make sure no interdependencies have been overlooked.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.7.5 - 05.05.2020
                                          • Enabled a toggle feature (Ctrl key) for the Trim tool so that the selection can be retained or removed.
                                          This small adjustment of the Trim tool is to bring it inline with the Trim 2 tool. This feature is per customer request.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            First look at the skylight tool in action:
                                            https://aws1.discourse-cdn.com/sketchup/original/3X/e/4/e492b52c1392aaf9038a71a8d1042273df9e1549.jpeg
                                            Note, that this image shows the skylights added to a generic roof. For the cutouts to work the roof geometry must be a valid solid group or component within an overall assembly group for the roof or building.
                                            Initially there are three skylights (sizes) to choose from however it is possible to add your own skylights into the library.
                                            The cut function can be toggled on/off in order to cut through the sheathing and cladding or in this case just a generic roof solid.
                                            At some point I would also like to add in a few VELUX Sun Tunnels.
                                            Now I just need to figure out how to heal the roof when a skylight is deleted or edited. For a Medeek roof that is fairly straight forward, just regen the roof, however for a generic solid things get a little more tricky.
                                            design.medeek.com
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 75
                                            • 76
                                            • 67 / 76
