    3D Truss Models
    1.5k Posts 32 Posters 1.8m Views 31 Watching
    • medeekM
      medeek
      As we begin a new decade the number of licensed users of the Truss plugin is currently at 1,200. The plugin is now just over 4 years old, it will be interesting to see what we can do with it and the other plugins of the mdkBIM suite in this coming year.
      I am looking forward to completing the complex roof module as well as bringing the truss side of the house up to par with the rafter side within this module.
      Beyond that, it is the new floor plugin and project plugin as well as completing some key items with the wall plugin.
      Wishing everyone a happy and prosperous New Year.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        A study of intersecting roof planes and trusses:
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        I didn't spend any time trimming truss tails or worrying about the sheathing or cladding, I was mostly interested in the truss layout and roof planes.
        Note that I created the tertiary roof plane in order to then draw a solid (temp rafter) which I then used as the primary roof plane for the second valley set (45 degree).
        I've colored all of the temp geometry transparently so you can dissect the model a little easier.
        I'm not entirely sure if this is how a truss manufacturer would actually handle this type of situation, but this is my best guess.
        design.medeek.com
        • jujuJ
          juju
          I fired up a different truss type that I have not used before - attic truss. I work in metric (mm) but the attic truss is only imperial (ft / in). Roof pitch I work in is degrees, but am facing 1/12 ratio in imperial? Did I miss a setting somewhere?
          How many of the other trusses / subsections are not homogeneous to each other? Can all the section / subsections be brought onto par with each other?
          • medeekM
            medeek
            There are still a few truss types that do not have all of the advanced options available to them. To the best of my knowledge only the attic truss still does not have a metric interface when using a metric template in SketchUp, I will work on this.
            To check which features have been added to each truss type, do a browser search here:
            404 - File or directory not found.
            (design.medeek.com)
            design.medeek.com
            • medeekM
              medeek
              Version 2.6.6 - 01.29.2020
              • Fixed a bug in the (complex roofs) roof plane edit menu for the outlooker size parameter.
              • Fixed a bug involving truss assemblies and valley set assemblies that are created in the same SketchUp session.
              design.medeek.com
              • medeekM
                medeek
                Version 2.6.7 - 02.09.2020
                • Fixed a bug in the text input method of the draw menu for complex rafter roofs.
                • Added a T1-11 built-in material into the material library.
                design.medeek.com
                • medeekM
                  medeek
                  Version 2.6.8 - 04.10.2020
                  • Fixed a show_modal bug for macOS in the Timber Truss HTML menu dialog.
                  With this latest release I've had to migrate to the .rbe encryption system so this version will no longer run on SketchUp 2015 or earlier.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 2.6.9 - 04.11.2020
                    • Enabled the "Edit Truss Assembly" function for all parallel chord trusses (imperial and metric units).
                    • Labels and callouts added to parallel chord trusses.
                    http://design.medeek.com/resources/trussplugin/images/truss_su672_800.jpg
                    There are still a number of truss types and rafter roofs that still need edit capabilities, I am slowly working through this list.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 2.7.0 - 04.12.2020
                      • Enabled the "Edit Truss Assembly" function for all timber trusses (imperial and metric units).
                      http://design.medeek.com/resources/trussplugin/images/truss_su673_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.7.1 - 04.13.2020
                        • Enabled the "Edit Roof Assembly" function for shed w/ ledger rafter roofs (imperial and metric units).
                        • Enabled soffit and fascia for shed w/ ledger rafter roofs: boxed, gable, angled.
                        • Enabled a roof cladding extension parameter for shed w/ ledger rafter roofs.
                        • Added the option in the shed w/ ledger rafter roof edit menu to specify a separate front and back overhang length.
                        • Enabled a "No Framing" mode for shed w/ ledger rafter roofs.
                        http://design.medeek.com/resources/trussplugin/images/truss_su674_800.jpg
                        design.medeek.com
                        • medeekM
                          medeek
                          Skylights have not been on my official todo list but now they are.
                          I've actually been tossing the Skylight idea around for a while now, how best to implement it within the various roof modules. I've got some ideas already but I haven't finalized it yet.
                          Does anyone have any specifics or suggestions on the actual skylight models/components that I should use. Specific brands, reference drawings, that sort of thing.
                          My thinking is to have some fairly generic skylight models that the user could chose from. The skylight module would then bring these components into the model and also cut the corresponding holes in the roof cladding and sheathing. I would also have a tool for editing and deleting a skylight. As far as moving the skylight on the roof plane, I would allow the user to simply click into the roof assembly and moving the skylight with the native tools as they see fit, this would be the simplest way of handling re-positioning.
                          Again, I'm still tossing this idea around, trying to shake out the best system for implementing it, any feedback is appreciated.
                          design.medeek.com
                          • medeekM
                            medeek
                            Velux has their official models in the warehouse but as usual there are too many details in these models, so I had to create my own low poly versions that are dimensionally accurate:
                            https://3dwarehouse.sketchup.com/warehouse/v1.0/publiccontent/7a9c9925-45e3-4a46-8dba-bd543d1f1065
                            3D Warehouse
                            design.medeek.com
                            • jujuJ
                              juju
                              3D Warehouse
                              Different manufacturers have different sizes. A single well constructed DC, where you can enter the overall sizing on a dialogue, would probably be more useful and cause less bloating of the extension?
                              • medeekM
                                medeek
                                First look at the Skylights Toolbar:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/9/c/9c74f6e602266b8ada8dc6c6c1b1b855034a2373.jpeg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I've thought about this however there are quite a few different types of skylights (ie. surface mount, curb mount, round etc...) so it would seem to make more sense to model a few of the most common ones and then allow the user to drop their own custom skylights into the library folder. However, I do get what you are saying on this, I may need to give it some more thought.
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    Maybe touch base with Yoni at FlexTools, they seem to have that process licked!
                                    • pbacotP
                                      Surface mount and curb mounted (typically on 2x6 framing over roof deck) are common. Velux is probably the standard though there are other types out there. In our area it's mostly Velux or something like that due to stringent energy requirements. You could have some of these, especially the ones meant to go into 24" o.c. framing. Then if you want branch out to some pyramidal or gable style skylights.
                                      • medeekM
                                        medeek
                                        Version 2.7.2 - 04.24.2020
                                        • Added wall sheathing thickness and wall cladding thickness parameters to the advanced options for trusses.
                                        • Enabled advanced options for tail bearing trusses.
                                        http://design.medeek.com/resources/trussplugin/images/truss_su683_800.jpg
                                        I still need to enable editing and labels for tail bearing trusses.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 2.7.2b - 04.24.2020
                                          • Enabled the "Edit Truss Assembly" function for all tail bearing trusses (imperial and metric units).
                                          • Labels and callouts added to tail bearing trusses.
                                          http://design.medeek.com/resources/trussplugin/images/truss_su685_800.jpg
                                          http://design.medeek.com/resources/trussplugin/images/truss_su684_800.jpg
                                          This update also resolves a potential bug that could cause the plugin to go into a infinite loop if the birdsmouth cut exceeds the depth of the top chord of the truss. If you are using tail bearing trusses I highly recommend upgrading to this latest release.
                                          The updated module is now properly creating the gypsum on the underside of the truss (three pieces).
                                          design.medeek.com
                                            db11
                                            Do you have an option for strapping between the trusses and the gypsum?
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 76
                                            • 77
                                            • 67 / 77
