    3D Truss Models
    1.5k Posts 32 Posters 1.8m Views 31 Watching
    • medeekM
      medeek
      @juju said:
      Different manufacturers have different sizes. A single well constructed DC, where you can enter the overall sizing on a dialogue, would probably be more useful and cause less bloating of the extension?
      I've thought about this however there are quite a few different types of skylights (ie. surface mount, curb mount, round etc...) so it would seem to make more sense to model a few of the most common ones and then allow the user to drop their own custom skylights into the library folder. However, I do get what you are saying on this, I may need to give it some more thought.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ
        juju
        Maybe touch base with Yoni at FlexTools, they seem to have that process licked!
        • pbacotP
          Surface mount and curb mounted (typically on 2x6 framing over roof deck) are common. Velux is probably the standard though there are other types out there. In our area it's mostly Velux or something like that due to stringent energy requirements. You could have some of these, especially the ones meant to go into 24" o.c. framing. Then if you want branch out to some pyramidal or gable style skylights.
          • medeekM
            medeek
            Version 2.7.2 - 04.24.2020
            • Added wall sheathing thickness and wall cladding thickness parameters to the advanced options for trusses.
            • Enabled advanced options for tail bearing trusses.
            http://design.medeek.com/resources/trussplugin/images/truss_su683_800.jpg
            I still need to enable editing and labels for tail bearing trusses.
            design.medeek.com
            • medeekM
              medeek
              Version 2.7.2b - 04.24.2020
              • Enabled the "Edit Truss Assembly" function for all tail bearing trusses (imperial and metric units).
              • Labels and callouts added to tail bearing trusses.
              http://design.medeek.com/resources/trussplugin/images/truss_su685_800.jpg
              http://design.medeek.com/resources/trussplugin/images/truss_su684_800.jpg
              This update also resolves a potential bug that could cause the plugin to go into a infinite loop if the birdsmouth cut exceeds the depth of the top chord of the truss. If you are using tail bearing trusses I highly recommend upgrading to this latest release.
              The updated module is now properly creating the gypsum on the underside of the truss (three pieces).
              design.medeek.com
                db11
                Do you have an option for strapping between the trusses and the gypsum?
                • medeekM
                  medeek
                  Yes, for some truss types it is enabled.
                  design.medeek.com
                    db11
                    OK, thanks.
                    One other quick question: when do you expect to have your gable wall module completed?
                    • medeekM
                      medeek
                      Maybe I'll wrap that up next. I really want to get this skylight module up and running though in the next couple of days.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.7.3 - 04.26.2020
                        • Added a Global Reset button in the General tab of the Global Settings.
                        https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cd164f87f2a986d3ef495bb9a5cfa6335fd24e5.jpeg
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.7.4 - 05.02.2020
                          • Fixed a bug with the soffit and fascia module for all truss types.
                          This bug fix is specifically for the boxed soffit for truss roofs. Previously if one did not enable the fascia but enabled the soffit then it would throw an error. There may be other similar bugs in this module or others so I am constantly testing combinations of various parameters to make sure no interdependencies have been overlooked.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.7.5 - 05.05.2020
                            • Enabled a toggle feature (Ctrl key) for the Trim tool so that the selection can be retained or removed.
                            This small adjustment of the Trim tool is to bring it inline with the Trim 2 tool. This feature is per customer request.
                            design.medeek.com
                            • medeekM
                              medeek
                              First look at the skylight tool in action:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/e/4/e492b52c1392aaf9038a71a8d1042273df9e1549.jpeg
                              Note, that this image shows the skylights added to a generic roof. For the cutouts to work the roof geometry must be a valid solid group or component within an overall assembly group for the roof or building.
                              Initially there are three skylights (sizes) to choose from however it is possible to add your own skylights into the library.
                              The cut function can be toggled on/off in order to cut through the sheathing and cladding or in this case just a generic roof solid.
                              At some point I would also like to add in a few VELUX Sun Tunnels.
                              Now I just need to figure out how to heal the roof when a skylight is deleted or edited. For a Medeek roof that is fairly straight forward, just regen the roof, however for a generic solid things get a little more tricky.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 2.7.6 - 05.11.2020
                                • Added the Skylights toolbar.
                                • Enabled skylights for all truss, rafter and complex roofs.
                                • Enabled skylights for generic roofs.
                                http://design.medeek.com/resources/images/skylight_su_menu_active.jpg
                                http://design.medeek.com/resources/trussplugin/images/truss_su696_800.jpg
                                I also added an additional tool for "regenerating" the skylights, this comes in handy after modifying the location of a skylight or if a Medeek roof gets regenerated and the holes in the sheathing and cladding need to be re-cut.
                                There are few new global settings I still need to add to fully complete this new module but overall it seems to be working quite nicely.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  View model here:
                                  3D Warehouse
                                  (3dwarehouse.sketchup.com)
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    thanks
                                    since we're expanding with more buttons, how's the work on reducing the amount of buttons on the taskbar coming along?
                                    • medeekM
                                      medeek
                                      Tutorial 18: Skylights (14.22 min.)
                                      I often get a lot of questions that are answered in the tutorial videos. Just a reminder, all of the tutorial videos can be found here:
                                      404 - File or directory not found.
                                      (design.medeek.com)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 2.7.7 - 07.31.2020
                                        • Fixed a bug with all assemblies when auto-assignment of materials is turned off in the global settings.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          I've been giving some serious thought to the estimating module the last couple of days as I regroup and review my various todo lists.
                                          I would like to spend a few days and update the estimating module to include rafter roofs. However, as I think about rafters and their lengths I am wondering what length exactly are we talking about? Do we want the actual (longest length of the member) or do we want a horizontal projection of the length? Typically both the top and bottom of a rafter has a bevel cut or even a compound bevel cut.
                                          The ridge board on the other hand is very simple (generally). There are no beveled end cuts so things are straight forward.
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/2/7/27cc852c1a571a27fe926f23e0b8591f310daf2f.gif
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/0/c/0c89f620606e1359664b082cc526b96792472d7d.gif
                                          design.medeek.com
                                          • pbacotP
                                            I would think that for estimating you need the longest dimension of the rafter, then extrapolate to the nexthigher board length.
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 76
                                            • 77
                                            • 67 / 77
