    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 297.7k Views 17 Watching
    • halroachH Offline
      halroach
      https://flextools.cc/wp-content/uploads/2019/08/flex_components_04_09-faster-750-e.gif
      Quick demonstration of FlexTools in action
      FlexTools - Super Quick Windows, Doors, Slats...
      • halroachH Offline
        halroach
        See how you can create different types of dynamic windows and doors by combining a few flex components in our latest blogpost.
        • halroachH Offline
          halroach
          This video is part of Justin's recent series 'SketchUp Extensions for Architecture'.
          FlexTools is in the top 20 favorites! Yoo-hoo! 😄
          https://flextools.cc/blog/flextools-overview-from-the-sketchup-essentials/
          https://flextools.cc/wp-content/uploads/2019/11/yt-The-SketchUp-Essentials-FlexTools-1024x576.jpg
          • halroachH Offline
            halroach
            Introducing a new flex component - FlexRamp.
            From now on you’ll be able to create sloped walkways & parking lot ramps in seconds!
            Learn more in the blog: https://flextools.cc/blog/flexramp
            https://flextools.cc/wp-content/uploads/2019/11/FlexRamp_02_02e.gif
              pibuz
              This is real wonder 😍 😍 😍 😍
              WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
              • halroachH Offline
                halroach
                Meet the new FlexDoor Glass component!
                Now you can easily create different dynamic glass doors with additional panels and multiple muntin distributions. The detailed documentation is in the works.
                See more at https://flextools.cc/blog/new-flexdoor-glass/
                  pibuz
                  So cool! Thanks!
                  ...did you guys had a look to the bug that I reported some time ago, about componentfinder including objects in folders different from the selected?
                  https://sketchucation.com/forums/viewtopic.php?f=403&t=71638
                  • utilerU Offline
                    utiler
                    This is so so good!!! Congratulations to you guys to continually listening to your user base and implementing new features! 👍 👍 👍
                    Just Curious...
                    • halroachH Offline
                      halroach
                      @pibuz said:
                      So cool! Thanks!
                      Yes, we'll try to have this fixed in the next ComponentFinder update.
                        pibuz
                        Wonderful! Thanks!!!!
                        • halroachH Offline
                          halroach
                          Check out the updated FlexDoor & FlexDoor Glass - Learn Page.
                          Find out what you can do with these flex components, including how to change the glass distributions, assign materials, make a glass pivot door, and more.
                          https://flextools.cc/wp-content/uploads/2020/03/FlexDoor-Glass_main-anim_02-gif_03.gif
                          • utilerU Offline
                            utiler
                            Super cool additions guys...!! nice to see you expanding this great suite of tools!!
                            Just Curious...
                            • halroachH Offline
                              halroach
                              Many thanks to Justin from 'The SketchUp Essentials' for a great FlexDoor Glass review!
                              • halroachH Offline
                                halroach
                                • mogrenM Offline
                                  mogren
                                  UN bonus serait d'avoir dans le arch window une possibilité paramétrable d'entourage de l'arc (voir capture)
                                  Je ne sais pas si c'est une tannée de programmation.
                                    On doit pouvoir tricher avec une texture! 😉
                                    Maybe cheat with a texture ?
                                      Even by default, it's not so bad! 😄
                                      Separate for have more size acceptable (no made here! 😄
                                      • mogrenM Offline
                                        mogren
                                        Oui.. un peu long comme mise en oeuvre tout ça.
                                        De mon coté j'avais recréé une arche avec l'outil décalage, fermée avec même diamètre et même nombre de segments (nombre impair pour la clé de voute) juste au-dessus de mon composant puis utilisé le plugin Split tool pour l'appareillage qui s'adapte aux segments
                                        En dernière étape si je veux que l'appareillage soit saillant du nu du mur: un Fredo's Joint push pull pour l'extrusion de toutes les pierres ou au choix une par une.
                                        D'ailleurs au moment de ce dernier l'application a sauté, je me demande si ce n'est pas un conflit entre Joint push pull et Split view?
                                        C'est une méthode aussi trop longue, le but de ma question s'adressait au dévellopeur de Flex s'il imaginait pouvoir rajouter la fonction à l'Archwindow (qui est déjà très pratique)
                                          Il semble qu'il a pris bonne note et donné une cool astuce! ☀ (voir 2 posts plus haut! 😉
                                          • mogrenM Offline
                                            mogren
                                            What I would like ☀
                                            • 5 / 9
