    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
      JDW Interiors
      Hi all,
      I've downloaded Fredoscale for my MacBook Pro 2018 but I can't seem to open it. I am running sketchup 2020.
      I firstly downloaded it from sketchUcation and then I went to 'Window>Extension manager>Install extension'
      In the extension manager it says the app is signed but I can't see how I can open the window and use the fredoscale tools.
      Can anyone help?
      Thanks in advance!
      Jack
        Have you quit out of SketchUp and reopened it to make sure both extensions load completely? After you do that you should be able to see the FredoScale tool palette in View>Tool palettes.
        • fredo6F
          NEW RELEASE: LibFredo6 v9.5k - 14 Mar 20
          LibFredo6 9.5k is a major release
          1. Fixes a bug preventing all my plugins to work with some configurations of MacOS Catalina
          2. Introduces a 'toolbar visibility' button in all the QuickLauncher dialogs of my plugins. This makes it easier to manage the visibility of icons in the toolbar, which was already available in the Default Parameters. You need to restart Sketchup for the changes to be effective.
          As an example, here is the new layout of the FredoScale QuickLauncher, with the visibility toggle buttons on the right (small eye).
          • E
            Elrodrules
            Hi -
            I had installed LibFredo6 9.5j and that was working fine. Today I tried to update to LibFredo6 9.5k and now I'm getting the following error(s). I'm using SketchUp Make 17.3.116 on a MacBook Air running macOS Catalina. I have quit and reopened SketchUp several times and the result is the same. Any suggestions?
            The first error window says:
            Curviloft 1.8a: Error starting up plugin (creating menus and icons)
            undefined method declare_topmenu' for #<Traductor::Plugin:0x007faf20183c70> [in bootstrap_curviloft.rbe: - #startup(): line 87]
            /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in `rescue in block in effective_load_part2'
            I click 'OK' and a second error window opens with these strings:
            Error: #<NameError: uninitialized constant Traductor::Plugin::T6>
            /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1072:in effective_load_part2' /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1003:in effective_load'
            /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_curviloft/__loader__curviloft.rbe:1:in <main>' /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in eval'
            /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require' /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load'
            /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:57:in register_extension' /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:57:in module:Fredo6'
            /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in `<top (required)>'
              maotine
              Thank
              • B
                BjR55
                I've logged into Sketchucation and have been trying to download the Round Corner extension and I've tried several times after viewing the video and I keep getting this error message pop up after it downloads:
                [img]
                [attachment=0:2dc108c7]<!-- ia0 -->Error%20message%20when%20downloading%20Round%20Corner%20Ext%20from%20LibFredo6.JPG<!-- ia0 -->[/attachment:2dc108c7]
                [/img]
                error message after downloading plug in
                  When you Download any file you can specify where to 'save it' OR what app will 'open it'.
                  A SketchUp RBZ archive is NOT 'opened' by anything when you download it.
                  In its case you need to 'save' it into your Downloads folder...
                  This is part of your browser's settings, and what options you choose in the download settings for each file-type...
                  When the RBZ is saved you can now install it using SketchUp...
                  Open the Window > Extension Manager and use the red-button 'Install Extension'.
                  When prompted, navigate to the RBZ's location and select it.
                  SketchUp now automatically installs the archive's contents into the correct locations in your ../Users/.../Plugins folder etc.
                  You posted this in the LibFredo6 thread...
                  BUT in the case of almost all of Fredo's Extensions you do need to have the LibFredo installed.
                  This 'helper' adds vital functions to other Fredo Extensions you install.
                  So first install the LibFredo RBZ as outlined above, then install the other Fredo Extensions' RBZ files as you want - like RoundCorner or FredoCorner etc...
                  Note that unlike 'standalone' ones, with Extensions that use a 'Lib' - like Fredo's [& thomthom's] you should restart SketchUp after the installations to ensure that everything gets synced properly...
                    Jas13
                    Bonjour!
                    Merci pour votre tuto d'installation qui était assez clair et pour les extensions.
                    Cependant j'ai la version pro 2018 et quand je vais dans fenêtre -> préférences, il n'y a pas extensions dans les options, de ce fait je ne peux pas installer complètement l'extension.
                    Si vous aviez une solution svp
                    merci beaucoup!
                    bien à vous
                    • fredo6F
                      Le menu est au premier niveau, sous l'entrée Extension Manager, pas dans Preferences
                        Jas13
                        désolé, je n'ai pas été suffisamment précise. Le problème que je rencontre est:
                        je vais dans fenêtre -> gestionnaires d'extension -> installer l'extension choisissant donc le fichier et l'ouvrant
                        il se situe bien dans le gestionnaire mais bien qu'activer je ne vois aucun changement dans mes barres d'outils même en fermant et rouvrant l'application.
                        Dans le gestionnaire l'icône de l'extension est sous la forme d'un diamant gris.
                        je ne sais pas si je suis assez claire, mais du coup voilà.
                        Désolé de vous embêter,mais c'est que j'ai d('besoin de vos extensions pour réaliser mes maquettes en 3D et après faire du rendu
                        bien à vous.
                        • fredo6F
                          LibFredo6 n'ajoute aucune barre d'outils. C'est juste une librarie, qui n'a d'intérêt que si un autre de mes plugins est installé (comme RoundCorner, FredoScale, ...).
                          Toutefois, LibFredo6 ajoute un menu Window > LibFredo6 Settings... s'il est bien installé.
                            AARo
                            Bonjour,
                            J'ai télécharge ce jour le Plug "Libfredo6" et "joinPushPull" sur Sketch'up 2020; suivant indications du tuto. Téléchargement, installation par le gestionnaire.
                            A l'ouverture de SketchUp le message suivant s'affiche
                            Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                            Error: #<ArgumentError: invalid byte sequence in UTF-8>
                            c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in match' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in block (2 levels) in load_from_config'
                            c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in each' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block in load_from_config'
                            c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in foreach' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in load_from_config'
                            c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in block in load_all_plugins' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in each'
                            c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in load_all_plugins' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:254:in startup'
                            C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                            C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Erreur de chargement du fichier Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                            C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                            C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
                            C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
                            Par avance merci de votre aide.
                              AARo
                              J'ai résolu au final le problème, il traînait un vieux fichier "ZLoader__OnSurface" dans le dossier Plugins.
                              J'ai réalisé un grand nettoyage et réinstallé Plug par Plug et cela marche !
                              • F
                                fedser
                                Hi Fredo6, I have a little problem with your plugins in SketchUp 2020
                                "FredoTools 3.8c" plugin does not display "svg" icons. Color palettes in "Color Paint" do not work. Window size is not saved in all your plugins. In SketchUp 2019, everything was great. (Installed LibFredo6 9.5k). Perhaps this information will help make your plugins perfect. Thank you for your work.
                                P.S. Sorry for my English 😄
                                • fredo6F
                                  Which Windows system do you have?
                                  Do you always get the problem on SU2020 or since you moved to LibFredo6 9.5k?
                                  • F
                                    fedser
                                    Windows 10 Home (v.1903 single language)
                                    Installed LibFredo6 9.5k when switching to SU2020 (clean installation) another version of the plugin is no longer available. I tried a set of SU2019 + LibFredo6 9.5k works fine.
                                    • fredo6F
                                      There is something wrong with SU2020 as it seems to use settings for the embedded API to HTML which is not HTML5, explaining no SVG support and all other sorts of visual problems.
                                      I have heard of the problem, but do not remember where.
                                      • F
                                        fedser
                                        I tried to say this. But I am not a developer and I can not express myself correctly. I wanted to convey this information to you because you began to use svg often and in SU2020 you will run into a problem. Your plugins are wonderful and we all hope that they will be even better, thank you.
                                          @fedser
                                          When you installed SketchUp v2020 did you do it correctly ?
                                          An incorrect installation can cause unexpected and weird issues...
                                          This is the correct way to do it - when it's already installed you can do a "Repair", which shouldn't affect your personal set up...
                                          While logged into your usual Windows user-account ensure SketchUp is not running.
                                          Fine the SketchUp installer's exe file - usually in your Downloads folder ?
                                          Select that exe file's icon, right-click > context-menu > "Run as administrator"
                                          When prompted choose "Repair"
                                          When it's completed restart SketchUp and see if it's any better...
                                          Installing a complex app's installer's exe file in any other way will cause unpredictable issues.
                                          So never double-click on the installer's exe file to "Run" it... even if your normal-user has admin-powers it is NOT the same as doing it as I outlined above...
                                          • F
                                            fedser
                                            @TIG
                                            This action does not solve the problem. I always install SU with administrator rights. I tried to install it on another computer. Problem still exists. The "Portrait" plugin also has a problem with svg. The plugin itself is working properly. SU2019 doesn't have this problem. Maybe this problem is only with me, I wanted to know how it works on your SU2020?
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 113
                                            • 114
                                            • 76 / 114
