    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
      The image is missing you cannot link to a file that is on your own PC !
      Try copy/paste ?
        Sunxl
        Try copy/paste ?
        Sorry,this is my first time to use this.
        the problem shown as below
        载入文件 C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe 时出错
        Failed to read RBE/RBS file.
        载入文件 Fredo6_!LibFredo6.rb 时出错
        Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
        C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
        C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
        thank you
        • fredo6F Offline
          This 'failed to load RBS/RBE' seems to be a problem related to the installation of Sketchup.
          Could you reinstall it, with 'run as administrator'.
            Sunxl
            Yes, I did. But the error still exist.
            I didn’t find any available solutions to deal with it.
              JDW Interiors
              Hi all,
              I've downloaded Fredoscale for my MacBook Pro 2018 but I can't seem to open it. I am running sketchup 2020.
              I firstly downloaded it from sketchUcation and then I went to 'Window>Extension manager>Install extension'
              In the extension manager it says the app is signed but I can't see how I can open the window and use the fredoscale tools.
              Can anyone help?
              Thanks in advance!
              Jack
                Have you quit out of SketchUp and reopened it to make sure both extensions load completely? After you do that you should be able to see the FredoScale tool palette in View>Tool palettes.
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v9.5k - 14 Mar 20
                  LibFredo6 9.5k is a major release
                  1. Fixes a bug preventing all my plugins to work with some configurations of MacOS Catalina
                  2. Introduces a 'toolbar visibility' button in all the QuickLauncher dialogs of my plugins. This makes it easier to manage the visibility of icons in the toolbar, which was already available in the Default Parameters. You need to restart Sketchup for the changes to be effective.
                  As an example, here is the new layout of the FredoScale QuickLauncher, with the visibility toggle buttons on the right (small eye).
                  • E Offline
                    Elrodrules
                    Hi -
                    I had installed LibFredo6 9.5j and that was working fine. Today I tried to update to LibFredo6 9.5k and now I'm getting the following error(s). I'm using SketchUp Make 17.3.116 on a MacBook Air running macOS Catalina. I have quit and reopened SketchUp several times and the result is the same. Any suggestions?
                    The first error window says:
                    Curviloft 1.8a: Error starting up plugin (creating menus and icons)
                    undefined method declare_topmenu' for #<Traductor::Plugin:0x007faf20183c70> [in bootstrap_curviloft.rbe: - #startup(): line 87]
                    /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in `rescue in block in effective_load_part2'
                    I click 'OK' and a second error window opens with these strings:
                    Error: #<NameError: uninitialized constant Traductor::Plugin::T6>
                    /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1072:in effective_load_part2' /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1003:in effective_load'
                    /users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_curviloft/__loader__curviloft.rbe:1:in <main>' /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in eval'
                    /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require' /Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load'
                    /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:57:in register_extension' /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:57:in module:Fredo6'
                    /Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in `<top (required)>'
                      maotine
                      Thank
                        BjR55
                        I've logged into Sketchucation and have been trying to download the Round Corner extension and I've tried several times after viewing the video and I keep getting this error message pop up after it downloads:
                        [img]
                        [attachment=0:2dc108c7]<!-- ia0 -->Error%20message%20when%20downloading%20Round%20Corner%20Ext%20from%20LibFredo6.JPG<!-- ia0 -->[/attachment:2dc108c7]
                        [/img]
                        error message after downloading plug in
                          When you Download any file you can specify where to 'save it' OR what app will 'open it'.
                          A SketchUp RBZ archive is NOT 'opened' by anything when you download it.
                          In its case you need to 'save' it into your Downloads folder...
                          This is part of your browser's settings, and what options you choose in the download settings for each file-type...
                          When the RBZ is saved you can now install it using SketchUp...
                          Open the Window > Extension Manager and use the red-button 'Install Extension'.
                          When prompted, navigate to the RBZ's location and select it.
                          SketchUp now automatically installs the archive's contents into the correct locations in your ../Users/.../Plugins folder etc.
                          You posted this in the LibFredo6 thread...
                          BUT in the case of almost all of Fredo's Extensions you do need to have the LibFredo installed.
                          This 'helper' adds vital functions to other Fredo Extensions you install.
                          So first install the LibFredo RBZ as outlined above, then install the other Fredo Extensions' RBZ files as you want - like RoundCorner or FredoCorner etc...
                          Note that unlike 'standalone' ones, with Extensions that use a 'Lib' - like Fredo's [& thomthom's] you should restart SketchUp after the installations to ensure that everything gets synced properly...
                            Jas13
                            Bonjour!
                            Merci pour votre tuto d'installation qui était assez clair et pour les extensions.
                            Cependant j'ai la version pro 2018 et quand je vais dans fenêtre -> préférences, il n'y a pas extensions dans les options, de ce fait je ne peux pas installer complètement l'extension.
                            Si vous aviez une solution svp
                            merci beaucoup!
                            bien à vous
                            • fredo6F Offline
                              Le menu est au premier niveau, sous l'entrée Extension Manager, pas dans Preferences
                                Jas13
                                désolé, je n'ai pas été suffisamment précise. Le problème que je rencontre est:
                                je vais dans fenêtre -> gestionnaires d'extension -> installer l'extension choisissant donc le fichier et l'ouvrant
                                il se situe bien dans le gestionnaire mais bien qu'activer je ne vois aucun changement dans mes barres d'outils même en fermant et rouvrant l'application.
                                Dans le gestionnaire l'icône de l'extension est sous la forme d'un diamant gris.
                                je ne sais pas si je suis assez claire, mais du coup voilà.
                                Désolé de vous embêter,mais c'est que j'ai d('besoin de vos extensions pour réaliser mes maquettes en 3D et après faire du rendu
                                bien à vous.
                                • fredo6F Offline
                                  LibFredo6 n'ajoute aucune barre d'outils. C'est juste une librarie, qui n'a d'intérêt que si un autre de mes plugins est installé (comme RoundCorner, FredoScale, ...).
                                  Toutefois, LibFredo6 ajoute un menu Window > LibFredo6 Settings... s'il est bien installé.
                                    AARo
                                    Bonjour,
                                    J'ai télécharge ce jour le Plug "Libfredo6" et "joinPushPull" sur Sketch'up 2020; suivant indications du tuto. Téléchargement, installation par le gestionnaire.
                                    A l'ouverture de SketchUp le message suivant s'affiche
                                    Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                                    Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                    c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in match' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in block (2 levels) in load_from_config'
                                    c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in each' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block in load_from_config'
                                    c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in foreach' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in load_from_config'
                                    c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in block in load_all_plugins' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in each'
                                    c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in load_all_plugins' c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:254:in startup'
                                    C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                    C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Erreur de chargement du fichier Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                    C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                                    C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
                                    C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
                                    Par avance merci de votre aide.
                                      AARo
                                      J'ai résolu au final le problème, il traînait un vieux fichier "ZLoader__OnSurface" dans le dossier Plugins.
                                      J'ai réalisé un grand nettoyage et réinstallé Plug par Plug et cela marche !
                                      • F Offline
                                        fedser
                                        Hi Fredo6, I have a little problem with your plugins in SketchUp 2020
                                        "FredoTools 3.8c" plugin does not display "svg" icons. Color palettes in "Color Paint" do not work. Window size is not saved in all your plugins. In SketchUp 2019, everything was great. (Installed LibFredo6 9.5k). Perhaps this information will help make your plugins perfect. Thank you for your work.
                                        P.S. Sorry for my English 😄
                                        • fredo6F Offline
                                          Which Windows system do you have?
                                          Do you always get the problem on SU2020 or since you moved to LibFredo6 9.5k?
                                          • F Offline
                                            fedser
                                            Windows 10 Home (v.1903 single language)
                                            Installed LibFredo6 9.5k when switching to SU2020 (clean installation) another version of the plugin is no longer available. I tried a set of SU2019 + LibFredo6 9.5k works fine.
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 78
                                            • 111
                                            • 112
                                            • 76 / 112
