    [Plugin] Fix Reversed Face Materials
    Scheduled Pinned Locked Moved Solved Plugins
    83 Posts 26 Posters 128.9k Views 26 Watching
      It would help to see the component that is not getting fixed. There are some cases where it might not be clear as to which faces are incorrectly oriented.
        This tool only fixes Faces which have the wrong orientation AND have a Material applied onto their back-side rather than their front-side.
        It in effect flips the Face over [aka 'reverse'] and swaps the Material from back to front sides, keeping its UVmapping [you cannot UVmap a Texture unless its applied directly onto a Face].
        This tool does NOT sort out issues when a Material has been applied onto a Group or Component-Instance.
        The Faces inside the Container which have no Material assigned will display with the Container's Material, BUT they will actually have the default 'nil' Material ! Look in Entity Info to see this while editing... The Container's Material is displayed for both front and backs of Faces with 'nil' Material in equal measure...
        View things in MonoChrome Mode...
        Use a Style with a highly distinctive back-face color.
        Use the context-menu Reverse/Orient tools to fix the faces that are reversed...
        • K
          kennundrum
          TIG/Dave, attached is a skp file that is an example of what I'm talking about. This model has been created in SoftPlan (my CAD program) and exported as a 3DS file, then imported into SketchUp. All I've done to it was run thomthom's CleanUp³ to reduce file size. Thanks in advance for any insight/help!
          MORGAN PIGEONIERRE_RAW.skp
            As TIG wrote, "This tool only fixes Faces which have the wrong orientation AND have a Material applied onto their back-side." Your model has the faces reversed but the materials are applied to the front faces. You might try Didier Bur's Automatic Face Reverser.
            I have to say, that's an annoying model to work on. With it turned at an angle relative to the axes, all the bounding boxes are skewed. That could lead to all sorts of headaches getting materials applied in SU. If someone sent that to me to work on, I'd charge extra. Do you have to draw them in your CAD program and import them into SketchUp. Wouldn't it be easy enough to draw that in SketchUp to start with?
            • sdmitchS
              sdmitch
              As Dave said, the fronts of some faces are on the inside. If you can use an exploded model, I have one that has the inward looking faces reversed but I had to explode all components/groups for an old plugin of mine to work.
              http://sdmitch.blogspot.com/
              • K
                kennundrum
                Sorry about that annoying model, it was a small part of a larger project that I grabbed because it would be of a size that I could transmit. I understand now why I wasn't having any success. The materials were all attached to the "front" faces though facing in the wrong direction in many cases. That is due to the export/import process - many faces get "confused" as to which way they should face. There still appears to be no quick way to process faces that have been reversed in a large imported model. I have several other face reverser plugins, the one that seems to work best though not perfect is a view-based tool that utilizes a screen area selection. I'll try Didier's plugin. Oops, I think the one I just described IS Didier's plugin! Thanks for the help.
                  Here it is in Monochrome Mode with a Blue Back-face Style...MonchromeMode+BlueBackFaceStyle.png
                  Use the context-menu 'Reverse...' - or one of the several available script tools that assist with fixing this kind of sloppy modeling...
                  Also as Dave said - having skewed axes is really annoying !
                  • K
                    kennundrum
                    Thanks for the tips. Exporting out of my CADD software where I actually build the model is what is causing the "sloppiness" of the reversed faces. That little pigeonierre was an ancillary building on a large homesite and was at a skewed angle on the property in relation to the home. I am trying to up my game in SU because I'm being asked to submit models in that format more frequently and having to deal with the faces seems to take more time than it would to actually build the model from scratch.
                    That being said, I can now see the point of view behind TIG's fix reversed faces tool - that of having the model being created 100% in SU and the sloppiness coming from users not making sure the correct faces face outward before painting them with a texture. My situation is different insofar as my faces come in already textured but in the import process, many get turned around. The correct face is still painted - just reversed - and they often number in the tens of thousands! Looks like it's time to get serious about SketchUp!
                      It does seem to me to be a good idea to leave the CAD program behind and just work in SketchUp. I would expect you'd reduce the time spent because you can prevent the sloppiness as you go.
                      Another thing that shows in your model that could be avoided is different components that are identical. For example, the corner pieces on the roof in your model are each a component. They could be instances of the same component instead. then when you apply the material to the faces in the component, it would apply to all of them at once. It's a good thing to have them as components but you gain in efficiency when they are instances of the same component.
                      • L
                        LBMartin
                        Hi TIG. I have not enough time to say thank you for this plugin. You save my design project with this excellent app. You save a lot of my time changing faces in a 56.000 polygons project. Thank you!!!
                          roomoon
                          Hi there TIG,
                          amazing plugin. Am I right in thinking that this will not return the textures on the 'back' of faces to default grey/white colour? I have a model here where a lot of the textures were applied in a blanket manner to the components and their interiors now have textures.
                          what would you recommend, this seems like the right tool, but perhaps im misusing it.
                          Thank you,
                          • B
                            BMPatel1441
                            Delete Back=materials not working if same materials are applied on both side ( front and back face ). Update the plugin accordingly.
                              I just tested this in SketchUp 2023 and it works fine for me. What version of SketchUp are you using? Your profile indicates SketchUp Free/Make 2020 which does not and never has existed.
                              • pep75P
                                pep75
                                I just installed this plugin in the 2026 version but it doesn't do anything? Does anyone has the same problem? Am I doing something wrong?
                                Dave RD 1 Reply Last reply
                                  Have you read the instructions ?
                                  There are several tools to reverse faces and change their materials/textures.
                                  Decide what it is you want to do...
                                  What are you trying to do, explain simple steps and issues [keep the Ruby Console open to see any error messages]
                                  Toggle between default face-view and textured-face view to see changes...
                                  It works fine for me with v2026.
                                    Dave R @pep75
                                    @pep75 I just installed it in SU2026 and gave it a try. It seems to do what it says on the tin. The back face color is green.
                                    1 Reply Last reply 👍
                                    Reply Quote 2
                                    • Rich O BrienR Rich O Brien marked this topic as a question on
                                    • 4 / 5
