    Updating Fredo6 Round Corners fails
    10 Posts 7 Posters 8.2k Views 7 Watching
    • B
      Brassovitski
      I have big trouble installing the latest version of the Round Corner plugin.
      I have uninstalled the old version, and the old version of Libfredo.
      I have installed the new Libfredo6_v9.5a.rbz, and after a restart, I have installed the version FredoCorner_v1.7c.rbz.
      After restarting Sketchup Make 2017, when I'm trying to use the extension, I get a message box:
      "This version of FredoCorner has expired. Please upgrade to latest version".
      Isn't FredoCorner_v1.7c.rbz the latest version??
      Please help.
      I don' know what I'm doing wrong.
      Sincerely Per Krog
        The current version of LibFredo6 is 9.5j. The latest version of FredoCorner is 1.7d. You might start by updating to the current versions.
        • B
          Brassovitski
          I found out that the link I used to download, downloaded version 1.7, even though it had version 3.3A, on the page. I've now downloaded LibFredo6_v9.5j.rbz, and RoundCorner_v3.3a.rbz, and it's working fine.
            What link was that?
            • pbacotP
              Thank you Dave. I felt quite clever for a moment there. I guess one could save the style and pull it up on an as-needed basis.
              • fredo6F
                @brassovitski said:
                There are 2 different plugins
                • RoundCorneris the older version, for SU8 and above - Current release is v3.3a
                • FredoCorneris a newer version for SU2017 and above, with more capabilities. Current release is v1.7d.
                FredoCorner is based on a different approach, so may fail where RoundCorner would make it and the reverse. That's why many users install both plugins.
                • K
                  kid1412200
                  Hi Fredo,
                  I install Plugin FredoCorner 3.3a in Sketchup 2021, but it's notification "You now need to get a License to continue using the extension". How to have License.
                  Thank you!
                  • fredo6F
                    In the messagebox, there is a button about Help on Licensing.
                    Otherwise, go to menu Tools > Fredo6 Collection > FredoCorner > License..... In the dialog box, there is a button Obtain License.
                    • kimgaK
                      kimga
                      Hi There,
                      I just bought the FREDO BUNDLE, INSTALLED ALL THE LATEST VERSIONS OF EXTENSIONS WITH FREDO LIBRARY, but the error message (attached) still asking for the latest version.
                      I restarted SketchUp 2x.
                      I use SketchUp Pro 2018.
                      What did I miss?
                      I have all the LICENCES.
                      I would be grateful for some advice.
                        You need to install the latest version of the SketchUcation Toolset [from the PluginStore/ExtensionStore³] - then restart SketchUp to ensure everything syncs...
                        The SketchUcation Toolset [>=v4.2.5] will add the latest licensing system...
                        Also ensure that you have the latest version of the Fredo Lib installed...
