    DO NOT UPGRADE TO CATALINA .... YET!!!!!
    20 Posts 12 Posters 123.8k Views 12 Watching
      Version 2019.3 is published.
      https://www.sketchup.com/download/all
      BUT it not been advertised, or notified in update checking !
      Its main change is MAC's Catalina compatibility.
      So if you must have Catalina get it.
      BUT remember that Catalina is flaky with ALL earlier versions of SketchUp and they won't be getting updated.
      So if you use v2017/2018 you can't step up to Catalina.
      Catalina has also broken lots of other common applications, so you might want to check what they are, as fixing SketchUp might only be one step down along road !!
      • jujuJ Offline
        juju
        stepping up to Catalina when you're on SU2019 / SU2019.1 / SU2019.2 is also a no-no.
          Unless you like to live dangerously 😲
          • E Offline
            Ecuadorian
            I also lost Audacity after the upgrade 😳
            -Miguel Lescano
              Catalina has broken many apps !
              The latest SketchUp v2019.3 [available but not widely advertised yet!] addresses most known issues, but I understand that it still suffers from an 'undo/redo' bug, and that needs fixing directly by Apple !
                slbaumgartner
                @Euadorian what kind of problem with Audacity are you seeing? If it is being rejected as 32-bit, you need to update to the latest release (2.3.2) which is 64-bit. However, there is known issue with access to certain input devices such as the microphone. They are looking into it. See this link for a temporary workaround:
                Page Not Found - Audacity Forum
                (forum.audacityteam.org)
                • E Offline
                  Ecuadorian
                  @slbaumgartner Thank you! It just won't open. I was in a rush, so I just used MacOS's voice recorder and then edited it in my PC. I'll look into it. Thanks!
                  -Miguel Lescano
                    ramyasri123
                      galactus
                      Plugins don't work with CATALINA 10.15.2 / SU 19.3
                      is there any news yet?
                        galactus
                        UPDATE: I just updated to Catalina 10.15.3 and installed LibFredo6_v9.5g. FredoCorner and Curviloft are working again!!!
                        • Mike LuceyM Offline
                          Mike Lucey
                          Good to hear. It looks like the wrinkles have been ironed out 👍
                            Leggy
                            So are we good to upgrade now?
                              Mike Lucey
                              Yes, all good now. I must 'unstick' this thread.
