    DO NOT UPGRADE TO CATALINA .... YET!!!!!
    20 Posts 12 Posters 123.8k Views 12 Watching
      laterstarter
      3dConnexion devices are not supported at all yet, though they inform a driver is being developed
      Natively SKP 2019 seems to work under Catalina so long as one has not been spoilt by a 3DConnexion navigation device.
      Kind Regards, Scott
        markchandler
        If you're on macOS Catalina, you should be running SU2019.3
        • jujuJ Offline
          juju
          Wow, another maintenance release?! When did this drop? I totally missed that.
          • sketch3d.deS Offline
            sketch3d.de
            • Release Notes
              Version 2019.3 is published.
              https://www.sketchup.com/download/all
              BUT it not been advertised, or notified in update checking !
              Its main change is MAC's Catalina compatibility.
              So if you must have Catalina get it.
              BUT remember that Catalina is flaky with ALL earlier versions of SketchUp and they won't be getting updated.
              So if you use v2017/2018 you can't step up to Catalina.
              Catalina has also broken lots of other common applications, so you might want to check what they are, as fixing SketchUp might only be one step down along road !!
              • jujuJ Offline
                juju
                stepping up to Catalina when you're on SU2019 / SU2019.1 / SU2019.2 is also a no-no.
                  Unless you like to live dangerously 😲
                  • E Offline
                    Ecuadorian
                    I also lost Audacity after the upgrade 😳
                    -Miguel Lescano
                      Catalina has broken many apps !
                      The latest SketchUp v2019.3 [available but not widely advertised yet!] addresses most known issues, but I understand that it still suffers from an 'undo/redo' bug, and that needs fixing directly by Apple !
                        slbaumgartner
                        @Euadorian what kind of problem with Audacity are you seeing? If it is being rejected as 32-bit, you need to update to the latest release (2.3.2) which is 64-bit. However, there is known issue with access to certain input devices such as the microphone. They are looking into it. See this link for a temporary workaround:
                        Page Not Found - Audacity Forum
                        (forum.audacityteam.org)
                        • E Offline
                          Ecuadorian
                          @slbaumgartner Thank you! It just won't open. I was in a rush, so I just used MacOS's voice recorder and then edited it in my PC. I'll look into it. Thanks!
                          -Miguel Lescano
                            ramyasri123
                              galactus
                              Plugins don't work with CATALINA 10.15.2 / SU 19.3
                              is there any news yet?
                                galactus
                                UPDATE: I just updated to Catalina 10.15.3 and installed LibFredo6_v9.5g. FredoCorner and Curviloft are working again!!!
                                • Mike LuceyM Offline
                                  Mike Lucey
                                  Good to hear. It looks like the wrinkles have been ironed out 👍
                                    Leggy
                                    So are we good to upgrade now?
                                      Mike Lucey
                                      Yes, all good now. I must 'unstick' this thread.
