    Divide oval
    17 Posts 6 Posters 4.1k Views 6 Watching
    • Q Offline
      Quail333
      Thanks, I have been banging away on this issue for a couple days.
      • bazB Offline
        baz
        Or you could do it all by eye. Artists have been winging it forever.
        In fact, 'exact' spacing can often look wrong aesthetically, compare a kerned to an un-kerned font or the margins around a framed picture for example.
        I have learned to trust my eye.
          slbaumgartner
          I agree with @baz, with the caveat that it depends on whether your goal is aesthetic or precision. Sometimes the precise answer looks awful, but might still be the correct answer to the problem at hand. Also, despite the myths about famous artists drawing a perfect circle by eye, the more likely explanation is that their circles are actually imperfect but close enough that the eye doesn't care.
          • Q Offline
            Quail333
            It is for a jewelry component and getting what you want on a small scale and symmetrical and to fit a stone is not easy by hand that is what I hope Sketchup can help me do. Incorporating an organic element is tougher than symetry when the whole thing has to come together to make a composition.
            • tibetT Offline
              tibet
              hi guys,
              i have the same problem, but somehow it doesn´t work for me:-(
              i do not play with su too often like before, so i ve´forgotten some stuff for sure.
              i ´d like to divide two ovals, an each into 8 segments with the same length.
              it´s for my teepee project.
              any help is very appreciated! thanks
              kifaru_teepee.skp
              SU 2015 Pro on Win10 x64
              • BoxB Offline
                One option using some of Fredo's tools.
                Curvizard and Divide Edges, Part of Fredo Tools.
                Explode the Oval first, otherwise it is seen as a circle, add one edge to specify a start point and weld it back together then divide it.
                • tibetT Offline
                  tibet
                  wow, thank you kindly for your effort!
                  that´s exactly what i need it!
                  best of luck!
                  • BoxB Offline
                    Happy to help.
                    • tibetT Offline
                      tibet
                      a small question please!
                      what is the plugin for "divide edges" you have been using?
                      once again, thanks a lot!
                      • BoxB Offline
                        SketchUp Plugins | PluginStore | SketchUcation
                        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                        (sketchucation.com)
