    Divide oval
    17 Posts 6 Posters 5.0k Views 6 Watching
      My general advice is to get a handle on the basic tools before you dive into plugins and extensions. There are some folks who jump right into plugins and never learn what the native tools can actually do and then when they need to do something new to them, they start looking for another plugin instead of looking at the native tools. I don't think that's a great way to learn SketchUp.
      There isn't a native too for equally dividing the oval (is it an oval or is it really an ellipse?) so an extension would be the way to go unless you want to do some math. Actually, an oval (parallel sides and semi-circular ends) wouldn't be terribly difficult to sort out manually but an ellipse would be rather involved.
      As for arraying the elements for the setting (prongs?), if you draw the first one and make it a component, you can set the component's origin, which is it's insertion point, in the proper location so you can basically drag and drop them into place from the Components panel. It's certainly not difficult but it can be a little tedious. It doesn't require any extensions, though.
      • Q
        Quail333
        David R, that was kind of you to answer my question in depth, I will keep working with my 'Dummies" book and You Tube tutorials for a while. I just need to be patient, I know what I want as a designer and I want it now! Happy New Year! Michael
          Happy that helped.
          HNY2U2
          • BoxB
            Here is a link to quite a bit of info on this subject.
            https://forums.sketchup.com/t/elliptical-array/17102
            • Q
              Quail333
              Thanks, I have been banging away on this issue for a couple days.
              • bazB
                baz
                Or you could do it all by eye. Artists have been winging it forever.
                In fact, 'exact' spacing can often look wrong aesthetically, compare a kerned to an un-kerned font or the margins around a framed picture for example.
                I have learned to trust my eye.
                  slbaumgartner
                  I agree with @baz, with the caveat that it depends on whether your goal is aesthetic or precision. Sometimes the precise answer looks awful, but might still be the correct answer to the problem at hand. Also, despite the myths about famous artists drawing a perfect circle by eye, the more likely explanation is that their circles are actually imperfect but close enough that the eye doesn't care.
                  • Q
                    Quail333
                    It is for a jewelry component and getting what you want on a small scale and symmetrical and to fit a stone is not easy by hand that is what I hope Sketchup can help me do. Incorporating an organic element is tougher than symetry when the whole thing has to come together to make a composition.
                    • tibetT
                      tibet
                      hi guys,
                      i have the same problem, but somehow it doesn´t work for me:-(
                      i do not play with su too often like before, so i ve´forgotten some stuff for sure.
                      i ´d like to divide two ovals, an each into 8 segments with the same length.
                      it´s for my teepee project.
                      any help is very appreciated! thanks
                      kifaru_teepee.skp
                      SU 2015 Pro on Win10 x64
                      • BoxB
                        One option using some of Fredo's tools.
                        Curvizard and Divide Edges, Part of Fredo Tools.
                        Explode the Oval first, otherwise it is seen as a circle, add one edge to specify a start point and weld it back together then divide it.
                        • tibetT
                          tibet
                          wow, thank you kindly for your effort!
                          that´s exactly what i need it!
                          best of luck!
                          • BoxB
                            Happy to help.
                            • tibetT
                              tibet
                              a small question please!
                              what is the plugin for "divide edges" you have been using?
                              once again, thanks a lot!
                              • BoxB
                                SketchUp Plugins | PluginStore | SketchUcation
                                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                (sketchucation.com)
