    Divide oval
    17 Posts 6 Posters 4.4k Views 6 Watching
    • Q Offline
      Quail333
      I am trying to divide an oval into equal segments, also I would like to array elements equally around an oval. This would be to create settings for jewelry design. Thanks
        You could use Polyline Divider in Fredo's Bezier Spline toolset. (Right click on the oval and select BZ-Convert to Polyline> Polyline Divider. Then you could use Chris Fullmer's Component Stringer to place instances of a component around the edge. Or use Path Copy for that. All are in the Plugin Store accessed at the top of the page.
        • Q Offline
          Quail333
          Thanks, I am still getting a handle on basic Sketchup skills do you think using plugins would be confusing or should I dive right in?
            My general advice is to get a handle on the basic tools before you dive into plugins and extensions. There are some folks who jump right into plugins and never learn what the native tools can actually do and then when they need to do something new to them, they start looking for another plugin instead of looking at the native tools. I don't think that's a great way to learn SketchUp.
            There isn't a native too for equally dividing the oval (is it an oval or is it really an ellipse?) so an extension would be the way to go unless you want to do some math. Actually, an oval (parallel sides and semi-circular ends) wouldn't be terribly difficult to sort out manually but an ellipse would be rather involved.
            As for arraying the elements for the setting (prongs?), if you draw the first one and make it a component, you can set the component's origin, which is it's insertion point, in the proper location so you can basically drag and drop them into place from the Components panel. It's certainly not difficult but it can be a little tedious. It doesn't require any extensions, though.
            • Q Offline
              Quail333
              David R, that was kind of you to answer my question in depth, I will keep working with my 'Dummies" book and You Tube tutorials for a while. I just need to be patient, I know what I want as a designer and I want it now! Happy New Year! Michael
                Happy that helped.
                HNY2U2
                • BoxB Offline
                  Here is a link to quite a bit of info on this subject.
                  https://forums.sketchup.com/t/elliptical-array/17102
                  • Q Offline
                    Quail333
                    Thanks, I have been banging away on this issue for a couple days.
                    • bazB Offline
                      baz
                      Or you could do it all by eye. Artists have been winging it forever.
                      In fact, 'exact' spacing can often look wrong aesthetically, compare a kerned to an un-kerned font or the margins around a framed picture for example.
                      I have learned to trust my eye.
                        slbaumgartner
                        I agree with @baz, with the caveat that it depends on whether your goal is aesthetic or precision. Sometimes the precise answer looks awful, but might still be the correct answer to the problem at hand. Also, despite the myths about famous artists drawing a perfect circle by eye, the more likely explanation is that their circles are actually imperfect but close enough that the eye doesn't care.
                        • Q Offline
                          Quail333
                          It is for a jewelry component and getting what you want on a small scale and symmetrical and to fit a stone is not easy by hand that is what I hope Sketchup can help me do. Incorporating an organic element is tougher than symetry when the whole thing has to come together to make a composition.
                          • tibetT Offline
                            tibet
                            hi guys,
                            i have the same problem, but somehow it doesn“t work for me:-(
                            i do not play with su too often like before, so i ve“forgotten some stuff for sure.
                            i “d like to divide two ovals, an each into 8 segments with the same length.
                            it“s for my teepee project.
                            any help is very appreciated! thanks
                            kifaru_teepee.skp
                            SU 2015 Pro on Win10 x64
                            • BoxB Offline
                              One option using some of Fredo's tools.
                              Curvizard and Divide Edges, Part of Fredo Tools.
                              Explode the Oval first, otherwise it is seen as a circle, add one edge to specify a start point and weld it back together then divide it.
                              • tibetT Offline
                                tibet
                                wow, thank you kindly for your effort!
                                that“s exactly what i need it!
                                best of luck!
                                • BoxB Offline
                                  Happy to help.
                                  • tibetT Offline
                                    tibet
                                    a small question please!
                                    what is the plugin for "divide edges" you have been using?
                                    once again, thanks a lot!
                                    • BoxB Offline
                                      SketchUp Plugins | PluginStore | SketchUcation
                                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                      (sketchucation.com)
                                      With your input, this post could be even better šŸ’—
