    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
    • samuel_tS
      samuel_t
      @oxer said:
      Samuel , really the Model height (cm) option do something, I changed this parameter to different values but the imported model has the same dimensions always.
      Hi Oxer! This feature works pretty well on Windows. I don't know why it doesn't work at all on macOS.
      • samuel_tS
        samuel_t
        @sibawal said:
        im using mac os high siera , sketchup 2019, and blender 2.81a
        This Blender is not supported. 😕 Export to .fbx or, as suggested by @Oxer, retry with Blender 2.79. 😉
        • samuel_tS
          samuel_t
          1.1.4 version fixes rendering of some high-density models (typically trees).
          Download latest Universal Importer plugin from SketchUcation PluginStore.
          • OxerO
            Oxer
            In the image the height issue on Mac.
            • L
              lewmosconi
              Hello man, thanks in advance for the app.
              But every time I try to import an FBX, messages like that appear.
              Universal Importer Error: Command failed: "C:/Users/Leo/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universaLimporter/Assimp/Win/assim p.exe- info 'C:WrogramData/Universal Importer/tmp/import.FEOC > "C:WrogramData/Universal Importer/tmp/assimp.nfo-
              C:/Users/Leo/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universaLimporter/assimp.rb:166:in 'get_texture_refs'
              Universal Importer Version: 1.1.4
                "WrogramData"?
                Does it actually say "WrogramData" instead of "ProgramData"?
                • samuel_tS
                  samuel_t
                  Hello. Reinstall Microsoft Visual C++ library (it can fix your error) then let me know if problem persists.
                  • K
                    kostiaarh
                    Hello. Importer Error. What does that mean
                    • joshtaysJ
                      joshtays
                      Maybe this has been asked, I tried to search it just in case, so apologies if it has been answered already... Is there any plan to support PDF in the future? Lack of PDF import to Windows Sketchup boggles my mind.
                      • samuel_tS
                        samuel_t
                        Hello @kostiaarh. This sounds like a bug. Could you please upload your model to a file hoster? This way I could debug it.
                        • K
                          kostiaarh
                          Yes. I uploaded the file. Thanks you.
                          https://mega.nz/#!WKZDkYSA!3HFXWqZTRpVGt_tUftP-i639I5TpToyvc4lG9apMFTA
                          • H
                            Headmade
                            Hi, iI installed the latest version of the plugin and it does not work on mac os ((
                            • samuel_tS
                              samuel_t
                              There's no plan to support PDF in future. 😕
                              • samuel_tS
                                samuel_t
                                https://sketchucation.com/forums/download/file.php?id=158465
                                Problem comes from model encoding. I've manually fixed "222.obj" and "222.obj.mtl" with a text editor.
                                I've attached fixed model:
                                222-fixed-model.zip
                                • samuel_tS
                                  samuel_t
                                  https://sketchucation.com/forums/download/file.php?id=158468&t=1
                                  Hi. What version of macOS are you running?
                                  • E
                                    Einstein
                                    Would it be possible to implement support for TGA format of textures? You can often download models textured with TGA files.
                                    • samuel_tS
                                      samuel_t
                                      Yes. It's possible. 😉
                                        db11
                                        Thanks for the great work on this extension Samuel. It's so useful, and I appreciate the rapid iteration / evolution to address user feedback.
                                        Fantastic job!
                                        • samuel_tS
                                          samuel_t
                                          1.1.5 version adds TGA and TIFF support for textures.
                                          • PixeroP
                                            Pixero
                                            Thanks you.
                                            I agree with the previous poster that PDF import would be awesome.
                                            • 22
                                            • 23
                                            • 7 / 23
