    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 647.3k Views 113 Watching
    • OxerO
      Oxer
      The .blend files of 2.80 don't work dought to changes in the API, try with .blend files of Blender 2.79, for me these work fine.
      • OxerO
        Oxer
        Samuel , really the Model height (cm) option do something, I changed this parameter to different values but the imported model has the same dimensions always.
        • samuel_tS
          samuel_t
          Hi Oxer! This feature works pretty well on Windows. I don't know why it doesn't work at all on macOS.
          • samuel_tS
            samuel_t
            @sibawal said:
            im using mac os high siera , sketchup 2019, and blender 2.81a
            This Blender is not supported. 😕 Export to .fbx or, as suggested by @Oxer, retry with Blender 2.79. 😉
            • samuel_tS
              samuel_t
              1.1.4 version fixes rendering of some high-density models (typically trees).
              Download latest Universal Importer plugin from SketchUcation PluginStore.
              • OxerO
                Oxer
                In the image the height issue on Mac.
                • L
                  lewmosconi
                  Hello man, thanks in advance for the app.
                  But every time I try to import an FBX, messages like that appear.
                  Universal Importer Error: Command failed: "C:/Users/Leo/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universaLimporter/Assimp/Win/assim p.exe- info 'C:WrogramData/Universal Importer/tmp/import.FEOC > "C:WrogramData/Universal Importer/tmp/assimp.nfo-
                  C:/Users/Leo/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universaLimporter/assimp.rb:166:in 'get_texture_refs'
                  Universal Importer Version: 1.1.4
                    "WrogramData"?
                    Does it actually say "WrogramData" instead of "ProgramData"?
                    • samuel_tS
                      samuel_t
                      Hello. Reinstall Microsoft Visual C++ library (it can fix your error) then let me know if problem persists.
                      • K
                        kostiaarh
                        Hello. Importer Error. What does that mean
                        • joshtaysJ
                          joshtays
                          Maybe this has been asked, I tried to search it just in case, so apologies if it has been answered already... Is there any plan to support PDF in the future? Lack of PDF import to Windows Sketchup boggles my mind.
                          • samuel_tS
                            samuel_t
                            Hello @kostiaarh. This sounds like a bug. Could you please upload your model to a file hoster? This way I could debug it.
                            • K
                              kostiaarh
                              Yes. I uploaded the file. Thanks you.
                              https://mega.nz/#!WKZDkYSA!3HFXWqZTRpVGt_tUftP-i639I5TpToyvc4lG9apMFTA
                              • H
                                Headmade
                                Hi, iI installed the latest version of the plugin and it does not work on mac os ((
                                • samuel_tS
                                  samuel_t
                                  There's no plan to support PDF in future. 😕
                                  • samuel_tS
                                    samuel_t
                                    https://sketchucation.com/forums/download/file.php?id=158465
                                    Problem comes from model encoding. I've manually fixed "222.obj" and "222.obj.mtl" with a text editor.
                                    I've attached fixed model:
                                    222-fixed-model.zip
                                    • samuel_tS
                                      samuel_t
                                      https://sketchucation.com/forums/download/file.php?id=158468&t=1
                                      Hi. What version of macOS are you running?
                                      • E
                                        Einstein
                                        Would it be possible to implement support for TGA format of textures? You can often download models textured with TGA files.
                                        • samuel_tS
                                          samuel_t
                                          Yes. It's possible. 😉
                                            db11
                                            Thanks for the great work on this extension Samuel. It's so useful, and I appreciate the rapid iteration / evolution to address user feedback.
                                            Fantastic job!
                                            • 22
                                            • 23
                                            • 7 / 23
