    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 79.2k Views 40 Watching
    • deaneauD
      deaneau
      short answer. SKP2015 make and pro works. download and install.
      @Esense3d.. dont be shy to answer.
      the shortest and fastest answer is this (if this work)
      • G
        Guilherme Bera
        Wow, thanks Aerilius for this plugin!! I was so amazed that I added the toolbar function to a bunch of plugins. Indeed, I'll post to each author, my icons and the modified script.
        Anyway, I was wondering if would be possible mix the Toolbar Editor and the LaunchUp. Let's me explain, the LaunchUp is able to keep the last searched function as a mini functional toolbar. And the Toolbar Editor make possible create custom toolbars. So, you would have some floating windows grouping your custom toolbars, a even more revolutionary UI implementation.
        I'd like to make me helpful, but I'm just a ruby starter yet.
        • greenskpG
          greenskp
          Thank you very much!
          • G
            Guilherme Bera
            @aerilius said:
            The toolbars are stored in the registry
            HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2014\Plugins_ae\ToolbarEditor.
            You can copy and paste it in the same key on another SketchUp installation or version. You can also use the File → Export functionality of the registry. I'm not sure whether I should add an export button to each of my plugins, I hope SketchUp will provide an efficient and central place to migrate settings.
            From a developer side, I want to emphasis again that most of us want plugin settings to be namespaced and bundled in one sub-key, and not mixed within SketchUp's internal keys.
            I did my backup in this way, and today I restarted my windows and restored the registry key. The custom toolbar appeared again, but I was unable to add more toolbar or functions.
            So the only way was to redo all the custom toolbars 😞
            • T
              thirdleft
              When I import my registry from one computer to another it loads all of the toolbars but does not load the buttons.Any ideas why this may be happening?
              Thanks in advance!
              • T
                thirdleft
                Thanks in advance!
                Okay the problem is because it remembers the username of the original computer. I logged into a colleagues computer with my username and it works but when i log in with his it doesnt. Is there any way of fixing this manually?
                Ideally i want to set up a registry and plugin data file for 3-4 users in our office so we all have the same toolbars but because we obviously dont have the same username it isnt working. Does this mean i have to set it up one by one?
                Thanks for all your help
                Regards,
                Keith
                  Jim
                  Look also in your "%APPDATA%\SketchUp Toolbar Editor" folder for toolbar commands.
                    rv1974
                    I've got subjective feeling that my custom TE icon loading is painfully slow on start-up.
                    Is it possible or loading original toolbars would take the same amount of time?
                      Ahmed0007
                      Toolbar Editor (1.1.3); not showing any icon in sketchup 2016, 17, 18 but it's showing 2019 can you please fix this problem.
                      • panixiaP
                        panixia
                        Is there a code snippet i can use to emulate keystrokes?
                        That would be a quick way to create a custom button which mimics a shortcut for menu entry.. ❗
                        • dereiD
                          derei
                          Is this plugin still being maintained? For some reason it doesn't add separators anymore.
                          DESIGNER AND ARTIST DEREI.UK
                          • jujuJ
                            juju
                            Latest version on EW is 1.1.8
                            • dereiD
                              derei
                              that's the one I have installed and it was acting funny by not adding separators on toolbars despite the fact they were being added in the editor. After briefly looking over the script, it seems the id of the elements is being taken from LaunchUp, so perhaps that one isn't being updated?
                              • 6 / 7
