[Plugin Library] LibFredo6 - v14.5b - 24 May 24
Did you see my answer in the Animator subforum?
I give a link to the latest version of FFmpeg for Mac.
- This points to a zip file.
- Extract the file 'ffmpeg' located in the zip archive under 'bin'
- put this file somewhere on your Mac where it's convenient to you
- In the Animator video, Click on the button 'locate FFMpeg' and point to this local file.
NEW RELEASE: LibFredo6 v9.5b - 08 Jan 20
LibFredo6 9.5b is a minor release for bug fixing and adjustments.
On SU 2018 the new update (with LibFredo v9.5b) is not preserving the guides.
(Correction) posted in wrong forum, this comment was meant for Fredo Guides. -
(Correction) posted in wrong forum, this comment was meant for Fredo Guides.Could you open the Ruby Console when you protect guides and then when you delete them, in order to see if there are error messages. Thanks.
ruby console is blank, doesn't show any activity.
@penumbra said:
[attachment=0:v3qajxdy]<!-- ia0 -->Annotation 2020-01-09 132839.png<!-- ia0 -->[/attachment:v3qajxdy]ruby console is blank, doesn't show any activity.
Does the problem happens with any model?
interestingly, no it does not. starting a fresh model the plugin works fine.
but here is something that pops up on the ruby consol when i start the sketchup file where it doesn't work. -
Could you post or PM me the model.
Because of this error, the process of protection does not start and thus is not active for this model.
Hi Fredo,
I just updated libfredo and it seems to have caused an issue with Curvizard.
Any curve and any action creates stange edges between points.
@box said:
Hi Fredo,
Any curve and any action creates stange edges between points.Many thanks for signaling the problem.
Definitely a major bug, which I fixed in LibFredo6 v9.5c, just published.
NEW RELEASE: LibFredo6 v9.5c - 10 Jan 20
LibFredo6 9.5c fixes a major regression bug affecting Curvizard. It is strongly advised to upgrade
Thanks Fredo for being so proactive and responding so quickly on all your plugins. On my phone at the moment so will confirm as soon as I'm able.
Thanks again Fredo.
Hi Fredo
Many thanks for looking at the issues with my file and FredoGuides. I sent you a separate PM with a WeTransfer link. Hopeful the file can shed some light and provide the necessary feedback. -
Hi Fredo!
What a wonderful set of plugins you have done! I am grateful to you, your work is sparing me loads of time!!!I'd have a question: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component? Since I work a lot with DCs this would be a greatly useful add-on..
Thanks in advance!
This is a good idea, and I think this is manageable.
NEW RELEASE: LibFredo6 v9.5d - 03 Feb 20
LibFredo6 9.5d fixes a major regression bug affecting Curvizard, preventing the generation as Sketchup curves for some tools. It is strongly advised to upgrade
NEW RELEASE: LibFredo6 v9.5e - 05 Feb 20
LibFredo6 9.5e is a minor release
- necessary for FredoTools::ReportLabelArea to count face area by material when material is applied to groups or components instead of faces
- For the opening of certain files on Mac, due to changes made in SU2019.3 and SU2020.
This is now available in FredoTools::ReportLabelArea v3.2a, with
For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
